Iroc LQ4, S480 turbo build
Old 11-04-2012, 05:42 PM
  #51
cprmn14's Avatar
Car: 91 RS
Engine: LTwon
Axle/Gears: Both
Re: Iroc LQ4, S480 turbo build
sub'd.
So the stealth pump is controlled by a toggle switch? Thats a good idea man, cant wait to see some numbers.
Old 11-04-2012, 08:34 PM
  #52
shawnc16's Avatar
Car: 86 IROC, 89 GTA
Engine: 350 blocks, both of em
Transmission: 700r4s
Axle/Gears: 10 bolt and 9 bolt, 3.73, 3.23
Not a toggle switch. It's a Hobbs switch. Pressure controlled at x amount of boost it completes in my case the ground circuit to turn the 2nd pump on. So it's a boost activated switch.
Lmoser610 (12-30-2019)
Old 11-04-2012, 09:42 PM
  #53
cprmn14's Avatar
Car: 91 RS
Engine: LTwon
Axle/Gears: Both
oh i got you now. thats awesome man, it would suck if one failed but at least you can feed that 50lb turbo. lol
Old 11-05-2012, 01:53 PM
  #54
shawnc16's Avatar
Yeah, that's always a possibility with anything.
Old 05-22-2013, 12:05 AM
  #55
shawnc16's Avatar
Well, I lost some interest in the build but things have been getting back on track. I bought a tig and some piping. Hope to get some good updates going.
Old 06-07-2013, 09:26 PM
  #56
shawnc16's Avatar
Work! Decided I needed to cut up my core support to be more functional.
1x1 square tube for the upper radiator mount. I did finish up the turbo mount as well but ended up needing to readjust for some clearance issues.
Old 06-09-2013, 08:44 AM
  #57
Bldgengineer's Avatar
Glad to see you're back on your project. I know how it is having to put our fun aside for a few months. I've been watching as I have a lq9 with a s480 I'm shoving in my T/A. My engine is still in the tear down phase but should be speeding up after I get back from vacation after the 4th of July.
Old 06-09-2013, 11:56 PM
  #58
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
Wow cant wait to see it done
Old 06-17-2013, 12:52 AM
  #59
shawnc16's Avatar
Not much to report. Brainstorming mostly. I'll be working on the intercooler mount next. Don't mind the wiring. It's a giant mess!
Got the ****** shoved outside for some spring cleaning in the garage.
Old 06-17-2013, 12:53 AM
  #60
shawnc16's Avatar
Wow we can't say mu ll et? Lol
Old 06-17-2013, 10:17 AM
  #61
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
no, it's due to some fueding that went one circa 2002, lol. i'd say someone could probably change that now, lol.
car is looking great shawn!
Old 06-17-2013, 12:02 PM
  #62
shawnc16's Avatar
Thanks Matt. I tried putting a parts list together today, it's pretty painful! Must work more overtime haha!
Old 06-17-2013, 01:59 PM
  #63
NemeSS-TyranT's Avatar
Car: 02 SS
Engine: 408 TT (1108rw-93/m1)6700rpm
Transmission: TH400(slipping)
Axle/Gears: 12bolt/3.42(whines😠)
car looks good w tt2.
have you considered using a2w intercooler?
progress looks good. roc on
Old 06-17-2013, 02:16 PM
  #64
lunati397's Avatar
Car: 2012 F350 lariot/1991 Camaro RS
Engine: Powerstroke/6.0
Transmission: 6R100/4L80e
Axle/Gears: 3.73/3.42
i have a A2W intercooler for sale give you a good price
Old 06-18-2013, 12:02 AM
  #65
shawnc16's Avatar
Thanks! The TT2's are coming off actually. No real plans on A2W. I've already got money invested in this setup and I think it'll work fine. We'll see how she does once I get the bugs worked out.
Old 06-20-2013, 02:23 PM
  #66
shawnc16's Avatar
Been working before and after work welding away. Passenger side is close
Old 06-26-2013, 08:07 PM
  #67
IrocZ'85's Avatar
Car: '85 IrocZ
cool build! Makes me wonder if I can fit a future MP76 in-front of my engine while only moving the stock radiator forward and not cutting up the core support...we shall see lol
keep up the great work!
Old 06-26-2013, 08:20 PM
  #68
shawnc16's Avatar
It'll fit no problem. The only reason I cut it up was because it looked funny with the short radiator. This turbo is massive compared to an MPT76. Thanks! Should have some updates this weekend. Waiting for UPS to deliver some goodies.
Old 06-26-2013, 08:47 PM
  #69
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: Strange 12 bolt 3.42
Looks good. What flexcoupler is that? Be careful with the ones that arent lined inside. The braided/weave steel can come undone and basically explode outward closing off the exhaust passage lol. It happened to my buddy and they werent sure why it happened or when, just couldnt figure out why power fell off up top. Eventually tore down to find it but by then it was to late. I think that extreme backpressure wiped the thrust bearing and may also lead to the trans failure. Ugly stuff
Old 06-26-2013, 08:50 PM
  #70
shawnc16's Avatar
Thanks, very familiar with the issue. These are lined. I bought them from zzp. I originally didn't want to use flex joints but I think it'll be a good decision once everything heats up.
