Lokar throttle cable; LS1 swap
Car: 88 Iroc
Engine: LM7
Transmission: TH 400
Axle/Gears: 12 bolt 3.91
What length cable is needed?
I'd like to order the black stainless cable, but that only comes in a 36" length. Is this long enough? XTC-1000LS1
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: Lokar throttle cable; LS1 swap
you cut them to length and that will be more than long enough
Car: 1984 Z28
stock ls1 throttle cable works as well and is a bit cheaper
Car: 1984 Camaro
Axle/Gears: Ford 9"/4.30
While I certainly understand this, I just gotta say it took me just a few minutes to remove, bend, and reinstall my pedal to work with the non traction control stock cable. If nothing else, grab a junkyard pedal and give it a shot...its a piece of cake.
1 Post
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
Got a stock line for dirt cheap and bent a pedla from a parts car I had and was done in 15min and didnt have to pay a insane price for something thats not needed right now like a lokar. Just my 2 cents
1 Post
Car: 1991 Camaro Z28
Engine: 2002 SS LS1
Transmission: 6 speed
Axle/Gears: Auburn 3.42
I have the lokar and love it. Looks trick too. Best pic I have right now.
1 Post
Car: 1998 Trans/Am, 1989 RS Camaro
Engine: LS1, LQ9 6.0
Transmission: 4L60E, 4L60E
Axle/Gears: 2.73, 2.73
I also whent with the ls1 cable non tc but i havent dropped it in yet so I cant comment on how it hooked up. Lokar is a nice cable tho.
COTM Editor
Received 1,855 Likes
Car: '89 Firebird
Engine: 7.0L
Neither the 4th gen cable or the Lokar cable are a direct fit. I don't know why people omit this information almost 100% of the time. Neither has the shape to snap into the slot in the firewall, and the Lokar is physically too big to clear the FAST 102 intake.
You will have a seamless fit and function if you merge the 3rd and 4th gen cables. Here is the non-hack way to do it (because there are lots of hack ways people have done it!)
https://www.thirdgen.org/forums/ltx-...ml#post5823889
I covered the cable install pretty good in my thread since I hadn't seen much info out there about it. Clear pics included.
Starts at post #27
https://www.thirdgen.org/forums/ltx-...-t56-swap.html
Starts at post #27
COTM Editor
Car: '89 Firebird
Engine: 7.0L
If you can't afford that, then maybe just attach a washer to the firewall and use the 4th gen cable.
The only good advice I can think of is to get yourself a heat gun and bench vice. These are both a lifetime buy and shop essentials. The heat gun is cheap. Bench vice is not, so yard sale it (they don't wear out).
A heat gun at Harbor Freight is like $10 with a coupon and a bench vice is a must have in your garage. I use mine all the time - paid for itself many times over.
9192camaro
16
02-03-2019 12:21 AM
LT1Formula
20
11-14-2015 12:02 AM
