Finally: Holley to produce LT and True Dual System
#151
COTM Editor
Received 1,855 Likes
Car: '89 Firebird
Engine: 7.0L
Re: Finally: Holley to produce LT and True Dual System
There are 3 holes that allow height adjustment of the torque arm. Lopping off the top hole would give clearance.
Edit: You may not need to cut it off. It might be enough to just never use the top mounting position. Hard to tell since I can't get it put in place.
#152
Got the crossmember today and did a fit up. Came with a hodgepodge of mismatched bolts and nuts, and not all were the right size.
I have a T56 and this is a NO GO without the Holley engine mounts. Crossmember runs into back of transmission. Not even close to being able to bolt it up to the car. We're talking total redo of the center section to make it fit.
Other problem is the torque arm bracket hits the reverse lockout solenoid so transmission cannot be lowered into place, even if I could get the crossmember bolted up. This has nothing to do with engine mounts. Crossmember simply is not compatible with the transmission.
* BMR k-member with LS1 engine stands
* QuickTime bellhousing
* LS1 F-body T56, Viper output shaft
#153
COTM Editor
Car: '89 Firebird
Engine: 7.0L
https://www.thirdgen.org/forums/ltx-...ml#post6000192
If you're going to build a Y-pipe to fit, then all you need to do is notch and box the back of the crossmember, and extend the slots forward. You don't actually need to shorten the torque arm bracket, just don't use the top mounting position.
#154
COTM Editor
Car: '89 Firebird
Engine: 7.0L
I'm glad you tackled this early on Qwktrip, as I knew sooner or later someone would want to try to use the crossmember on an LS/T56 swap using non-Hooker engine brackets. I've put together a mock-up of the crossmember and a 4th-gen F-body T56 extension housing how it sits using the Hooker engine brackets and I'd like to send them to you if you can PM me your email address...I would post them here but still can't get pictures to load. You are more than welcome to post them from here yourself if you want to.
You may see some differences with your set-up and the mock-up that will explain the differences better besides the fore/aft offset differences between the Hooker engine brackets and what you're using.
I'm sure we'll all learn something from your exercise.
#156
The problem may originate with the BMR K-member. I initially installed the LS1 with a 4L60E and noticed an engine setback issue. It moved the motor close enough to the firewall to physically not leave enough room for a factory dipstick tube. I had to use a Lokar flexible braided stainless one with a smaller diameter to get it to fit. Best guess is it moves the engine back about 1/4 to 1/2 inch and up by the same amount. This also forced the holes for the transmission mount to be slotted to allow the bolts to go into the transmission and through the crossmember into the mount.
The problem remained the same when I switched out the transmission to a T56 Magnum with a FBody tailhousing. I had to slot the new crossmember just a touch for the transmission mount bolt.
So people using motor mounts other than the BMR K-member might not have issues with the transmission crossmember if their mounts really do maintain factory engine position for a thirdgen. Yet another reason I'm considering modifying the original engine K Member and putting it back in.
#157
How bad is the interference? Got any pics?
I helped a friend swap an ls1/t56 into a miata a while back; and I remember having to remove the s0lenoid/ plug the hole for better trans tunnel clearance... So i guess if worst came to worse I could just remove it. I just hate the idea of going from 5th to reverse.
toddoky, did either of the cars you installed the system on have the reverse lockout in place?
Yes, the reverse lockout solenoid was in place during mock-up of the crossmember. I'm going to send photos of a mock-up I just did of the transmission parts in question and the crossmember to Qwktrip so he can compare them to what he's experiencing in his situation. There are no issues similar issues when using the crossmember with the Hooker engine brackets.
#159
COTM Editor
Car: '89 Firebird
Engine: 7.0L
I need to do myself a service and learn how to weld. I even have a gas MIG welder sitting in the garage. LOL!
#160
It is a good skill to have for sure. I think I'm fairly certain about the major cause of the non-compatibility you're experiencing between the crossmember and your BMR subframe. The Hooker engine brackets and crossmember work in tandem to place the LS crankshaft and transmission centerline axis in the same location as the stock SB engine and transmission was set up with. If the BMR subframe moves the engine up and/or back, then it will cause you to have to drop the tail of the transmission down from the stock position to enable the top of the trans to continue to clear the trans tunnel/firewall sheet metal. The only way to prevent that would be to cut open the tunnel and rebuild it around the transmission. I believe this to be the case in your situation due to the interference you are experiencing between the crossmember and the reverse lockout solenoid; there is no such interference when using the crossmember with the Hooker engine brackets, even with the torque arm bracket set to the highest set of holes as you see in my mock-up photos.
#161
COTM Editor
Car: '89 Firebird
Engine: 7.0L
That Hooker crossmember is definitely STOUT! I am still working out ways to use it without too much complexity.
