View Poll Results: Did this swap make the power you would have expected?
Voters: 57. You may not vote on this poll
LS1 1991 Z28 Swap
1 Post
Car: 1991 Camaro Z28
Engine: 2002 SS LS1
Transmission: 6 speed
Axle/Gears: Auburn 3.42
LS1 1991 Z28 Swap
Thought I would share my swap, see what people thought, and offer advice if anyone needs it...
Here is what I started with, of course it isnt quite this pretty anymore, the paint is pretty faded... the TPI 305 needed to go...
Engine prep time...
Tired TPI / 140'ish K, ran the crap out of it, never had a problem other than water pump/alternator
The donor, a 28k 2002 LS1 from an 35th Anniversary car. It is a complete pullout with Tremmec 6 speed all accessories and ecu/wiring. The crank pulley had a few chips, so I swapped in a March underdrive pulley.
I had to cut the crossmember for the ac compressor to clear.
The test fit.
I used a Speartech wiring harness which made things easier, but as you can see, wiring in the gauges and fans was still a mess...
Engine prep time...
The test fit.
1 Post
Engine: 2002 SS LS1
Re: LS1 1991 Z28 Swap
FINALLY, setting the new engine..
I set it in with the K member out, then bolted the K member under it, I couldnt get the car high enough to pull it from underneath.
The controversial steam tube.. I hooked it up, why not? I simply threaded a fitting in my stock 3rd gen radiator and put a nipple in.
K member clearance turned out okay using an Energy Suspension trans mount the oil pan squeaks by..
Idler arm clearance wasnt an issue for me, and the Gates Hose fits okay, it just looks too long...
The rear axle is from the donor 2002 SS, its the Auburn Posi with 3.42 gears and an AAM girdle cover.
I learned the hard way, dont get the Spohn transmission crossmember with the driveshaft safety loop if you have an aftermarket drive shaft. It wont fit, my driveshaft was rubbing.
1 Post
Engine: 2002 SS LS1
Finished Product - The stock TPI aif filter intake is real restrictive, so I ordered a 2004 GTO K&N setup
The rims are also from the donor car
1 Post
Engine: 2002 SS LS1
Installed an SLP line lock, pay close attention to the length on the tires marks left on the road, and also, when I am coming back towards the camera it is roasting the tires again, I did a 180 but you cant see it through the smoke....
http://s241.photobucket.com/albums/f...t=MVI_1899.flv
Video footage from inside the car
http://s241.photobucket.com/albums/f...t=MVI_1900.flv
Car: 04 GMC Yukon XL
Engine: Vortec 5300 V8
Transmission: Hydra-Matic 4L60-E A4
That's a sweet conversion. Congrats on it. How's it run?
Car: 92 25th anv z28
Engine: 346 TC78 Turbo
Transmission: 4L80E
Axle/Gears: 3.25 9"Nodular, Strange axles
Man. You got the sister car to my car..lol. Doin the same thing right now. But using a spohn cross member. Looks good! Any words of wisdom?
Judging by his vids that he has posted Ide say it runs pretty darn decent!!!
Great job on the swap! Looks like it came out pretty sweet! Whats your exhaust set up? It sounds pretty tight... I see mainifolds, and I thought I saw what looks like a 4th gen cat in the one pic... Didnt hear a whole lot of rasp...thats my reason for asking.
Lets see what else... Was your car a 5speed or auto originally?
Again...nice work!
J.
Again...nice work!
J.
1 Post
Engine: 2002 SS LS1
My car was originally a 5 speed, in 2001 I swapped over to a 6 speed. I am using the stock 2002 manifolds for now. I read they flow as well as any set of shorty headers. I am not runnning any cats, (just a hollowed out 3inch) it goes into 3 inch exhaust all the way back into a 2 chambered Flowmaster with a single 3 inch tip on the left side. I was thinking of swapping to a Loudmouth muffler with a dump over the axle because I am not running headers yet. I am going to do headers next year, just wanted to work out all the bugs first. I would say, like any third gen converted to an LS1, its a sleeper. People immediately assume its a TPI car.
Car: 91z,97ws6,98fb,87&90jeep,05 yz250
Engine: 5.0tpi,5.7LT4,5.7LS1,4.2I6,5.7TPI,1
Transmission: t5,4l60e,
great looking swap, looks almost like our's
1 Post
Car: RS
Axle/Gears: 9" for the ladies
Looks good I would LOVE to see pictures of the wiring where it connects from the LS1 harness to the factory 3rdgen harness.
