Turbo LQ4 build. New Track Times & Video Added!!
#53
Car: 86 Camaro
Engine: 6.0L LQ4
Transmission: 4L80E
Axle/Gears: 9 inch, 3.50
Re: Turbo LQ4 build
I finally got everything in place good enough to run the car. Doing so always reveals a few minor problems, with the worst being a small oil leak, exhaust rattle, and some minor trimming needed on the fan shroud for the IAT snesor. I got the car out for a few hours the other day so i busted out the camera mount and got some video. Enjoy!
http://www.youtube.com/watch?v=Miiwoi-U-gY
#54
Car: 86 Trans Am,03 Yukon,92 Z28
Engine: 5.3, 5.3, lb9
Transmission: th350,4l60e,700r4
Axle/Gears: 3.73,3.73,2.73
Re: Turbo LQ4 build. Video Added!!
Heck yeah! Looks and sounds good!
#58
Car: 88 trans am 72 olds cutlass
Engine: soon to be 5.3 455 olds
Transmission: soon to be t-56 2004r
Axle/Gears: 3.23 3.73
Hey that road looks familiar , sounds awesome, i look forward to checking that thing out this summer.
#59
Car: 86 Camaro
Engine: 6.0L LQ4
Transmission: 4L80E
haha yeah thats the local "closed course"
Assuming this thing stays together ill be out a lot this summer hitting the strip and car shows.
#60
1 Post
Car: 1967 Firebird P.T.
Engine: LS3 4" Strkr 422ci
Transmission: MN12 6 speed
Axle/Gears: 3.73 8.5" 10 Bolt Eaton
SICK, i agree with 1ADans statement earlier an ill add to it...
This LS **** is more addictive than crack!
#62
Car: 86 Camaro
Engine: 6.0L LQ4
Transmission: 4L80E
Took a friend for a ride the other day and he had his GoPro camera so we shot a little video. Enjoy
http://www.youtube.com/watch?v=SZLCl...wUawwZH3kOnJI=
#63
i seen on the vid your 0-100 was 10 seconds spinning most of it but whats your 0-60 time ?
#64
Car: 86 Camaro
Engine: 6.0L LQ4
Transmission: 4L80E
Not sure on 0-60. I'll be going this spring for a dyno tune and turning the boost up a bit so once that's all done I'll be getting some track times. Can't wait
#66
Car: 86 Camaro
Engine: 6.0L LQ4
Transmission: 4L80E
I finally made it to the track over the weekend and got about 6 passes on the new setup. Started the day at the 5-6 psi of boost that i have been driving around on the street with. Then after some playing around decided to turn it up a bit to ~9psi. Here is the last and fastest slip of the day, I am 3513 and a buddy in his 02 corba spraying a 150 shot is in the other lane.
Noticed a couple issues:
The first couple runs, the car was only hitting about half boost in second gear only. It would start at full in 1st, drop to half in second and immediately jump back to full in 3rd. But the issue went away so not sure what to think.
Also the car was shifting into 4th by the end of the track, but it is most likely due to being on shorter street tires and spinning lots (ie higher mph through the traps).
Oh and this was on pure street tires not even a drag radial
#67
Re: Turbo LQ4 build. Track Times Added!!
good run, respectable 60' time on street tires, looks like he may have been reeling you in towards the bottom end.
#68
Car: 86 Camaro
Engine: 6.0L LQ4
Transmission: 4L80E
yeah he definately did, he got the win light on that one cus i was lazy at the tree...
#69
Car: 86 Camaro
Engine: 6.0L LQ4
Transmission: 4L80E
Sorry guys, iv been a bit lazy on updating this with times but iv been back to the track several times since my last post. I threw a set of slicks on so i could make good use of the transbrake. Here is the time slip from my best run yet, which was launching at 3-3500 on the transbrake, building about 5psi on the line, with the boost set to 10psi. My buddy also got the pass on video with his phone so ill throw up the link to that.
Left Lane (3573)
The video:
http://www.facebook.com/photo.php?v=3708568746521
Left Lane (3573)
The video:
#70
Car: 86 Camaro
Engine: 6.0L LQ4
Transmission: 4L80E
Re: Turbo LQ4 build. New Track Times & Video Added!!
Its been ages since iv updated but figured you guys might get a kick out of where the car has ended up. The last year with the car has gotten a little crazy!!! Upgraded the turbo to the CX racing GT45R 80mm and it makes some steam with the wick turned up! Also swapped the cam for a tick stage 1 turbo cam and did head studs and ls9 gaskets.
Here are the goods!!
Dyno run is on ~18psi with 112 octane. Remind you, this is a stock lq4 shortblock with rod bolts! And it has been boosted for 2 1/2 years now!!
Here are the 3 pulls I made. Lower power pull was 9 psi
Also have some track times to back it up. Only got to make one run at high boost becuase i need to "get my IHRA license and update my safety equipment" hehe.
#72
hopefully they weren't too stern at the slip booth!
that thing is moving out!
#73
Car: 86 Camaro
Engine: 6.0L LQ4
Transmission: 4L80E
Thanks guys. They weren't too hard on me. I really need some rear suspension work to get that 60 foot down and it should be bottom 9s easy. All that will probably wait until next winter because this winter will be spent on my nova project!
#75
Car: 1986
Transmission: t56
Axle/Gears: Auburn 3.73 posi moser axles
This is exactly what my hopes are for my car, only with the t56, nice build man. I can't believe the numbers.
#77
Car: 86 Camaro
Engine: 6.0L LQ4
Transmission: 4L80E
Re: Turbo LQ4 build. T72 to GT45 and now to S475
Well I've decided to dig this thread up from the dead AAAAAGAIN!!!
Its been a few years since I have posted any updates so I'll get everyone back up to speed. A few changes I have made with the car is the switch to e85 (including 1000cc injectors and a magnafuel 750 pump) and I added to my roll bar to make it a 10 point cage. Besides that, just tons of street miles and the occasional trip to the drag strip.
New fastest pass with the car was a 9.44 @147.9, this is on e85 and 20-22psi from the CXRacing gt45 80mm. Id say that turbo is tapped out at this point and didn't really pick up as much power after 18-20psi. I should also mention I am still running the same engine that I started with back in 2011, at this point this poor 6.0L has to have 100 track passes and 25k hard miles. I'm anxious to see how much is left in it!!
So that brings us to today.... the obvious next step is a t6 turbo. I picked up a Chinese knock off s475 (96mm turbine 1.32 a/r) with only some dyno time on it for 300 bucks so it will be perfect to get the car swapped over to a t6 setup and then make it super simple to bolt on any s400 turbo later on.
I'm starting completely from scratch on the hotside. The old t4 hotside that i built at the very beginning of this thread has held up surprisingly well over the years (besides a few cracks) but I have just out grown it. The plan now is to use down and forward truck manifolds (cut down and v banded of course) and do a true divided setup to try and get this turbo to spool within a reasonable amount of time.
So I'm just barely getting started and have only mounted the turbo so far using a 1/4" brace off the head but I wanted to post up early so you guys can follow along.
Quick fender video of the 9.44 pass
#78
COTM Editor
Received 1,855 Likes
Car: '89 Firebird
Engine: 7.0L
I love wicked street cars and you have one by any definition of the word! And I like it when people share here because it makes the site better.
#79
Car: 86 Camaro
Engine: 6.0L LQ4
Transmission: 4L80E
Decided to just create a new build thread for the T6 setup. Link below
https://www.thirdgen.org/forums/powe...ml#post6102250
#80
Car: 86 Camaro
Engine: 6.0L LQ4
Transmission: 4L80E
