View Poll Results: Did this swap make the power you would have expected?
Yes
59.65%
No
8.77%
I have no idea!
31.58%
Voters: 57. You may not vote on this poll
LS1 1991 Z28 Swap
Old 06-01-2008, 06:46 PM
  #51
ssean92's Avatar
Car: sold
Re: My LS1 Vs. 2001 Corvette video
I wasn't knocking it Bro..... And I am with you on the go fast. hence the 383 I have...LOL
Old 06-01-2008, 09:24 PM
  #52
RaGiN Z's Avatar
Car: 83 Camaro
Engine: 383 stroker, mini blower, nitrous
Transmission: TKO600
Re: LS1 1991 Z28 Swap
been thinkin about it... not a fan of the 4th gen console... Doesn't go well with the car. I like the seats tho! are they bolt on?
Old 06-02-2008, 04:06 AM
  #53
Bradlyj8Z28's Avatar
Car: 1991 Camaro Z28
Engine: 2002 SS LS1
Transmission: 6 speed
Axle/Gears: Auburn 3.42
The seats are a direct bolt in. I actually get allot of questions about the car, everyone thinks the seats and console are factory. Fits in great, its actually a direct bolt in also. The only thing I am lacking is a trim plate for the front of the firebird radio pod.
Old 06-02-2008, 08:44 AM
  #54
RaGiN Z's Avatar
Car: 83 Camaro
I agree that it looks factory especially being that they practically are I am just not a fan of the flow of it with the third gen dash. Are you planning to replace your dash as well? I see its got a lot of cracks in it.
I am gonna have to look around for 4th gen seats, thats official. What about the back seats?
Old 06-02-2008, 10:20 AM
  #55
Engine: 2002 SS LS1
The seats are a direct bolt in, even the back. I have the back seats that match my front. I am going to replace the dash cover, eventually, its easy. I have just been concentrating my efforts on my swap, and making it drive like it came that way. Fast, efficient now, pretty later....
Old 06-10-2008, 05:41 PM
  #56
cool z's Avatar
Car: 91 Camaro vert
how long did it take you to do all the wiring?
Old 06-10-2008, 07:36 PM
  #57
Engine: 2002 SS LS1
I actually had a buddy, who is a wiring genius, give me a hand. The wiring itself took approximately 3 hours, with good schematics. Now if I had done it on my own, with the little electrical experience I have, it probably would have been at least 6 hours.
Old 06-10-2008, 08:31 PM
  #58
RaGiN Z's Avatar
Car: 83 Camaro
that doesn't seem all that bad actually
Old 06-12-2008, 05:55 PM
  #59
Blownz28man's Avatar
Car: 92 25th anv z28
Engine: 346 TC78 Turbo
Transmission: 4L80E
Axle/Gears: 3.25 9"Nodular, Strange axles
Got a question for you... The plugs that are under the passenger side dash that plug in to the engine harness.. what are the pinouts? What did you do about them?Also the fuse panel(driverside firewall) theres a mess a wires there and thats next on the agenda for my swap.Thanks
Old 06-18-2008, 04:02 PM
  #60
Engine: 2002 SS LS1
I didnt have to do anything to driverside firewall, I assume you mean the bulkhead connector. I used a Speartech wiring harness. Honestly, using anything else to wire in a harness, you would need to get the schematics from a factory service manual. You can find them on here just do a search.
Old 06-22-2008, 02:03 PM
  #61
Engine: 2002 SS LS1
Here is a video of me racing my buddies hopped up 5.0 Mustang..
http://videos.streetfire.net/video/1...991_167427.htm
Old 06-22-2008, 02:31 PM
  #62
mesterz2889's Avatar
theres enough reason right there yeah put that fox body in its place nice work man im envious
Old 07-11-2008, 12:09 PM
  #63
BrOdBaNd's Avatar
Car: 92 Camaro
Engine: El Tee Juan
Transmission: Tee five six
Axle/Gears: 10 Bolt 4:10's
Man I am DEAD SET on this swap. First I got to sell my lt1 t56, then my various tpi parts. Sell my 94 m6 z28, then pull my motor and tranny, sell it. Then find a t56/ls1 combo and get to work haha.