I have two Y-pipes so I could cut one up to make fit. Or I could go back to stock K-member with Holley engine mounts. I have always thought the tubular K-member was puny in comparison and regretted buying it anyway.
#162
#163
COTM Editor
Car: '89 Firebird
Engine: 7.0L
It doesn't use mount plates like stock K-member. It has permanent engine stands.
http://www.bmrsuspension.com/?page=p...360&superpro=0
#164
#165
Even easier than I thought it looks like...as long as there was access for a MIG gun, I'd saw through the stand tubes and nudge the engine forward until you can get the rear of the trans case to clear the front edge of the crossmember. You're in the unfortunate position of having engine and transmission mounting components that were not designed to be compatible with each other and will need to modify one or the other to get them to play nice together.
#166
It would probably be easier to modify the stock K member for the AC compressor and pan clearance and put it back in than modify the tubular unit. That's my plan for some point during the next 12 months since I'm not happy with fitment or the tubular lower control arms it requires.
That method could also provide very desirable results.
#168
COTM Editor
Car: '89 Firebird
Engine: 7.0L
COTM Editor
Thanks man, you're telling me! Now I'm unsure what I'm gonna do with the rest of the exhaust... When it shows up to coat or not to coat. It should be pretty cool as I envision it, guess we will see
#172
Car: '91 LS6/T56/9"
Engine: LS6
Axle/Gears: Currie 9"/4.11, detroit truetrac
QwkTrip - You need to develop those welding skills! You'll suck at first, but you'll be awesome in no time!. Just like everything else in life, experience makes all the difference. Where are you at in IL? I'm on the northside of Chicago. I'd help ya out anytime if you're near me.
I'm right next to Strange Engineering too if that helps.
#173
1 Post
Car: 92 Z28
Axle/Gears: 3.73 10 bolt
Man those coated headers look good.
Has anyone actually mounted the trans cross member with the other style motor mounts ie. Spohn ect yet?
#174
Yes, QwkTrip attempted an installation of the crossmember with a BMR K-member with miserable results. I would suspect any installation not using the Hooker engine brackets is going to produce a similar experience.
#175
1 Post
Car: 92 Z28
The BMR K member is even more different. Regular swap mounts on stock k member should just shift the whole thing back to where the tail housing is in stock location. So however much a difference that is between normal and your motor mounts would be the only difference. Not sure if it will work or not. I would try it myself but I figure someone will get to it before I'm ready anyways.
#176
#178
#180
Car: 91 Firebird
Engine: 6.0
I'll PM Qwktrip and see if he'll ship his to me and I'll test fit it to my car.
Maybe this is something we could pass around to different members with different engine mounting options to see what works and what doesn't......
#181
I am this setup and am willing to try the Holley crossmember.
#183
#184
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
Think this would provide enough flow for a 390 SBC with a F1 Procharger?
#186
WOW. As much as I love these new parts, spending $3100 for all of them is a lot to swallow. Not sure that its geared towards the budget minded crowd though. Id factor in another $4K in parts to do a nice LS swap. Thats including a nice LS engine and fully rebuilt trans along with a few odds and ends that would be needed to properly do a nice clean swap.
#187
#188
#189
Has anyone installed the dual exhaust in a lowered car? Curious how the over the axle section clears with the car dropped on lowering springs.
#190
The system was specifically designed for such applications and provides plenty of clearance around all the rear suspension components.
#191
Car: Pontiac 89 GTA
Engine: 350 TPI 5.7L V8
Can you sale just the cat Back part?
Do you have a Header that work with this but for the L98 engine?
#192
The exhaust system in only sold in one configuration, which is to attach it directly to the Hooker LS swap headers. With that said, it can easily be modified,by someone with the proper skills, to connect to any other type/brand of headers. I've done one such install on a Holley employee's IROC and connected the system to set of Hooker 2210HKR headers that were on his car.
#194
That would depend on who you buy it from and whether you chose the 409ss or 304ss version of the system. You can find the part numbers for each on the Holley website and pricing for them as well if you chose to buy direct from Holley.
#195
I have the headers and exhaust, ordered the motor and trans mounts and oil pan.
Do I need to notch the factory k member for the ac compressor ?
#197
#198
My photo search was inconclusive in being able to make that determination for you; you will definitely have to remove the triangulated frame brace if one is present on your car.
#199
A realistic expectation would be around the 450-475HP level, although some users have installed the system on higher HP setups to take advantage of the overall ground clearance, sound and fitment benefits the system provides.
#200
Car: 1982 Z-28
Engine: 383
Transmission: Turbo 350
Axle/Gears: Det. Posi, Superior Axles, 3:73 G
Anyone with the dual exhaust kit installed have any sound clips? Overall opinion on the noise level? Thanks