Pictures would be so nice as opposed to a text file talking about what splices to what!
Also I was wondering will the ls1/t56 bolted together drop in with the stock k-member in place or will it bind at the oil pan/k-member and firewall before they clear?
Car: Camaro
Engine: 6.2L
As for the engine dropping in together? I did manage to squeak it in there all in one but I had an overhead crane on a dolly and an engine tilter. It took three of us to do it without nicking the paint. One had to pull from below to get it to clear under the firewall and one to operate the life and one to guide it in from the top. Its a real SOB of a job but it is doable.
Im still convinced going in/out through the bottom with the k-member attached is the best way... assuming you have an engine hoist, which you should if you are pullin engines. Just goofing around, a buddy and me lifted the entire front of the donor car up by ourselves while the k-member was unbolted. Its really rather "light" up front.
Hey...might as well mention it real fast... Ill be doing my swap over again pretty much 100%. Except for the re-wiring and all the custom work. So if anyone has anything they'd like pics of or write ups on... let me know!
J.
J.
Car: Camaro
Engine: 6.2L
No argument here about dropping the car over it would be easy to do it that way a whole lot less muscle required. In my case it was not an option though as I had the engine in and out a few times for mock up and the car was on high stands so from above was the ticket.
1 Post
Car: RS
Just a nice high res pic of that would be awesome.
It's 10x easier to look at a pick and go ok the green wire with the white line on the ls1 harness goes to the tan wire with the black line on the old harness vs. pin 43 connects to a3
Car: Camaro
Engine: 6.2L
I have connections all over the place but mainly from the C100 connector ( under the brake booster ) and the LS1 fuse box I installed. If you look at the sticky at the very end theres a link with pics of my set up and an explanation of how I did it. By using the LS1 fuse box very little needed to be connected from there to the LS1 PCM it all just plugs in like stock. The actual connections are scattered all around to bring all the wires up to that fuse box I put in so thats where the actual splicing occurs. The connections to my car are all just wire added on to get it to reach out there is all. Hope that made sense
Car: '91 GTA
Engine: 402ci LS2
Transmission: faceplated T56
Axle/Gears: 9" w/ 4.11's
Aaron- All you had to do was ask me. Tim and I did mine and it turned out great... looks factory. We used the LS1's main connections and kept the weatherpacks... we cut after them (body side, no PCM side) and ran them inside the car through the passenger side fender and kicker panel to where the stock TPI ECM was. We also kept the stock 3rd gen harness under the dash so basically I could unhook the LS1 harness and put a stock TPI harness back in. Come over sometime and look at what you want to.
From what I understand, the SD cars had a one piece underhood harness (engine and body together) so we basically had to split my stock harness and kept a few things (dash gauge wire for oil pressure, water temp, etc). We also kept the stock 3rd gen relays (fuel pump, fans, etc) and used the LS1 PCM to trigger them on. The wiring was actually pretty straightforward and somewhat simple (thanks to Tim).
Also, you can install the motor/trans as one unit from above. I've done it multiple times (with my 346 and 402)... even a few times by myself with a cherry picker.
Usually I have the motor/trans together with no intake on it but with all the front accessories on it, drop it in from top at a pretty steep angle, and in the middle of doing it I drop the headers down in the K-member (Hawks SWLT's), and then when its close just hook up the motor mounts and headers. Its pretty easy to do. I even keep the radiator in the car... its a tight squeeze as one big unit but very doable. Dropping it out the bottom (like a 4th gen) is just extra and unnecessary work IMHO.
My harness has the main PCM connectors in through the firewall. Then the white and blue plug goes in through the fender where the stock 3rd gen wires went. Everything else is plug and play just like the 4th gen. I used the 4th gen fuse boxes, and the plugs are in the same general location as the 4th gen engine bay. Just hidden better. The only wires that I actually tapped into on my car were the start wires, and the A/C wire for the A/C request signal. Everything else is pretty much all 4th gen wiring. When I remove everything, Ill have to unplug the engine harness just like in a 4th gen, then for the connections that I did make, they are weather packs...so it will all just come right out. no fuss, no muss.
J.
J.
Car: 1991 RS Vert
Transmission: 4l60e
Very Clean Swap! I hope mine looks that good, I am contemplating doing the wiring myself, did you try that 1st or did you plan on going through Speartech?
