Steam Pipe Bypass
Old 03-01-2009, 06:34 PM
88LT1Drop's Avatar
Car: 1988 Camaro Conv.
Engine: 96 LT1
Axle/Gears: 3:73's
Steam Pipe Bypass
how do i bypass the steam pipe coming out from underneath the throttle body? trying to hide or get rid of as many lines and hoses as possible for a cleaner look.
Old 03-01-2009, 07:11 PM
Aaron91RS's Avatar
Car: RS
Axle/Gears: 9" for the ladies
Re: Steam Pipe Bypass
http://www.team3rdgen.com/modules/3r...steam_tube.htm
Old 03-01-2009, 08:48 PM
88LT1Drop's Avatar
Engine: 96 LT1
Axle/Gears: 3:73's
is that the same for lt1s?? any other way of doing it?
Old 03-01-2009, 09:58 PM
3.1EyeCandy's Avatar
Car: 1987 GTA
Transmission: 4L60e
This is an ls1 as well - but another way of doing it. Might not accomplish your goals of reducing clutter though... Just some bent alluminum pipe and a little hose
Click to embiggen.
Old 03-02-2009, 04:35 PM
chevyowner02's Avatar
Car: 1992 camaro
Axle/Gears: 3:73
Put a 3/8 cap on the port off the tb. Run a new pice of hose off the steam tube up to the radiator. (pass side near the cap)
Old 03-02-2009, 05:25 PM
ssean92's Avatar
Car: sold
I don't run the steam tube..... plugged the hole in the back of the heads
Old 03-02-2009, 06:46 PM
Car: 1992 camaro
Axle/Gears: 3:73
Humm... thought you had to have but if ssean92 is working fine with out it there you go do away with it all together.
Old 03-06-2009, 06:48 PM
Kory-88Iroc 350 tpi's Avatar
Car: 88 Iroc
Engine: 94 lt1 modded
Transmission: t 56
I drilled and tapped the back of the waterpump under the thermostat for a 1/4" pipe thread. I used a 90 degree hose barb fitting and ran the hose to that. I have been running this set up for 8 years with no problems.
Kory
Old 03-06-2009, 07:37 PM
SheldonZ28's Avatar
Car: 89 IROC/05 RX8
Engine: LS1/LS1
Transmission: T56/T56
Axle/Gears: 3.42 GM/3.55 8.8
You MUST have a steam setup up top. You CAN plug the rear holes w/ blocks that came one all 03+ LSx motors, then theres a cross over across the front w/ a outlet you can run to the rad/top of the waterpump.
Old 03-07-2009, 12:05 AM
Firebat's Avatar
http://www.ls1tech.com/forums/lt1-lt...am-pipe-s.html
On the thread linked above, post #12 is kind of interesting about the 92 corvette LT1 water pump.
Old 03-07-2009, 06:29 AM
ssean92's Avatar
Car: sold
I pluged the steam tube on the back of my LT1 heads not LS1. I have no Idea about those. I just wanted to make clear that I have a LT!
$750 L98
11-07-2015 02:26 PM
LT1Formula
10-08-2015 08:34 PM
Quick Reply: Steam Pipe Bypass
