Extra sping after steering wheel disassembly
Old 04-30-2016, 05:59 PM
newagereject's Avatar
Car: 1988 Trans Am GTA
Axle/Gears: 3.73 posi
I have this metal spring in the pictures and i can not remember where it goes can anyone tell me where it goes?
Old 04-30-2016, 06:37 PM
Twin_Turbo's Avatar
Re: Extra sping after steering wheel disassembly
IT's the key warning buzzer contact
goes into the little slot near the lock cilinder
Old 04-30-2016, 06:40 PM
Twin_Turbo's Avatar
Old 04-30-2016, 09:59 PM
Kinda hard to tell in your picture I'm assuming top?
Old 05-01-2016, 01:34 AM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Remove this, install spring from end facing column, hook on plastic body.
Old 05-01-2016, 02:05 AM
Alright thank you
Old 05-01-2016, 03:27 PM
So I'm having trouble getting the ignition cylinder into the hole, it appears that the pin flat part that is supposed to go into it won't turn back far enough, in the first two pictures I have shown what I mean, the third image shows the gear on the left side that move with the pin, what am I supposed to do to fix this?
Old 05-02-2016, 11:56 AM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Put the key in the ignition so you can turn/align the flat pin.
Cmk24
04-24-2016 06:09 PM
wgripp
04-24-2016 01:39 PM
Donald Croes
04-20-2016 04:35 PM
someone972
Wheels and Tires
04-14-2016 09:39 AM
Quick Reply: Extra sping after steering wheel disassembly