Car: Camaro
Engine: 6.2L
I'm not sure who your asking but at first i was going to use Speartech but I just couldn't get an exact straight understanding of what he was going to do and the price seemed absurdly high to me so I thought why not try it? If it doesn't work out I can always buy a harness afterwards. It was a lot easier than I expected the only real trick is just organizing and labeling every single wire so you can determine what you need to hook up and what you need to eliminate.
I mean its not hard to know you need a wire for the volt gauge, one for the starter from the key switch.. hmmm whats this purple one here? aha thats it. A/C request goes to? speedo wire goes to? etc its not that hard its the mapping that takes the time.
I understand why speartech charges so much. Wiring scares the crap out of some people. And he offers an almost 100% plug and play solution for anyone to follow. That means its worth something. I still couldnt afford to get it though. haha. And Im sorta glad I didnt, beacuse now I have fuse blocks and relays and plugs and it all looks factory.
J.
1 Post
Car: RS
Yeah Jeremy, I have to check yours out! Let me know when.
I think the confusing part for those that haven't done it is there is no standard answer from those that have.
Some guys are using the 4th gen fuse box, some aren't. Some are splicing in to the 3rd gen light harness some are using the 4thgen, some are keeping the 3rd gen starter wires, some are going all 4th gen. Some got the 4th gen fuel tank and regulator, some don't.
Car: Camaro
Engine: 6.2L
Third gens varied vastly over the years with regards to wiring. Theres carbs, TBI's, TPIs, V6, 4cyl, all with unique wiring so its impossible to say "connect these LS1 wires to these third gen wires" and your done.
This is why you dont find what you want to see. But as each of us goes through it and posts up most all versions have been done before and there is enough info to get an idea and enough support to get you through to the end. So once again as I said you just need to map out all your wires and label them. Then decide what you want to keep and what you want to ditch.
For instance if you just want to run the thing hook up all the pink and red wires to + and supply fuel, disable VATS and it will run fine. Now the choice is yours whether you want to hook up a temp gauge, volt gauge, reverse lights, etc etc. Its not that difficult but you do have to map out your third gen car wiring and the wiring from your donor engine. Then its about choices the method is simple.
Good luck
Car: '91 GTA
Engine: 402ci LS2
Thats mainly because there are so many differences in our cars to begin with.
1 Post
Car: 88 GTA
Engine: Ls1
Axle/Gears: 9 bolt 3.27
Great swap, and one that I am contemplating, the catch is my car is RHD so the wireing is already messed with. I guess it is time to learn how to read a wiring diagram........
Car: 1991 Camaro RS
Engine: The Wicked six'ah
Axle/Gears: stock 3.08's
Ugh I was going to do the LT1 Swap from the Current TBI..... But this is SO much Nicer!!! and I gotta do it... but Im going to school and dont have near enough money. My instructor at school told me to swap with a 5.3L silverado engine..
1 Post
Engine: 2002 SS LS1
Dyno Run
I chose a Mustang dyno because I did not want inflated results.
This is a basically stock 2002 LS1 rated at 330 hp.
For those that dont know;
Mustang dynos reproduce real world conditions and drag to simulate being on the road. They take into account vehicle weight and such, dynos such as dynojet do not, they give you actual HP numbers to the wheels. This looks good, but I wanted to know what kind of power I was making on the street.
My car sitting on the dyno....
Okay, so with sea level correction, my car made 285hp and 300ft lbs.
I dont think that is bad for a stock engine rated at 330hp, if you figure 15% drivetrain loss its right on target....
Here is a link to the video...
http://s241.photobucket.com/albums/f...UT_DynoRun.flv
1 Post
Engine: 2002 SS LS1
Dyno Run Print Outs
The car was data logged during my run, I was concerned with knock because my car has an undertermined vibration, at WOT it was 22 degrees to 5600 RPM when I shut down my run. I was told this was normal.
I was also told my A/f ratio was dead on target for a stock tune.
I am fairly happy, I think after I descreen my MAF, and make my "cold air intake" a true cold air intake, I should be around 300rwhp. I will be happy until I finish everything else, then its on to a head and cam package. I figure not to bad for a 3 week swap with no follow on issues. I have been driving it daily since completion without incident.
1 Post
Engine: 2002 SS LS1
Thought I would share with everyone, I drove my car to South Carolina from Texas, about 1100 miles. It ran great and I had no problems, I also got about 29mpg at between 75-80mph.
