95 LT1 383 GM hotcam FPR required?
Old 09-02-2015, 01:19 PM
Strick1's Avatar
Car: 92 Vette, 83 Camaro
Engine: 305 going to 95 LT1
Transmission: 5 speed going to T56 6 speed
Axle/Gears: 3.73 posi with disc brakes
I need to replace the fuel pressure regulator on the fuel rail. The engine has been bored and stroked and is cammed with a GM hot cam. I also stepped up the injectors to 32lbs. What fuel pressure will I need? Will the standard OEM FPR do the job? Or do I need an adjustable FPR?
Old 09-03-2015, 08:33 PM
Lonnie P's Avatar
Car: 91 Formula
Engine: 2012 LS9
Transmission: 4L80E
Axle/Gears: Strange 60 3.54:1
Re: 95 LT1 383 GM hotcam FPR required?
Factory pressure is fine, base pressure should be 43psi with vacuum line removed.
No need to get an adjustable.
You should correct the tune if necessary, not the fuel pressure.
Old 09-04-2015, 07:11 AM
Strick1's Avatar
After studying how the fuel injection system really works, all I need is 43.5psi on the rail and a good fuel pump. It will also need a PCM update to control the injectors and ignition and other things needed for my engine swap. Thanks for the reply.
UltRoadWarrior9
04-28-2020 10:39 PM
88SS6SPEED
11-11-2015 07:05 AM
L0tuS
10-04-2015 08:07 AM
WejaZ28
10-03-2015 07:38 PM
L0tuS
09-04-2015 11:16 PM
Quick Reply: 95 LT1 383 GM hotcam FPR required?
