TPI to LT1 cooling lines
Car: 1981 Camaro; 1986 Z28
Engine: LT1; LT1
Transmission: 6 speed; 6 speed
Axle/Gears: 3.73; 3.42
I'm wondering how ya'll have configured your cooling systems with the LT1 swap. I'm not having any issues but i'm looking to make it look a little better. The factory used a hard metal line that ran along the frame rail and went strait to the radiator and routed the hoses differently. The LT1 doesn't use this so I'm curious what options are out there. Currently, i'm running hoses from my LT1 water pump to the heater core, with a T fitting that goes to the steam tube. Any pics would be great.
Car: 92 Firebird
Engine: Supercharged 6.0
Axle/Gears: 8.8 3.73
Re: TPI to LT1 cooling lines
You can use the 4th gen heater core hardlines for a cleaner look, but most swaps LT1 and LSx use common hose from the WP to heater core
Check the upper radiator port that used to be for the heater core. Some are threaded internally and accept a 3/8npt barb for the steam line
Sanjay
08-12-2015 03:41 PM