One more thing. I have 2 t56's at my house. Both are from a 94. One is actually being used in a drivable z28. The other has been sitting in my room for months. Instead of selling the t56 that I have. Would it be worth keeping? Getting another bellhousing and ls1 and putting it all together? What do I need to make an lt1 t56 work with an ls1?
Old 07-11-2008, 03:31 PM
  #64
chevyowner02's Avatar
Car: 1992 camaro
Axle/Gears: 3:73
The ls1 T-56 has a larger inputshaft. If you sell one of the LT1 T-56's pm me with a price.
Old 07-11-2008, 04:55 PM
  #65
BrOdBaNd's Avatar
Car: 92 Camaro
Engine: El Tee Juan
If I cannot use the lt1 style t56 then i am def going to sell it. Is there any way I can get it to work?
Old 07-11-2008, 07:05 PM
  #66
ssean92's Avatar
Car: sold
very nice videos
Old 07-11-2008, 08:54 PM
  #67
Car: 1992 camaro
Axle/Gears: 3:73
The clutch hydraulics are different since the LT1 is a pull clutch and LS1 is a push clutch. Also the front adapter plates are different.You can interchange them, but you have to change everything from the front adapter plate forward, including the input shaft. But behind that I belive they both are the same.
Old 07-19-2008, 09:41 AM
  #68
bonddav's Avatar
I looks like you have zr1 wheels on first what size 17x9.5 17x11
Old 07-27-2008, 12:46 PM
  #69
Engine: 2002 SS LS1
They were stock rims from a 1997 Camaro SS. I think the were 17x9.
Old 07-28-2008, 06:55 PM
  #70
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
Do you have a weight after the swap?
Old 07-29-2008, 12:22 AM
  #71
Engine: 2002 SS LS1
I havent had a chance to weigh it yet, but I will. I figure it should only be about 2-300 pounds lighter than stock.
Old 10-23-2008, 10:38 AM
  #72
Engine: 2002 SS LS1
My Z28 is getting its first paint job since new. Thought I would share a few pics along the way.. or you can view more at STREETFIRE.NET
http://videos.streetfire.net/album/1...op_1432610.htm
Old 10-23-2008, 01:22 PM
  #73
screeminchicken's Avatar
K member clearance turned out okay using an Energy Suspension trans mount the oil pan squeaks by..
Did you have issues with the LS1 AC comprossor hitting the K-member brace on passenger side or did u remove it? I cannot tell from the photo.
Also your Strut tower bar , you are using, whats the make and model.
Thanks again
Old 10-25-2008, 07:56 AM
  #74
Engine: 2002 SS LS1
The ac compressor is in the factory location, I notched the K member. The strut tower brace is an Edelbrock, for a 1991 Camaro.
Old 10-30-2008, 12:04 PM
  #75
I was actually wanting to know about the K-memeber brace. Some cars had these metal triangular pieces on the 2 sides of the K-memeber. I think one side attaches to the k-memeber and other to the body.
You could order Spohn K-member with those on it.........but heard that there might be an issue of it hitting the LS1 AC comprossor.
Old 10-30-2008, 12:44 PM
  #76
cam-'s Avatar
Car: Camaro
Engine: 6.2L
Ahh those braces. I just took mine off and meant to replace it with something modded or fabbed up and never did. Drives just the same as before so no issues without it that I have noticed. I left the drivers side on though. I also have pretty major frame connectors on my car kind of half SSM and half Kenny Brown but they are welded in all throughout the underside so that might help stave off flexing issues.
Old 11-04-2008, 02:35 PM
  #77
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
I like the wheels on the car with the sides of the spokes black. I think the black on the car would look better if it were gloss and not flat. What exhaust is that? I really like the tone.
