L98 to 6.0l LQ9 Swap 89 Iroc
First and foremost some play toys have to go....
Say bye bye to the C5
Here is the replacement toy.....................
Re: L98 to 6.0l LQ9 Swap 89 Iroc
There had been a visit from the post man when I got home last night....
LS1 Intake and fuel injectors scored from LS1tech 150.00 shipped...
I could have done some fab work on my own mounts but this is so much more easy..
Thats is one clean starting base of a car Should be a nice swap
Craigslist Score!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Fbody oil pan, windage tray and pickup tube. 100.00
Fbody Camaro 98-02 front accessories minus water pump and crank pulley. 400.00
And yes that does include every bolt and nut for oil pan and accessories!!!
Craigslist score number 2!!!!!!!!!!!!!!!!!!!!!!!!!!!
4.8 complete with harness and computer 300.00
This will replace the Lq9 in my SWB.
And from the same guy a cammed 5.3 with a Texas Speed .224 cam and Pac valve springs......... I post some pics after awhile.... 400.00
So I know what your thinking did I get screwed on the 5.3 since I was not able to verify the cam before the purchase?
Score!!!!!!!!!!!!!!
FYI the 5.3 is in great shape other than missing a couple of oil changes. New set of bearings, Hot Tank and it should be project ready!
Score!!!!!!!!!!!!!!
So I am thinking the LQ9 with a set of 243 heads and the above TSP cam should make for a fun ride..... I would love to go FI, just don't have the bones for it though...
Car: '91 LS6/T56/9"
Engine: LS6
Axle/Gears: Currie 9"/4.11, detroit truetrac
I bought a 4-post lift that ROCKS, but I wanna see/hear details on your 2-post asap!
Thanks!! I thought so also....
I will try to have the lift up this weekend. I will try to document the install process.
Life has slowed me down but I am back working on the swap.
Built 4l60e with 2500 stall.
LQ9 getting prepped for cam install.
Car: 1987 Z28
Engine: 2005 5.3L, LS6 Cam
Axle/Gears: DTS 9" 3.50 TrueTrac
Awesome, I am in your boat also. Just sold my 2000 FRC to get back into a 3rd gen and LS swap it...again...lol
Jay
Jay
I know this is mainly thirdgen cars but here is what I have been working on.
5.3 after I rebuilt it.
Some pics in the truck.
I have learned a few things since installing this turbo... Don't clock your turbos like this kids.
Oil return no more than 15° from vertical
And here are some pics of carnage.
This was the recent owner of the LQ9.
Goes with out saying I rolled the truck so no need for a replacement engine.
Ont he bright side of things it has speed the swap project for the camaro up!
Car: 92 GTA
Transmission: A-4
Nice work. When life happened I sold my 2007 C6 last Spring and picked up my 92 T/A that I'm swapping.
To:
To:
Car: 1992 RS Heritage Edition
Engine: LS6 Mut
Axle/Gears: Stock
If I may make a suggestion....Junk the ls1 intake and find an ls2 or ls6. Lq9 with a cam like yours that intake is going to rob you of a significant amount of power. Better runners, larger throttle body, etc..
Progress has been a little slow.
Most of last weekend was spent working on the wife's car getting it ready for Friday races.
I did get the K-Member finished up.
That is a really clean car you've got!
Have you thought about something other than the 2500rpm stall torque converter? A restalled 12" stocker won't do anything for you other than generate heat. You need more stall speed even for a stock setup.
#42
Progress still slow but I did manage to get a few things done.
Drilled and tapped hole for alternator.
And just a few shots of accessories. I still need to clean these up.
I also got one of the flanges welded on the manifold.
Weld looks like crap, I should have used the mig rather then tig.
