E-rod installed & Passed
Old 01-15-2016, 01:56 PM
  #51
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Re: E-rod installed
Around what this set you back. Since if I ever get sent to the referee I might as well do something like this.
Old 01-15-2016, 07:43 PM
  #52
yaj15's Avatar
Car: 1988 IROC-Z
Engine: L98 - full intake & exhaust boltons
Transmission: Bowtie 700r4, 2400 rpm stall
Axle/Gears: Borg-Warner 9bolt, 3.45 gears, posi
Re: E-rod installed
I've seen the erod LS3/4l65e connect and cruise kits go for around $10k-$11k. It's expensive but its a nice kit and don't have to do any outside tuning.
Old 01-15-2016, 08:14 PM
  #53
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Re: E-rod installed
I'm right under 11k, includes eng, trans, tcu, torque conv, eng/trans mounts.No reman stuff, if that matters.
Old 01-19-2016, 07:19 PM
  #54
COTM Editor
alan91z28's Avatar
Car: 91/89/85/82 Z28s, 88 TA, 88/88 SC
Engine: SBC and LS variations
Re: E-rod installed
Looks like a very nice install, great job
Did you take any pics of the underside... it would be interesting to see how the cats that they supply mounted up
Old 01-19-2016, 11:25 PM
  #55
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Re: E-rod installed
Holley blackheart Exh
dennisbernal91z (05-19-2021)
Old 01-20-2016, 12:09 AM
  #56
JayBoCC2's Avatar
Car: '88 trans am GTA
Engine: 5.7L 355 TPI L98
Axle/Gears: eaton posi 3.73 gears
Re: E-rod installed
Do you have part numbers on those manifolds and cats by any chance?
I'm struggling on exhaust for my ls swap.
Old 01-20-2016, 09:42 PM
  #57
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Re: E-rod installed
Cats come as an assembly, not individual units, LH-92225676, RH-92225677.The manifolds are from a 98 f-body.
Old 01-25-2016, 04:35 PM
  #58
On Probation
TPI TERR's Avatar
Car: 87 IROC-Z
Engine: LsX
Transmission: MN12 6speed
Axle/Gears: 3:42
Re: E-rod installed
nice swap. any videos of the vehicle?
iirc you can do a a case re learn with hp tuners.
i believe i had the same issue when i first did my swap , my code picked up a few misfires.
Old 01-25-2016, 10:04 PM
  #59
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Re: E-rod installed
Thanks, No vids though.No re-learn for me either, the ref would consider that a mod.
Old 01-25-2016, 10:42 PM
  #60
gsmarcano's Avatar
Car: Camaro
Engine: 350-Vortec-carbed
Transmission: 700-r4
Axle/Gears: stockola, right now anyhow
Re: E-rod installed
nice looking job, and love the gauges,.................
Old 01-26-2016, 10:48 AM
  #61
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Re: E-rod installed
Definitely, Speedhut are great gauges.
Old 01-26-2016, 12:07 PM
  #62
MY87LT's Avatar
Car: 1987 Camaro LT
Engine: LG4 w/ SLP headers & a 3" catback
Transmission: THM700R4 (Stock)
Axle/Gears: Stock 2.73 gears. No Posi
Re: E-rod installed
So did you ever take it to the state ref.?
Old 01-26-2016, 12:32 PM
  #63
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Re: E-rod installed
I haven't even finished the 500 mile break in, so it's gonna be a while before I do that.I'm in no hurry anyway.
Old 03-13-2016, 10:14 PM
  #64
yaj15's Avatar
Car: 1988 IROC-Z
Re: E-rod installed
Did you take your car to the state ref yet?
Old 03-14-2016, 01:44 PM
  #65
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Re: E-rod installed
No, but I will update this when I do.
Old 03-15-2016, 12:03 AM
  #66
Dartht33bagger's Avatar
Car: 1991 Z28
Engine: L31-R 350 w/ EBL P4
Re: E-rod installed
Really clean build. I'd love to do something like this someday. Emissions legal is not something you see often on this site sadly.
Do you have a list of all of the parts you used on the build by chance?
