Ignition switch wiring help
Car: 86 Z28 Camaro
Engine: 5.7 Vortec
I'm trying to find what the dark green wire that plugs into the ignition switch does. It's a 86 camaro.
Re: Ignition switch wiring help
Dark green/white stripe Power to instrument panel.
http://austinthirdgen.org/mkportal/m...ody_wiring.gif
Car: 86 Z28 Camaro
Engine: 5.7 Vortec
Car: 86 Z28 Camaro
Engine: 5.7 Vortec
Both turn signals work on the outside of the car. And my wiring diagram shows the right rear being dark blue
Car: 86 Z28 Camaro
Engine: 5.7 Vortec
I could have sworn it was connected to the coolant gauge. I had everything marked and my little boy pulled off some of the tape that had the writing for what it was and lost them. So that's why I'm in the dark. I appreciate it
Car: 86 Z28 Camaro
Engine: 5.7 Vortec
Well I found it. I had cut all my gauge plugs off and marked the wires. Well my little boy took off the tape that had my markings. Well I found my plugs and sure enough the dark green coolant wire is tied together with the dark green wire that goes to the ignition switch
