5.3L "smog legal" ?
Old 05-20-2008, 06:13 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Axle/Gears: 3.42 LS1
5.3L "smog legal" ?
OK, every now and then I see 5.3L Tahoe engines for sale, we use Tahoes at work, they drive good, engine would be excellent in a lighter weight Camaro.
And here comes the issue(s)
1) It's not really smog legal to swap it into the Camaro, correct ? Because it's classified as a truck engine.
2) Do the Tahoe engines come with any smog equipment at all ?
3) To use on in the Camaro, could I use a wiring harrness, and intake manifold from a late Camaro ? (because the LS1 intake is not as high as the Tahoe one, which would give it away as a different engine)
4) If 3 is a yes, can you go into the ECM and change it so it'll work for a 5.3L engine rather than a "5.7" (346ci not 350 blah blah)
Why even asking this ? Because no way I can afford the entire LS1 package, but people sell 5.3L engines for the same price as LT1 engines. And those with LS1/LS6 engines sell their stock parts sometimes rather cheap, because they upgrade to aftermarket parts like FAST intake manifolds etc etc
Old 05-21-2008, 12:45 AM
five7kid's Avatar
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
5.3l = 323 ci, not 346. The 5.7l LSx engines are 346 ci, not 350.
It is not technically emissions-legal in a passenger car. Putting LS1 stuff on it would make it look more like an LS1, but the "motor change" inspector's job is to verify everything is from an emissions-certified application, and the one of first things he's going to check is the block/head casting info.
You'll also have to have dual cats, LSx evap system, and if memory serves, even an LSx transmission, etc.
You might get by with it (heard of a CA TGO member who got Vortec heads and a Super Ram, I believe it was, past an inspector - but that wasn't a "motor change" situation).
The only question you have to ask yourself is, "Do you feel lucky?"
Old 05-21-2008, 01:39 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Re: 5.3L "smog legal" ?
yeah the casting number thing is the tricky part
jaridjohn
10-05-2015 07:01 AM
wstephan96
09-25-2015 04:28 PM
Quick Reply: 5.3L "smog legal" ?
