LSX and LTX Parts Looking to buy or sell LSX or LTX parts? Post it here.
[For Sale] 89 Formula w/LS1 M6 swap project
Old 07-07-2015, 08:16 AM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
It pains me to do this, but the time has come for someone to finish my project. Lots of time and parts have gone into this, but I would like to move on.
The car is solid and apart from surface and use rust, the car is pretty good. It has been in an accident which CarFax shows. The drivers side front corner was damaged so I put on a new fender and bumper. Shortly after, I bought a newer daily and the LS1 swap began. It's not quite finished. The car runs, needs to be tuned (idles ok, WOT is pig rich) and I have been installing late model Formula parts. I have the bumper and am working on putting the washer bottled under the nose filler plate. The hood needs a little glass work. I have the rear wing to complete the conversion. The two issues with the car that I know of are; after the engine warms up, there is a subtle whine coming from the clutch area and the blower fan doesn't work. I think the whine is the TOB or the input shaft bearing, to be honest, I'm not sure. Please feel free to ask questions, I'm sure I forgot something. More pics will be added too
I am looking for $7k as is. I would prefer not to part it out.
Link to some pics:
https://drive.google.com/folderview?...Xc&usp=sharing
Car info:
1989 Formula WS6 T - tops
116K on the body, less than 100 on the brand new engine
1991-92 Formula front, rear and hatch (spoiler included)
Small nostril ram air hood
Black interior, 4th gen center console, AEM WB gauge and electronic oil pressure where the radio is. No head unit, but all speakers are there and two amps have been installed in the rear fold down seat. 1LE AC delete. Trunk mounted battery. 91-92 GTA tail lights.
4th gen WS6 wheels
Brand new LS1 (trip odo is actual engine miles)
-FAST 92MM intake
-FAST 92MM TB
-Futural F13 cam
-Patriot Stage 2 CNC ported heads
-42lb injectors
-High flow oil pump
-Double roller timing chain
-SS fuel lines
-Hawks long tubes to 2.5" cats, 3" cat back to dual 3" out Flowmaster
-High amp alternator
Freshly rebuilt T56
-LS7 clutch
-New slave cylinder
-4th gen aluminum drive shaft
-GTO shift ****
4th gen 3:42 rear and fuel tank.
Suspension
-Belltech drop spindles
-Ground control weight Jacks
-KONI shocks
-BMR adjustable panhard bar
-Lakewood control arms
-Lakewood subframe connectors
-New front shock bearing hats.
-Spohn tubular k-member
-BMR 3 point shock tower suport.
-Magical wonder bar
Brakes
-BAER 13" track kit
-New SS brake lines
Attached Thumbnails 89 Formula w/LS1 M6 swap project-img_1720resize.jpg   89 Formula w/LS1 M6 swap project-engine1-09.jpg   89 Formula w/LS1 M6 swap project-img_1718resize.jpg
Old 07-07-2015, 09:21 AM
RamIt's Avatar
Car: 1984 z28
Engine: 93 LT1 350
Axle/Gears: 7.625" 28 spline 3.23
Re: 89 Formula w/LS1 M6 swap project
Your link to google drive is broken.
Try logging out then checking to see if you can see them.
Killer project.
Old 07-07-2015, 10:16 AM
Omega's Avatar
Engine: LS1 / LS3
Killer project.
Thanks, they should be ok now.
Old 08-27-2015, 01:45 PM
Omega's Avatar
Engine: LS1 / LS3
SOLD! Please close.
Jorlain
08-24-2022 05:11 PM
rubblerubble
03-13-2016 06:57 PM
Fox118
Members Firebirds
111
01-26-2016 07:17 PM
sac92transam
10-07-2015 02:31 PM
ericjon262
09-11-2015 06:07 PM
Quick Reply: [For Sale] 89 Formula w/LS1 M6 swap project
