Lt1 wiring.... fusing?!
Old 05-25-2007, 09:24 PM
WhiteBlaze's Avatar
Car: 1984 Firebird
Axle/Gears: 3.42's
Hey guys, I had my harness reworked by a person, so all i have are like 7 wires. For the switched and the constant, I just found two wires under the hood and tapped into them. Are these probably already fused, or not?
Also, I have relays for the fan and fuel pump.. how should these be fused, and what amp rating??
Thanks!!!
Old 05-27-2007, 09:10 PM
eagle_eyes's Avatar
Car: 1988 Pontiac firebird
Engine: '93 LT1
Transmission: Built 700R4
Axle/Gears: 3.70 9 bolt
Re: Lt1 wiring.... fusing?!
all origional power wires from the car are fused...unless it's directly from the battery. the relays for my fuel pump and fans have 12 v. power going to them.
Old 05-28-2007, 12:16 AM
WhiteBlaze's Avatar
Car: 1984 Firebird
Axle/Gears: 3.42's
Thanks for the reply. That saves a lot of headaches, but I'll still need to probably fuse my fuel pump and electric fan, I have a former carb'ed car.
Old 05-28-2007, 10:11 PM
eagle_eyes's Avatar
Engine: '93 LT1
if you are unsure if a hot wire has a fuse in it or not...or can't find one, i would put a fuse in it....2 fuses is better than none
3rd gen money
10-11-2019 09:57 PM
thunder57
11-07-2015 02:28 PM
AmorgetRS
09-28-2015 09:33 PM
lanceflame44
09-25-2015 12:28 PM
gta892000
09-16-2015 12:37 AM
Quick Reply: Lt1 wiring.... fusing?!
