Overhead console flashlight
Car: 1986 IROC Z28
Transmission: auto
After reworking my 86 iroc headliner I replaced all the burnt out bulbs and the console and map light work, however the removable flashlight I can't get working after replacing batteries so I have to believe it's the bulb but when trying to remove it broke into pcs. It's not a standard bulb but more of a magnifying bulb, anyone have any idea where to find a part # or the bulb ? I don't think this thing has ever been used and it's in great condition.
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: Overhead console flashlight
I'm sure you can get these at a local Pep Boys or Hardware.
https://www.google.com/url?sa=t&rct=...MEXfvLS3A097ew
Yep thats the one.
Ive been wanting to try this one.
http://www.ebay.com/itm/Epistar-LED-...kAAOSwLEtYhy2P
Engine: 5.0 EFI
That would be brighter.Personally,I've never used mine,for all I know the batteries are most likely dead.lol.
Car: 89 Iroc Convertible
Mine works although I don't keep batteries in it.Dont want them leaking inside my flashlight
Engine: 5.0 EFI
Yea, I should remove the batteries also. I seldom use the TA.
It's pretty much just there for show anyway.I don't ever use it
Same here !
Many times when I thought the bulb was dead, but it was just crud on the terminals that was not allowing voltage to flow. The best way I've found to clean all the little contacts inside these things is to pull them all out of the flashlight and drop them into a cup that's got Klean-Strip RUST Remover in it. Just enough chemical to completely cover the contacts. ( & NOT a plastic cup !! ) Leave then in their overnight and then pull them out and dry them off. The contacts can be totally covered in crud when you start, but they will come out looking almost new. A quick wire brush before re-installing them and Wa-La; A working flashlight again !
Wish i still had picture, but I can't seem to find it.
