Iroc LQ4, S480 turbo build
Old 07-10-2012, 09:01 PM
shawnc16's Avatar
Car: 86 IROC, 89 GTA
Engine: 350 blocks, both of em
Transmission: 700r4s
Axle/Gears: 10 bolt and 9 bolt, 3.73, 3.23
The TurboMu11et LQ4 S480 Build
Thought I'd show you guys how to stuff one of these massive turbo's in the engine bay without cutting out the core support. Trust me, it fits (snug)
The radiator is a griffin core 31x16, core support is stock, uncut. The turbo has about 1" on each side (radiator to water pump)
1" setback plates, stock engine mounts.
Old 07-11-2012, 09:05 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Re: Iroc LQ4, S480 turbo build
Ohnose, not another boosted LS LOL
Old 07-11-2012, 10:59 AM
robguitargod1's Avatar
Car: '91 LS6/T56/9"
Engine: LS6
Axle/Gears: Currie 9"/4.11, detroit truetrac
Goddamn does that look tight! Giggity....
Old 07-11-2012, 05:04 PM
RaverRacerX's Avatar
Car: 1989 Camaro RS
Engine: Ellis Juan
Transmission: t-56
thats a large turbo..
Old 07-11-2012, 10:08 PM
shawnc16's Avatar
Just a borg warner S480. They're pretty common and a lot cheaper than going with a garrett or precision turbo. It weighs 45 lbs though.
Old 07-14-2012, 05:15 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
One guy made 770 RWHP with a 4.8, spinning 7700. Just ARP bolts and a small cam.
Old 07-18-2012, 09:51 PM
Blownz28man's Avatar
Car: 92 25th anv z28
Engine: 346 TC78 Turbo
Transmission: 4L80E
Axle/Gears: 3.25 9"Nodular, Strange axles
Wow. I thought I was going to have a hard time mounting my lil TC78 there... No you'll have a hard time! Thats tight!
Old 08-28-2012, 10:13 PM
shawnc16's Avatar
Progress. Slow but the ball is rolling!
More pics in the album:
http://s30.photobucket.com/albums/c3...Turbo%20Build/
Old 08-29-2012, 06:31 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Very nice, I want to turbo something, just not easy with the tight fit in our cars. Keep up the good work.
Old 08-29-2012, 09:13 AM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
Suscribed! How you planning on getting the belt on and off?
Old 08-29-2012, 10:48 AM
shawnc16's Avatar
Its an alternator relocation kit. The alternator is mounted with a turnbuckle, similar to a march pulley kit. Modular turbo sells it.
Old 09-07-2012, 04:19 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
WOW! that turbo is huge! if im having trouble fitting my small turbo lol
Old 09-30-2012, 08:57 PM
shawnc16's Avatar
Finally got em finished up this weekend. Name:  AD65024F-7CA0-4C63-A632-2C4D26AA0E0A-4575-000001D9540E990A.jpg
Old 09-30-2012, 10:25 PM
86White_T/A305's Avatar
Car: 1987 TransAm Ttop
Engine: 2005 LQ4
Transmission: Ls1 T56
Axle/Gears: 3:42
very nice,subscribed
Old 10-01-2012, 09:32 PM
shawnc16's Avatar
Thanks! Lots to do and I'm hoping its ready in the spring.
Old 10-06-2012, 09:18 AM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
i want to do my radiator like that, even on my N/A motor just for the extra room, lol!
Old 10-13-2012, 05:55 PM
shawnc16's Avatar
Did some clocking of the turbo and found its final resting spot.
It should go about 3" lower without the board in there.
Old 10-13-2012, 05:57 PM
shawnc16's Avatar
Also finishing up my fuel system minus one fitting. For whatever reason one fitting had no threads.
Old 10-14-2012, 12:38 AM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
damn tight fit
Old 10-14-2012, 01:05 AM
shawnc16's Avatar
Actually it's not as bad as I had originally thought. There's enough room to tweak it if I need to.
Old 10-14-2012, 01:08 AM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
really where is the radiator gonna go?
Old 10-14-2012, 01:26 AM
gp90gta's Avatar
Car: 1990 GTA
I love the way you made the headers, what gauge did you use?
Old 10-14-2012, 01:29 AM
shawnc16's Avatar
The radiator is in there, right where the a/c condenser used to be. The manifolds are sch. 10 pipe
Old 10-14-2012, 01:43 AM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Oh okay, can't wait to see it done then. Im also doing a turbo 4.8 and cant even fit my t76 lol
Old 10-14-2012, 01:46 AM
shawnc16's Avatar
This is a massive turbo (weighs 45 lbs.) you should have no issue with a smaller unit. Rear mount battery and play around with the clocking of the turbo.
Old 10-14-2012, 02:00 AM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
yeah well the guy i bought the car off had a t76 godspeed so i bought a t76 turbonetics but won't fit.. giving me headaches now
Old 10-19-2012, 09:17 PM
shawnc16's Avatar
Thought I'd spice up the thread a little bit with some more pictures.
