LS6 Swap for my canyon carving 87 RS
#52
Car: 87 RS Camaro
Engine: LS6
Transmission: Tremec 6 Speed
Axle/Gears: FAB 9, Floater, 370 True Trac
Re: LS6 Swap for my canyon carving 87 RS
Sway bar Housing 1.75 tube, can't rem the wall Thickness 30.00
Rectangle stock for tube mounts 15.00
Welding 20.00
Powder Coating 30.00
Speedway Engineering 608-49.1.43 Hollow 1 7/16 OD 217.47 ONE
Speedway Engineering 605A-125 Bushing, Nylon (2) 14.32 Each
Speedway Engineering 605C-125 Collar (2) 9.20 Each
Speedway Engineering 617-3-49 Arms, (2), 30 Degree 66.25 Each
Hardware, Hardened 15.00
Custom bends on the arms 110.00 for both
Zinc Plating, MIN lot cost $160 FREEBIE
Rod End w/ Rubber links (Spohn) 90.00 for a Pair
Looking like $600 Plusfor 1st time around on a one up deal, I could save money with multiples.
Welding 20.00
#54
Car: 87 RS Camaro
Engine: LS6
m me you number, I can share.
Dennis
Dennis
ambainb
04-25-2016 09:21 PM
