Side window moves side to side, need fixing
Car: 91 GTA
Axle/Gears: 3:73
Looking for some direction on my door window, when part way down it moves side to side. I'm looking to replace broken parts just wondering if someone knows of the part that may be broken.
Sorry I'm out of town and haven't pull the door apart yet. with a little luck I'd like to order parts first then take car apart. I'm currently ordering other parts from top down solutions and might add to the cart
Cheers
Cheers
Car: 91 GTA
Axle/Gears: 3:73
Car: 91 GTA
Axle/Gears: 3:73
Re: Side window moves side to side, need fixings
Put it this way I avoid closing the door when the window is part way down. It's either all the way up or down to prevent causing more damage
Sounds like your window guides are worn out.
Car: 91 GTA
Axle/Gears: 3:73
I took apart the inner door panels and found these parts just loose fallen down at the bottom of the door.
Can someone confirm where the black rubber piece goes? I'm assuming the white plastic piece goes between the actual window to the door acting as a spacer