Old 11-29-2008, 06:05 PM
  #78
82z28man's Avatar
Car: 91 Z28
Engine: 6.0 LSX Single turbo
Transmission: 4l80E
Axle/Gears: Moser 9" 3.55
If you didnt use the bulkhead on the driver side how do you wire in your gauges? Im going to be doing this swap very shortly, and was just curious.
Old 11-29-2008, 07:02 PM
  #79
Engine: 2002 SS LS1
I had to tap into the bulkhead harness to wire in the gauges.
Old 11-29-2008, 07:11 PM
  #80
Engine: 2002 SS LS1
Most recent pics after paint job...Please notice the plates...
http://www.streetfire.net/profile/Bradlyj8Z28.htm
Old 11-29-2008, 07:46 PM
  #81
Car: 1992 camaro
Axle/Gears: 3:73
Dang that turned out nice!
Old 12-04-2008, 09:58 PM
  #82
On Probation
TPI TERR's Avatar
Car: 87 IROC-Z
Engine: LsX
Transmission: MN12 6speed
Axle/Gears: 3:42
any pics of ur y pipe?
Old 12-16-2008, 10:08 AM
  #83
zacharyhorn's Avatar
Car: 91 Firebird
Engine: Turbo 355
Axle/Gears: 3.73:1 7.625" 10 Bolt
Very nice work bro! In the next year or so I will be attempting that same swap. Right now I have my built 355 and a T56 out of a 97 trans am. I love the six speed! Still didn't get my speedo working yet, to busy driving it!
Old 01-09-2009, 03:25 PM
  #84
NETom's Avatar
Are you planning on hooking up the A/C? Will the 4th gen hoses work?
Old 01-09-2009, 04:12 PM
  #85
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Dude, drop the front tag, get some clear corner markers, new parking lights, new headlights, paint the wing, and the car would double (or possibly triple) in sweetness.
Old 01-11-2009, 09:44 PM
  #86
Engine: 2002 SS LS1
My ac is hooked up, I had custom lines made. You just have the third gen lines and fourth gens lines mig welded together. It uses the original third gen controls as well.
Old 01-14-2009, 03:22 PM
  #87
Shinobi'sZ's Avatar
I think the black on top looks sinister. I've received allot of props on streetfire. It looked like poop with the clear coat coming off. I am of the mindset, go fast first then make it pretty. I dump alloted of cash on the swap, I am pacing myself. Besides, people really underestimate it as an old worn out TPI camaro....
I do however have another video, me racing a 2001 Corvette. I look pretty fast next to him, but once he learns to drive it, he has only had it for a few days, he should outrun me. If you guys have a Streetfire account, leave some comments on my videos.
2001 Corvette Vs. 1991 Z28 LS1
http://videos.streetfire.net/video/2...LS1_164007.htm
Has to be driver.But can relate as I pulled a 95 Viper from a light and when we were done I asked him if he knew how to drive....he had 120 rear whp more then me
Your dyno numbers look pretty consistant for a stock LS1. My first (97) C5 (stock) put down 313/332 rear hp/tq. But with Heads, Cam, LS6 Intake, Headers, and underdrive pully put down 430/400 rear hp/tq. @ 6500 rpms.
You should be able to get a lot more out of that LS1 then 285 rear hp too.
and for you guys talking about dynos.
a mustang dyno simulates load that's all. a dynojet can do the same thing with and eddycurrent...as well as a dynopack.
dynojets are calculate power off of inertia...spinning drums to measure power..but with an eddy current can be made to hold power...primarily it is best (all load dynos) for tuning. But I have seen plenty of 600+ rwhp cars tuned on a dynojet...with a MAF....and turn 11 sec and under in the 1/4.
the reason a dynojet works pretty good (with an eddycurrent) on a car like the C5 is that the car is very close to the drum weight of the dyno. There are two drums...each weighing 1600lbs...thus totalling 3200lbs. A C5 Z06 is 3150 and between couple and vert get to about 3350lbs. So it is almost one to one with respect to weight and is reliable.
mustang dynos do show about 8-10% less rear wheel power then a dynojet not using a eddycurrent.