Old 03-15-2016, 11:35 PM
  #67
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Re: E-rod installed
4L65e trans w/ GM torque conv
Dakota digital cruise control
MSD Dynaforce starter
Hooker blackheart Exh
Spal Fans
Speedhut gauges
Slicone Intake sys
Hawks/Spohn- Trans X/Eng mounts
Racetornix 255 fuel pump
GM f-body oil pan kit
4th gen front accessories/fuel tank
C6 brks
That's all I can remember atm.
Old 03-20-2016, 08:51 PM
  #68
yaj15's Avatar
Car: 1988 IROC-Z
Re: E-rod installed
What are the part numbers for the Speedhut gauges you used?
Old 03-21-2016, 10:40 AM
  #69
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Re: E-rod installed
I don't remember & they're not printed on the invoice, but they are the legacy line.
Old 03-21-2016, 11:10 AM
  #70
yaj15's Avatar
Car: 1988 IROC-Z
Re: E-rod installed
Thanks. I'll probably swap out my gauges for some Speedhut's when I do my LS swap.
M3638 (06-20-2020)
Old 03-23-2016, 01:01 AM
  #71
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Re: E-rod installed
You'll like em, worth the money.
Old 05-21-2016, 12:23 AM
  #72
cosmick's Avatar
Car: '86 Camaro, '94 Camaro, 3 others
Engine: LG4 ->L29, L32->LR4, L36, LG4, L31
Transmission: 700R-4, T5WC, 4L80E, SM465, 4L60E
Axle/Gears: 3.42, 3.23, WTB/WTT 2.93
Re: E-rod installed
CARB has established that iron or aluminum doesn't matter for engine blocks, that different displacements within an engine family doesn't matter, and light truck sourced parts functionally identical to passenger car versions using the same engine family doesn't matter. Thank the old SBC V8 for those last 2.
The caveat is the tuning. So for LSx retrofit swaps, the 5.3L Monte has a useful tune, likewise the LS2 for LQ4s. But the 4.8 never came in any car, which is why mine is now in my S-10.
The ERod swap is worthless until it passes, and even then it's overpriced by around nine grand.
Old 07-09-2016, 08:53 PM
  #73
yaj15's Avatar
Car: 1988 IROC-Z
Re: E-rod installed
Have you had a chance to get your car signed off by the smog rep?
Still like the LS powerplant compared to your Gen 1 small block?
Old 07-09-2016, 10:00 PM
  #74
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Re: E-rod installed
Yep, it passed everything, except the visual.Due to the exhaust manifolds.Got an engineer at the Bar trying to get CARB to allow the OE manifold swap.Since its already in the GM manual.No guarantees though.
I'm also tryin to get the supplied manifolds to fit.Which means more modifying on the x-member.In the meantime, ive put 1600 plus trouble free miles on it.
Old 07-09-2016, 11:12 PM
  #75
yaj15's Avatar
Car: 1988 IROC-Z
Re: E-rod installed
Thats great! CARB needs to let it pass since it was a GM part.
Old 07-10-2016, 11:55 AM
  #76
COTM Editor
alan91z28's Avatar
Re: E-rod installed
just out of curiosity since i am not in CA (but thinking about doing one of these for a normal plate with no restrictions in PA), then to get your cert did you have to swap in the supplied manifolds which it sounds like you are working on before you can technically drive it on the street?
Old 07-10-2016, 12:04 PM
  #77
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Re: E-rod installed
The car has a current registration till feb-2017.So "technically" I can drive it legally right now.Ive got till feb to get this sorted or it goes into PNO.
This wouldn't be an issue anywhere else though, but ghod damm Ca.
Old 07-25-2016, 04:44 PM
  #78
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Re: E-rod installed & Passed
Success!
Old 07-25-2016, 04:47 PM
  #79
MY87LT's Avatar
Car: 1987 Camaro LT
Congrats man. I take it we will get to see your car at the meet on the 7th?
Old 07-25-2016, 04:58 PM
  #80
COTM Editor
alan91z28's Avatar
great job, fully CA certified and more powerful than original!
Old 07-25-2016, 05:22 PM
  #81
yaj15's Avatar
Car: 1988 IROC-Z
That's great! I'm glad you were able to get it smogged and fully legit. This state is nuts with all the stupid smog laws.
