VATS bypass module
Old 03-27-2007, 03:06 PM
RAGEman's Avatar
Car: 87 Camaro Z28
VATS bypass module
Has anyone ever had any trouble out of the various VATS bypass modules? Im just curious if my VATS is being bypassed. If not, I need to have it programmed out of the PCM. Thanks.
Old 03-27-2007, 05:05 PM
Blue1989RS's Avatar
Car: 1989 RS
Engine: 3.1L + .060" overbore
Axle/Gears: 4.11, Auburn LSD
Re: VATS bypass module
I was lucky enough to have the complete 94 donor car when I did my swap. So I just pulled the VATS box out of the 94 dash and used the right resistor to make it pulse and hooked it up. Worked for me! Is your swap done yet, or are you having post-swap problems?
Old 03-27-2007, 05:18 PM
RAGEman's Avatar
Car: 87 Camaro Z28
It's isnt quite finished yet. I havent worked on it for at least 6 months, Im going to start working on it again to try to fix it.
Old 03-27-2007, 08:49 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Best thing, have the VATS taken out of the PCM, that way you don't have to worry about the module going bad and stranding you somewhere.
InfernalVortex
04-20-2021 11:31 AM
RS Reaper
10-17-2018 07:52 PM
$750 L98
11-07-2015 02:26 PM
dusterbd
09-29-2015 08:40 AM
tattmann
09-27-2015 05:20 PM
Quick Reply: VATS bypass module