Car: 92 Chevrolet Camaro RS
Engine: 3.1L V6
What are the rpms at in 6th gear at 75mph?? Excellent swap. If you dont mind sharing, whats the price tag? Where the pcm located? Did you buy the whole donor car?
1 Post
Engine: 2002 SS LS1
The Ecu is in the factory location in my dash thanks to my Speartech wiring harness. I say I guess I did everything for around $6000. I could have bought another car, or done something awsome to my old engine, but it really throws people for a loop when they find out I have an LS1.
Car: '89 Trans Am GTA
Engine: WAS 350 - now L92 (alum. 378/6.2L)
Transmission: WAS 700R4, now a built T56
Axle/Gears: 3.27 9-bolt
Re: Dyno Run
Yes, weight & drag have a significant effect on qtr-mile times & trap speeds, but my understanding is that a dyno just measures the power that's getting to the wheels...
(And yes, a Mustang dyno is generally considered to be more "accurate" or "real world" than a Dynojet, no argument there.)
1 Post
Engine: 2002 SS LS1
Re: Dyno Run
Not sure what you're getting at here - a vehicle's weight has nothing to do with how much power/torque the engine makes, nor does drag. If two LT1 drivetrains (just as an example) are configured identically, but one's in a Camaro, & the other's in an Impala SS, then they should put down near-identical numbers on the same dyno on the same day...
http://www.z06vette.com/forums/f55/m...dynojet-47063/
1 Post
Engine: 2002 SS LS1
man! I have an ls1 and t56 sitting next to my camaro! hmmmm.... its for the other Z tho.... maybe I could just get another one.... I think the girl would kill me but it almost seems like it would be worth it!
#42
1 Post
Engine: 2002 SS LS1
Here are a couple of interior shots.
The seats are from an 01 WS6 and have the six way power and dual lumber on both seats...
I have the window switches just sitting where the ashtray would normally be, the extra switch is for the line lock. The Monsoon stereo and console are from the same SS donor vehicle I got my engine from. The console is a direct swap. The Monson stereo actually hooked up to the factory '91 stereo wiring with no modification. The floor mat looks rough, but they are the factory original. I cant find any factory replacements, they all say, Camaro or Z28, I want ones that are made for my car (stupid cat hump) and that simply say GM at the top.
I need to clean it, I have just been so busy. Its funny, I actually used wall anchors to mount the radio pod. The pod is from an 86 or so Firebird. Other than needing to make a beauty plate for the front, the pod looks like it was meant to be there.
#44
1 Post
Engine: 2002 SS LS1
I added a 45 degree elbow to put the filter closer to the fender. Now I just need to build a cold air block off so the engine heat wont soak the filter.
#45
1 Post
Engine: 2002 SS LS1
Aeroforce Interceptor Gauge
Scan gauge that reads everything that my computer outputs. Also has a performance mode and data logger that records 60 seconds of data when wide open trottle is applied. The performance mode records 0-60, 1/8 and 1/4 mile. They say it has a .1 margin of error. I did 0-60 in 4.1, and the 1/4 in 13.2. Not bad for a stock LS1. I am going to take it to the track to see if the numbers are accurate.
#46
drools.....
::stares at LS1 and T56 in garage.... stares at 280z.... stares at the third gen.... and contemplates::
according to carpoint.com its 310hp for that year... not bad at all
#47
1 Post
Engine: 2002 SS LS1
My Nittos were thin, so I killed them, and bought new tires. Here is a link to the burnout video....
http://s241.photobucket.com/albums/f...t=MOV00133.flv
#48
Transmission: 4L80E
Man...I'll soon be there hopefully. Doing wiring now. yuck
#50
1 Post
Engine: 2002 SS LS1
My LS1 Vs. 2001 Corvette video
I think the black on top looks sinister. I've received allot of props on streetfire. It looked like poop with the clear coat coming off. I am of the mindset, go fast first then make it pretty. I dump alloted of cash on the swap, I am pacing myself. Besides, people really underestimate it as an old worn out TPI camaro....
I do however have another video, me racing a 2001 Corvette. I look pretty fast next to him, but once he learns to drive it, he has only had it for a few days, he should outrun me. If you guys have a Streetfire account, leave some comments on my videos.
2001 Corvette Vs. 1991 Z28 LS1
http://videos.streetfire.net/video/2...LS1_164007.htm