Old 07-25-2016, 05:55 PM
  #82
BrutalGTA's Avatar
Car: 1989 GTA
Engine: LS coming soon
Transmission: 80E coming soon
Axle/Gears: S60/35 Spline/S-Trac/3.73
So now that it's passed, can you tune it for more power?
Old 07-25-2016, 08:05 PM
  #83
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Thanks guys.
Yes, I was already going, but now even more so.
For any smog test.They will check the ECU for I/M readiness & other issues.So any mod to the ECU calibration is considered "tampered".
Old 07-25-2016, 08:12 PM
  #84
BrutalGTA's Avatar
Car: 1989 GTA
Wow, really? So it's got a global computer like the new camaros that save the last X amount of calibrations? What about changing for tire sizes. Will that hurt you as well?
Old 07-25-2016, 08:38 PM
  #85
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
I believe so, ECU/eng are based off a 2011 Camaro, just simpler.Theres no egr/air inj & evap are not supported.
The TCU lets you program tire size &/or final drive, if you change either of those or both.This way the ECU can compensate the changes.
Old 07-25-2016, 08:42 PM
  #86
yaj15's Avatar
Car: 1988 IROC-Z
If you get the chance I would be interested in seeing how much power reaches the tires. GM underrates most of the LS motors and they wake up with a tune. I would be interested in seeing how underrated that LS3 is in EROD tune.
Old 07-25-2016, 08:48 PM
  #87
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Its the same spec eng as in the 2011 Camaro, same HP even.Ive wondered how much too, but I suppose its underrated the same as GM did so in the Camaro.
Old 07-25-2016, 09:06 PM
  #88
BrutalGTA's Avatar
Car: 1989 GTA
So how long is that trans going to hold up to 430/424?? Still have 10bolt?
Old 07-25-2016, 09:27 PM
  #89
BrutalGTA's Avatar
Car: 1989 GTA
Wait a minute! 2011 spec camaro auto trans, you've got an L99 then not a LS3.
Old 07-25-2016, 10:53 PM
  #90
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
I didn't say anything about trans specs & the 4l65 will hold up better than the 4l60 does, even behind a ls1.
Old 07-25-2016, 11:30 PM
  #91
BrutalGTA's Avatar
Car: 1989 GTA
Yeah, but the ls1 doesn't have the ***** a 6.2 does! Any plans to upgrade rearend?
Old 07-25-2016, 11:54 PM
  #92
RamIt's Avatar
Car: 1984 z28
Engine: 93 LT1 350
Axle/Gears: 7.625" 28 spline 3.23
His info shows the 9 bolt. I'd run it till it broke.
Old 07-25-2016, 11:57 PM
  #93
yaj15's Avatar
Car: 1988 IROC-Z
9bolt should hold up fine on street tires. The manual cars are harder on rearends than the automatic cars are.
Old 07-26-2016, 12:43 AM
  #94
BrutalGTA's Avatar
Car: 1989 GTA
Duh, I didn't look to the left, only his signature. He outta be fine for a good while!
Old 07-26-2016, 10:32 AM
  #95
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Yes, 9 bolt.Been looking to upgrade for a while though.
Old 07-26-2016, 10:55 AM
  #96
BrutalGTA's Avatar
Car: 1989 GTA
I highly recommend Carl at Central Racing Products! 316-299-8427 His customer service rivals if not surpasses that of BBU! Plus he will give you the lowest price! Tell him your a member of LS1 tech or Chip sent ya!
Old 07-26-2016, 12:29 PM
  #97
Matt_91RSTPI's Avatar
So what exhaust manifolds did you end up using to finally pass?
Old 07-26-2016, 02:34 PM
  #98
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
The ones supplied with the e-rod.
Old 11-30-2016, 10:07 PM
  #99
yaj15's Avatar
Car: 1988 IROC-Z
Have any video's of the car driving?
Old 12-01-2016, 08:44 AM
  #100
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Wow nice job passing through the cali BS, you build one awesome car that you can just drive and enjoy in all 50 states.
Quick Reply: E-rod installed & Passed