Just curious what your setup put down for hp/tq numbers...what intake did you use (97=s LT1 right)?
Old 02-16-2009, 12:33 PM
  #88
ml258-89iroc's Avatar
Car: 1989 iroc
Axle/Gears: 2.77
i am interested in how you made your y-pipe to work with the stock exhaust manifolds. i am planning on doing the same for now. thanks for any info.
Old 02-18-2009, 09:43 AM
  #89
Engine: 2002 SS LS1
I drove my car open manifold to an exhaust shop a few miles down the road. They made me a custom y pipe and mated it up to my exhaust. I will see if I can find a picture.
Old 03-29-2010, 09:56 AM
  #90
Engine: 2002 SS LS1
It has stock manifolds, with 3 inch pipe back to a two chambered flowmaster, single in with a single out and a single 3inch tip. I am adding a Borla intercooled round/slashed tip in a few days. Plus and exhaust cuttout. I will add a video after I do. I got it painted, the black is now gloss. The pics are above.
Old 03-29-2010, 12:44 PM
  #91
ShMaCk2004's Avatar
Car: 1987 Camaro IROC-Z
Transmission: LS1 T56
Axle/Gears: Richmond 3.73
what throttle cable did you use and how well does it work?
Old 03-29-2010, 07:36 PM
  #92
iroc stangs's Avatar
Car: 87 iroc-z camaro
Engine: 305TPI
Axle/Gears: G92 3.23 posi
nice job on the camaro! the new paint looks much better. and the wheels look great i'll be picking up some 02 anniversary wheels if i ever what new wheels! if you dont mind me asking how long did it take to do the engine and the required stuff and how much did you spend on the total.
Old 03-29-2010, 09:13 PM
  #93
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Nearly thought i stole your pain job for a sec in the pic but you stopped where i kept going, LOL.
Old 03-29-2010, 11:28 PM
  #94
Engine: 2002 SS LS1
I used the Lokar cable. Works and looks great. Only thing I did differant was put a screw through the mount into the firewall. Other than that, perfect.
Old 03-29-2010, 11:30 PM
  #95
Engine: 2002 SS LS1
I would say it took a couple of days to pull and put in the LS1, but I allowed a month total to work out all the bugs. I would say total I spent about 6000 on the swap. But I bought things I didnt really need. Such as a custom wiring harness, and and adjustable torque arm.
Old 04-22-2010, 12:48 PM
  #96
Engine: 2002 SS LS1
LS1 1991 Z28 Swap Exhaust Cut out
I added a QTP exhaust cut out to my car, thought I would share it...link below
http://www.streetfire.net/video/ls1-...ut_2001777.htm
Old 05-26-2010, 09:38 PM
  #97
Engine: 2002 SS LS1
Y pipe pictures
Someone asked for pics of my y pipe. Stock 2002 manifolds, with a custom made y pipe. Ugly, but gets the job done.
Attached Thumbnails LS1 1991 Z28 Swap-ypipe1.jpg   LS1 1991 Z28 Swap-ypipe.jpg
Old 04-27-2011, 09:35 PM
  #98
Engine: 2002 SS LS1
Just wanted to share another pic. My Z28.com submission for the calendar last year.
Old 04-27-2011, 10:22 PM
  #99
last_'s Avatar
Car: 91 Camaro RS
Axle/Gears: stock...
Hey man, very nice car overall. I hope you continue to push this car to even greater heights. Any updates?
Old 07-12-2011, 10:02 PM
  #100
Engine: 2002 SS LS1
I added a Wonderbar to the front end.
Attached Thumbnails LS1 1991 Z28 Swap-wonderbar.jpg   LS1 1991 Z28 Swap-wonderbar1.jpg
Quick Reply: LS1 1991 Z28 Swap
