Stock LS1 dyno chart
Old 05-24-2006, 02:45 PM
z28evans's Avatar
Car: 89 iroc
Howdy,
I've attached my dyno chart, Blue is with the TPI intake and Red is a 'Cold Air Intake' run (removed the tpi intake). 1998 LS1 stock, with 2001 Exhaust manifolds, M6 trans.
James
Old 05-24-2006, 10:11 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
I knew that the Camaro Airbox was restrictive, but 17hp and 13lbft torque, that's alot.
Old 05-24-2006, 10:38 PM
92rs85berlintta's Avatar
Car: White 25th Anniversary RS
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
Holy crap!! I wonder what amount thats holding back my cc306 LT??
Old 05-24-2006, 11:15 PM
StevenK's Avatar
Car: 91 Z28
Axle/Gears: 3.73 Hawks 8.8
Damn thats a huge difference from the airbox. Is it gutted or completely stock?
Old 05-24-2006, 11:16 PM
Klortho's Avatar
Car: 1987 GTA
I don't think it would matter if it was gutted or not, you're still trying to suck the same amount of air through a little tiny hole compared to a big ole hole.
Old 05-25-2006, 11:01 AM
z28evans's Avatar
Car: 89 iroc
Not a very good photo, but it gives you an idea of the intake that i'm talking about.
It is with the baffles removed and K&N filters that have about 2.5k miles on them since the last cleaning. The intake has a smaller diameter than the ls1 maf, and has some restrictions inside of it as well. It doesn't have the cross-sectional area that is needed.
James
Old 05-25-2006, 08:35 PM
StngKlr's Avatar
Car: 89 RS
Transmission: TH350
Damn, that is alot. I wonder if some tuning would net even more HP. Nice job.
I was gonna do this type of test at the drag strip, but never put together any type of CAI lol. Now this will be the next thing I'll do to the car. What did you use btw?
Old 05-25-2006, 09:01 PM
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
wow that motor is so beutiful in our cars!
Old 09-22-2006, 12:49 PM
GregWestphal's Avatar
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
I don't see the attached picture. Was it removed from the post? Thanks!
Old 09-22-2006, 02:24 PM
z28evans's Avatar
Car: 89 iroc
Howdy,
My webhosting companies' server went down and they lost a lot of my content (their backups didn't work). It will probably be a few weeks before i get all of the photos back online, and even then the links will most likely not work.
Sorry,
James Evans
Old 09-23-2006, 07:14 AM
xtremeirocz's Avatar
Car: 1986 Irocz- Houstons Fastest Street
Engine: 408 LS1 w/ 2 stage
Transmission: Turbo 350
Axle/Gears: 3:73,3850 lbs , best of 9.92 @ 138
I was the one who got to make the pull on the dyno and it was amazing how much faster it reved without that stock box
Old 09-23-2006, 08:11 AM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
Cant see the pictures either. What size cold air did you go with?
IM about to give up on mine as well. IM modifying it as much as i can but still not sure what im doing.
Was the tpi intake box stock? stock air filters?
Old 09-23-2006, 11:52 PM
z28evans's Avatar
Car: 89 iroc
I had a stock tpi dual snorkle/cold air intake with K&N filters, and the baffles removed.
It made 17hp and 13ftlbs more with the maf open than it did with the intake.
I haven't made a new intake yet, just been driving it. I have a plan on the new intake, but i want to fab up something for fun and not go the traditional tube off to the side aftermarket intake. It's on my list of things to do
Old 09-24-2006, 08:36 AM
MikeH's Avatar
Car: 90 IROC
Engine: 406
I like the camaro design, so i would like to keep it. Its just designed for a 245 horse motor.
I have an aftermarket hood, and there is more space. between the hood and intake, then the stock hood. I took a heat gun to the area where it necks down and looks like it would flow pretty well now. I will smooth it out and paint it if it makes good power.
IM working on opening the other major restriction where the boot connects to the intake. It necks down a lot there. The boot is around 3.5 id, but the box necks down to 2.5 on one side, not good.
After thats done im going to dyno the car.
Old 10-02-2006, 03:27 PM
dingle's Avatar
Car: '83 Camaro
What were the dyno numbers?
MustangBeater20
10-29-2022 09:20 PM
1984HO
03-19-2021 11:59 AM
Orr89RocZ
04-25-2016 08:28 AM
sweet_87_iroc
09-25-2015 10:01 PM
eightsixseven
08-14-2015 03:09 PM
Quick Reply: Stock LS1 dyno chart