Old 04-12-2014, 01:23 AM
  #71
shawnc16's Avatar
Updates! Finally! After working OT like a madman and surviving this crazy *** winter, the build is back on track somewhat. I'm still working crazy hours but the parts are pouring in. I made a few changes.
Edelbrock Pro Flow intake over the ls1 I had.
Ditched the stock ecu/harness for Holley HP EFI.
The hotside I built, I didn't really care for, too many bends. Started over.
Also bought a new 9" Housing and center section, and a driveshaft from MWC.
Underhood wiring is getting changed around as well as the A/C delete box being removed in favor of a heater/ A/C delete panel.
Couple pics of my progress.
The Merge I'm currently working on. Instead of 45's off the manifolds, I'm just going to go with 2 90's into the merge. Short and simple. Its getting heat wrapped as well.
Old 04-12-2014, 01:32 AM
  #72
shawnc16's Avatar
Rearend is a Moser unit with a backbrace welded on 35 spline axles. Yukon aluminum bolt through center w/ spool and 3.50 gear. 5/8th studs and strange brakes. Shouldn't have any issues with it!
Old 04-12-2014, 07:55 PM
  #73
shawnc16's Avatar
Small bits of work today. Painted the 9" housing. I planned on tacking up the rest of my hotside but realized I was short on 90 bends. That will get put on hold until next weekend. More to come tomorrow!
Old 04-13-2014, 04:01 PM
  #74
shawnc16's Avatar
Rearend found its way home this morning after setting the center section in place. I need to test fit my Spohn Drag Bar next which may mean modifying the back brace a little bit. We'll see. Next week I finally get a couple days off so I'm looking to make some better progress.
Old 04-13-2014, 08:59 PM
  #75
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Axle/Gears: 9 Inch w/ 3.55
Hey does that intake manifold clear the stock hood?
Old 04-13-2014, 09:19 PM
  #76
shawnc16's Avatar
I dont have a stock hood but I'd be willing to make an educated guess and say no. It sticks up quite a bit near the throttle body.
Old 04-13-2014, 09:33 PM
  #77
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Does it clear in the back?
Old 04-13-2014, 11:26 PM
  #78
shawnc16's Avatar
Its about 1/2" lower than the wiper cowl.
Old 04-24-2014, 11:59 PM
  #79
shawnc16's Avatar
Tac welded the hotside up. Fits pretty nice but, the turbo hangs lower than I would like. I bought a scavenge pump for the turbo drain.
Old 04-25-2014, 12:14 AM
  #80
shawnc16's Avatar
Got quite a bit accomplished over Easter weekend.
Tablet mount setup. I'll be running the Holley EFI OS on a Dell Tablet with Windows 8. Should help with the tuning process and keeping tabs on things.
DS seat and cover mounted.
AC/Heat Delete Panel installed
Rearend is just about finished up besides brake lines. These Strange brakes are pretty sweet!
Also got the TH350 out and the TH400 in. Spohn mount and Strange chromoly DS also ready to rock. Its getting pretty close
Old 04-25-2014, 12:38 AM
  #81
shawnc16's Avatar
Forgot to mention, I plan on fitting my new shifter in place of the megashifter which I hate!
Old 04-25-2014, 08:04 AM
  #82
AGearHead4life's Avatar
Car: 92 Camaro
Engine: LS 6.0 LQ4 + Turbo
Transmission: T56 6 Speed Manual
Axle/Gears: 4.11 For now
Looks great man! Awesome build!
Old 04-25-2014, 10:09 AM
  #83
woodside783's Avatar
Car: 2010 Camaro
Engine: 416 ls3 Mike Norris tuned
Transmission: rpm stage 5 tr6060
Axle/Gears: stock
Wow
Old 04-26-2014, 12:20 AM
  #84
shawnc16's Avatar
Thanks. Can't wait to get more work done this weekend. I wanna hear this thing run! Its been a 3-4 yr project.
Old 04-26-2014, 02:42 PM
  #85
cosmick's Avatar
Car: '86 Camaro, '94 Camaro, 3 others
Engine: LG4 ->L29, L32->LR4, L36, LG4, L31
Transmission: 700R-4, T5WC, 4L80E, SM465, 4L60E
Axle/Gears: 3.42, 3.23, WTB/WTT 2.93
I never thought cutting a core support could make for a cleaner result, but I sure like what you've managed!
Old 04-27-2014, 11:59 PM
  #86
shawnc16's Avatar
It opens up the engine bay quite a bit.
Old 04-28-2014, 12:21 AM
  #87
90camaro355rs's Avatar
Car: 72 nova/ 90 camaro rs,04 suburban
Engine: blown 327/ 355/306/355/5.3
Transmission: muncie 4 speed/T5/powerglide,4l80e
Axle/Gears: 342/411/456/ moser axles
looks good shawnc16, Im no turbo guy by any means, I do like following y'all anyways.
keep the pics coming.
