84 Camaro LS1 Swap - AC Compressor. PLEASE HELP
Car: 1984 Camaro Z28
Engine: 305 SB
Axle/Gears: 3.43
I'm sure you guys are tired of seeing these and I have been doing my homework on this common issue of AC Compressor clearance, but I haven't found any solutions tailor fitted to my particular problem.
Obviously, the compressor won't mount to the the stock location BUT I'm already running a UMI Tubular K-member with my set up and still having clearance issues. I am on a budget though and the Kwik Performance brackets on top of a new Compressor sort napalms my piggy bank. Maybe I'm just doing something wrong? Any insight is appreciated.
Thank you.
Thank you.
Car: 86 IROC-Z, 98 Z28
Engine: 370 LSx, LS1
Transmission: T56's
Axle/Gears: 3.73, 3.42
Re: 84 Camaro LS1 Swap - AC Compressor. PLEASE HELP
The UMI piece wasn't designed to accommodate the 4th gen ac compressor to mount in its stock location.
Engine: 305 SB
Axle/Gears: 3.43
Well, that's unfortunate. I take it my best is a relocation kit?
Transmission: T56's
I'm actually in the same boat as you with a current build, and I haven't really looked into a solution. Quick and easy way out would prolly be the relocation kit. Maybe a smaller compressor or another accessory drive that mounts it in another location? I honestly couldn't tell you.
Engine: 305 SB
Axle/Gears: 3.43
Car: 1983 Firebird SE
Engine: C5 LS1
Transmission: 6 speed
For anyone looking, the BMR K-member lets you use the 4th Gen compressor.
rh76camaro
08-15-2015 12:48 PM
