Victor Jr hood clearance.
Old 10-31-2011, 12:13 AM
1badeagle's Avatar
Car: 1984 Formula ws6
Engine: 370 LSX
Transmission: 4L80E with a brake and 4500 Stall
Axle/Gears: Moser 9" 4.30 gear
Im getting ready to drop my 370 in my car. It has a victor junior with a 750 holley on top. Is there any way that this will fit under the stock power buldge hood on my formula? If not how big of a cowl do I need or can I use a ram air hood?Hope someone with a carbed lsx will chime in.Thanks,Dustin
Old 10-31-2011, 11:15 PM
Thridgen60's Avatar
Car: 86 Camaro
Engine: 6.0L LQ4
Transmission: 4L80E
Axle/Gears: 9 inch, 3.50
Re: Victor Jr hood clearance.
When i had a gm single plane on my camaro, i had a demon carb and a 4" air cleaner with either a 1" or 2" drop base and the front of the air cleaner lid was about a half inch from my 4" cowl hood. I never even attempted a stock hood with mine but i would say almost definitely not. I would bet you could get away with a 2" cowl and a short air cleaner.
Old 11-01-2011, 06:39 PM
1badeagle's Avatar
Engine: 370 LSX
That really blows since I just spent like 8-9 hours stripping the paint off my hood.
Old 11-05-2011, 10:37 AM
HP52TA's Avatar
Car: 89 WS6 TransAm
Engine: LQ408
Transmission: T56 Magnum
Axle/Gears: Strange S60, 4.10s
I am running a victor junior with an elbow on my current LS1 setup and am hoping to fit it all under a stock Transam hood. If it fits it will be tight, but looking across the fenders it looks promising. I haven't attempted the hood install yet, but I can get you some pictures and measurements of the elbow as comparisson for your carb install.
With the previous 406 SBC, I was running a 750 QFT carb (no choke) with a 68-72 corvette big block drop base and lid using a 3" filter. Without modifiying the fuel bowl vent tubes, I had about 1/2" of clearance between them and the filter lid. This filter setup cost around 11 hp on the dyno when we ran with/without filter assembly test runs. (on a 450 hp engine) This setup was all under the same stock Transam hood and only slightly touched the hood insulation at the very front of the filter.
I did a lot of searching for the lowest drop base I could find and this is the one I came up with.
http://www.yearone.com/serverfiles/f...ain2.asp?cat=Q
Direct link didn't work, so search for Part# ACB396. (14" open-style air cleaner base for 1965-1969 and 1972 models with big-block engine.)
ACB396 14" open-style air cleaner base for 1965-1969 and 1972 models with big-block engine.
Lid is Part # ACL396.
Old 11-10-2011, 12:12 AM
1badeagle's Avatar
Engine: 370 LSX
I hope it fits for you. Im running the power buldge hood, but the hump isnt directly in the middle, so I dont know that it will even fit with a drop base. I sure hope it does though, its a sick *** hood!!
Old 11-22-2011, 05:35 AM
1badeagle's Avatar
Engine: 370 LSX
Does everyone agree that a 3" harwood cowl hood will work on a victor junior setup with a drop base>?
Old 11-22-2011, 07:34 AM
HP52TA's Avatar
Car: 89 WS6 TransAm
Engine: LQ408
I just fitted my hood last night. It took a little modification of the internal support to provide ample clearance, but she fits with additional room to spare. I will get you some pics up tonight.
Old 11-22-2011, 10:54 PM
HP52TA's Avatar
Car: 89 WS6 TransAm
Engine: LQ408
Not sure what you will need for clearance above the manifold, but here is what my elbow added to the manifold height.
If you are planning to run a carb with a choke I am sure you will not be able to clear the stock hood with what I found in getting mine to fit under there. You can see the rest of the hood mods and fitment I did in my build thread in post #79.
https://www.thirdgen.org/forums/ltx-...ld-swap-2.html
Old 12-14-2011, 03:50 PM
1badeagle's Avatar
Engine: 370 LSX
Im positive after seeing those pics that I won't have any clearance. My setup is probably 4" taller than that of yours.
Old 12-14-2011, 07:26 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
that elbow will absolutely kill off power and torque to that motor. Unless its a boosted combo, I would do a 4150 style throttle body.
Old 12-14-2011, 08:01 PM
INTIMIDATOR Z's Avatar
Car: 1987 IROC
Engine: Turbo 293ci 4.8l
heres my victor jr. with a low pro elbow. i sat my strut tower bar on it the other day and it looks like itll almost fit perfect if i shaved a tiny bit out of it.
Old 12-20-2011, 04:53 AM
1badeagle's Avatar
Engine: 370 LSX
That means theres no way that a carb will fit with a air cleaner then.
91TTOPZ
Exterior Parts for Sale
09-20-2016 12:42 PM
dusterbd
09-29-2015 08:40 AM
Quick Reply: Victor Jr hood clearance.