Old 04-28-2014, 08:02 PM
  #88
shawnc16's Avatar
Thanks! I'd recommend you go forced inductions but, damn its expensive!
Old 04-28-2014, 08:11 PM
  #89
shawnc16's Avatar
Spent this weekend in the garage again, finished up my rear suspension, did some wiring, weight removal from behind the dash and lots of small odds and ends tied up. I didnt take many pics but here is what I have
I'll try to remember to take more pics next weekend.
Old 04-28-2014, 08:49 PM
  #90
I have a chevy 360 with a 6-71 blower with duel 750 double pumpers, that forced enough for ya! yes it was expensive as well!
Attached Thumbnails Iroc LQ4, S480 turbo build-3-3-2014-galaxy
Old 04-28-2014, 09:02 PM
  #91
shawnc16's Avatar
Hell yes! That's awesome! I would love to do that one day. Any idea what kinda power it makes?
Old 04-28-2014, 09:18 PM
  #92
well all on paper its turned up to push 10.4 lbs of boost its somewhere in the neighbor hood of 900 plus maybe 8 something to the rear wheels, its a full roller engine, msd electronics, 15.5 compression with boost, 9.1 just motor. I had to have a clutch made for it, kept blowing the others up. It doesn't move much, I have to run 114 plus octane or it detonates badly. It took me a year to build, wanted an 8-71 but my machinist said it wouldn't be proportioned right and look funny on a small block, so I opted for the 6-71.
Its in my 72 nova muncie 4 speed 10.5 rear end full spool, 456 gears moser axles with c clip eliminators.
Old 04-28-2014, 09:29 PM
  #93
like I said the numbers are just on paper, when I researched everything and did the numbers that's what I came up with, I have been asked to put it on a dyno and see exactly what it makes, me I am really not worried about it, I have a drag car that is where I make sure my numbers are correct, the Pontiac headed 406 pushes 863 hp with 813 to the rear wheels.
I have 255 70 15 rear tires, it will lite them up all the way to 4th if you can shift that fast. I put 12 miles on it last year. I have a 90 rs with a full roller 355 that I drive way more than the nova.
I really wanna put the blower in the Camaro. I really don't wanna cut the hood up for it to fit. The Camaro has a Strip Dominator high rise and has to have a cowl hood. I have issues with that as well, Kinda needs a filter on top to keep it clean though.
Old 04-29-2014, 08:23 PM
  #94
shawnc16's Avatar
Pretty cool! Hoping to make that kinda power with this setup but, the rods would likely bend. I'm probably going to build a 370 this coming winter to throw more power at it!
Old 04-29-2014, 08:54 PM
  #95
I tell ya I have built several engines over the years, I have a 306, callies 300 in crank, groden 6.200 long aluminum rods, BRC pistons should be 14.5 to 1 with 58 cc heads, I have brodix cylinder heads 53 cc chambers, 2.110 valves 6.83 6.47 lunati solid roller cam, tunnel ram intake, crane roller rockers 1.7, it will be a high winder when completed, I have a 355 with a stock crank eagle rods, brc 14.5 comp pistons with 58 cc heads Brodix heads from 306 will be swapped if I decide to run it, comp full roller cam 5.75 5.75 lift, stefs aluminum pan, intake I need to buy, comp solid roller lifters, comp roller rockers 1.52,
those 2 engines are spare, then I have a full roller 355, comp cams 580 575 lift, comp roller rockers, speed pro flat top pistons, sportsman II heads 202 intake 160 exhaust, strip dominator intake comp solid roller lifters, eagle crank, eagle rods, This engine has been together for 8 years now and is still as strong as the day it was built.
everything runs off msd box and dist.
it takes time, I have been racing for 20 years now and have a blast doing it, the blower is my first and my last, the power is unbelievable. as I am sure the turbo set up is as well. Just cant get past the excessive heat and all the tubes that have to be run.
Old 05-01-2014, 03:00 AM
  #96
RaverRacerX's Avatar
Car: 1989 Camaro RS
Engine: Ellis Juan
Transmission: t-56
thank god youre actually making use of the divided tang.
Old 05-01-2014, 03:55 PM
  #97
shawnc16's Avatar
Wouldn't have it any other way! If I did, I would knife edge the divider
Old 05-08-2014, 10:17 PM
  #98
shawnc16's Avatar
Pics
Old 05-08-2014, 10:20 PM
  #99
shawnc16's Avatar
Decided to run no intercooler to save some fab time. The hood stack idea is more of a joke than anything. I'm probably gonna first fire it with the stack just for grins. Work is getting done. Looking at a first fire next weekend.
Old 05-10-2014, 12:05 PM
  #100
89ROC-Z's Avatar
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
Looks awesome. Would you be able to ever make another set of them log manifolds? If so I'd be serious about picking up a set.
Quick Reply: Iroc LQ4, S480 turbo build
