[For Sale] Patriot stage II cnc heads, comp xer273 cam
Re: Patriot stage II cnc heads, comp xer273 cam
They would bump compression but make more power with the better port flow. Its a good sized head more ideal for higher rpm but a 6.0 has more cubes than the ls1 this setup was on. Pulled to mid 6000's with the small cam and held well to 7000 rpm shifts
Flow on a local bench showed 272 at .585". 193 exhaust flow at .600. Seems lower than most benches, think stock 243's dont flow over 240-250 on this bench. They are an older patriot head, may not quite be 227cc but run hard on the ls1 it came off of
Bump!
Bump!
COTM Editor
Received 1,855 Likes
Car: '89 Firebird
Engine: 7.0L
mz92274
08-25-2015 08:47 AM