The car
Engine build
Also did the twin intank pump treatment. I had a walbro already so I strapped an aeromotive stealth 340 to it. The 340 will kick on with a hobbs switch.
Old 10-19-2012, 09:47 PM
mw66nova's Avatar
Engine: 7.0L
woohoo! love seeing progress! what does the clearance look like on the driver's side with that truck manifold?
Old 10-19-2012, 10:15 PM
shawnc16's Avatar
I think it fits pretty decent if you cut the flange off and weld on a v band. The passenger side wasn't good at all. That's why I opted to build a set to make it symmetrical.
Old 10-19-2012, 10:19 PM
mw66nova's Avatar
Engine: 7.0L
i'm disappointed the car got gfx...
Old 10-19-2012, 11:44 PM
shawnc16's Avatar
I didn't wanna steal your thunder.
Old 10-22-2012, 02:30 PM
ThirdGenDemon's Avatar
Car: 1986 Camaro
Engine: LS6
Transmission: Tick Stage 2 T56
Axle/Gears: Moser 12 Bolt
Nice! Im doing a 5.3 turbo, T56 swap on my 87 IROC. Can you post up some interior pics as well? Just curious what you got going on in there with the cage.
Old 10-22-2012, 02:33 PM
shawnc16's Avatar
I don't have too many pics of the interior. I'm going with kirkey pro drags
Old 10-22-2012, 02:39 PM
Car: 1986 Camaro
Engine: LS6
Keeping a drag seat in the passenger side? I have a set of drag seats with foam inserts. Im using one for driver and a stock fourth gen passenger seat. Well, thats the plan anyways lol. Have yet to procure a passenger seat. I'm working on getting the cage installed. What kind of power numbers are you shooting for? Weekend car?
Old 10-22-2012, 02:51 PM
shawnc16's Avatar
Yep keeping the seat there and picking up another one for the driver side. Not really sure on power but I have 8 lb springs in the gates to start with. I'll try 15 lb springs If I can get it done on gas, after that I'll have to bump to E85 and more boost.
Old 10-22-2012, 03:27 PM
Car: 1986 Camaro
Engine: LS6
What sort of cam are you running? Intake? Those engines are great for boost. Are you on LS1tech as well?
Old 10-22-2012, 03:42 PM
shawnc16's Avatar
It's a stock LQ4 with arp rod bolts, head studs, LS9 gaskets. Cam is a TU2 from speed inc. LS7 lifters, Texas speed pushrods and patriot gold extreme springs. I have an LS1 intake right now but I'm going with the Holley hi ram eventually. 80 lb. injectors, Holley rails w/ 8 an feed 6 return, Aeromotive regulator. One walbro 255 full time and a stealth 340 on a Hobbs switch when boosting.
Trans is a th400 w/ griner transbrake and I plan on a ptc converter. Ford 9" rear and and a 3.25 or 3.50 rear gear. I don't have a thread on tech but I am on there.
Old 10-22-2012, 06:15 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
sweet car as well wanna see this done
Old 10-23-2012, 09:18 AM
Car: 1986 Camaro
Engine: LS6
Well, I can see you building one hell of a car. Very nice setup. Keep us updated!
Old 10-23-2012, 11:58 AM
shawnc16's Avatar
Thanks. I'm trying to keeps some updates going. Lots of boring stuff going on right now.
Old 10-23-2012, 12:46 PM
Car: 1986 Camaro
Engine: LS6
Hey, I like boring details. Fill er up!
Old 10-25-2012, 06:58 AM
  #42
pmgm's Avatar
Nice car... I like how you built the headers....
Old 10-27-2012, 11:20 PM
  #43
shawnc16's Avatar
Small victories today. Got the turbo feed ready to go.
Also the fuel system is fully plumbed.
Old 10-28-2012, 08:20 AM
  #44
Car: 1986 Camaro
Engine: LS6
Looking nice dude! Keep em coming!
Old 11-01-2012, 10:32 PM
  #45
Kurtis2short's Avatar
Why did you choose to have the oil feed down by the filter instead of up top where the sensor goes
Old 11-02-2012, 01:20 AM
  #46
shawnc16's Avatar
Less clutter, I have my oil pressure gauge hooked up to the top. It'll be fine.
Old 11-03-2012, 11:31 AM
  #47
Car: 1986 Camaro
Engine: LS6
Any updates for us to drool over?
Old 11-03-2012, 11:44 AM
  #48
shawnc16's Avatar
Haven't had the motivation to get out there. It's been cold and gotta pay the bills.
Old 11-03-2012, 11:54 AM
  #49
Car: 1986 Camaro
Engine: LS6
Yeah, I hear ya man. I'm just sitting here on the forums, wishing I could work on mine...
Old 11-03-2012, 04:03 PM
  #50
shawnc16's Avatar
Doing some planning for the hot side.. I'll be making an order here soon. I have to figure out what I need. It's a matter of ordering just enough bends because 304ss isn't cheap!
Quick Reply: Iroc LQ4, S480 turbo build
