lt1 timing
Old 10-26-2010, 12:32 PM
sszcam's Avatar
Car: 00 ss 89 iroc lt1
Engine: ls1, lt1
Transmission: M6, auto
lt1 timing
Just finished the install on my LT1 in an 89 iroc. I never took the opti off but did put a new cam rockers lifters in the motor. The cam was installed by a mechanic I did the rest. My question is what sort of timing adjustments can be made or will the engine adjust that itself. I am having some backfiring out the intake. seemed to get a little better as I ran the car. Car doesnt seem to have much power either.
Old 10-26-2010, 01:01 PM
johnmcillwain's Avatar
Re: lt1 timing
It times itself the distributor will b very self explanatory on how to install. He might have the Cam a tooth out though.
Old 10-26-2010, 04:27 PM
1981LT1's Avatar
Car: 1981 Camaro; 1986 Z28
Engine: LT1; LT1
Transmission: 6 speed; 6 speed
Axle/Gears: 3.73; 3.42
Re: lt1 timing
You either need to readjust the valves or the cam is off. The distributor is extremely hard to put on the wrong way and there is no advance/retard like on carb cars.
Old 10-26-2010, 05:11 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Re: lt1 timing
You have to take the opti off to put a cam in the car, the opti itself will only go on one way (unless it's a '93-'94 I've heard of the splined ones being put on wrong).
Old 10-26-2010, 07:24 PM
torque_is_good's Avatar
Re: lt1 timing
yea, I liked that comment too considering the opti sits in front of the timing cover and is driven by the camshaft.
May i suggest www.lt1pcmtuning.com and capture datalogs and have Solomon tune it for you. You can't be running an LT1 with a non stock cam without having the tune changed.
Old 10-28-2010, 01:01 AM
sszcam's Avatar
Engine: ls1, lt1
Re: lt1 timing
If the cam was a tooth off would that affect the oil pressure gauge?
I have tried a couple diff sendiing units now but cant get a reading. I know there is pressure otherwise the motor would be junk by now.
Old 10-28-2010, 06:19 AM
Klortho's Avatar
Car: 1987 GTA
Re: lt1 timing
No
midge54
12-27-2019 04:14 PM
midge54
01-29-2017 07:00 PM
TheExaminer
08-19-2015 10:07 PM
sreZ28
08-14-2015 07:48 PM
Thirim
08-09-2015 06:19 PM
Quick Reply: lt1 timing
