6.0 getting boosted (A&A style) pic heavy
Car: 1987 Formula 350
Engine: 6.0 boost and smak
Transmission: 4l80e
Axle/Gears: 9bolt 3.27
So my low 11's slips were getting boring (N20). So I desided to go with a Centrifugal supercharger to start with because I found a great deal on a CCW V-2, never used.
Here is the swap.
How she was, dirty but you get the Idea.
disassembly
Here is the swap.
disassembly
Transmission: 4l80e
Re: 6.0 getting boosted (A&A style) pic heavy
A&A adjustable tensioner
Bracket test fit
Transmission: 4l80e
A&A bracket test fit with HD tensioner
another angle
Transmission: 4l80e
Supercharger Test hung, F-body Crank pulley removed, F-body alt removed
Ugly TB removed and F-body Power steering removed
Transmission: 4l80e
last f-body bracket removed. Water pump with stay.
Vette ACC bracket test fit
Transmission: 4l80e
Corvette Crank Pulley installed. Drilled crank for pinning
Transmission: 4l80e
Oil Return. (5/8npt to barb)
Pin and ARP crank bolt installed
Transmission: 4l80e
Oil supply line. <br/>Copper Alloy 3/16 line, 37deg flare with stainless steel tube nut and sleeve. <br/><br/>Oil cooler block off was drilled and taped to 1/4npt. A 1/4npt to -3an
-3an copper alloy supply line connected to supercharger
Transmission: 4l80e
I could stand the ugly corroded throttle body so I gave it a quick polish. <br/><br/>The truck 140amp alt needed to have and extra hole added to the vette acc bracket
Transmission: 4l80e
A2A intercooler showed up, with the 3" tubing kit from csracing
Another teardown, for spring upgrade. PAC 18s https://amzn.to/2NQvNkp
Transmission: 4l80e
Transmission: 4l80e
plate style spring compressor https://amzn.to/2mLUSRV
Springs installed and a fresh sanding and painting of the valve covers
Transmission: 4l80e
I decided to paint the fuel rails too... I like it
ACC bracket installed. you can see the extra hole for the lower hole, for the alt.
Transmission: 4l80e
Corvette power steering pump installed
I got excited and slapped everything on. Since I had so many test fitments it goes on in a short time
Transmission: 4l80e
I decided I had enough with the damn Lokar 4l80e dipstick, so I bought another with a locking dipstick.... way better. https://amzn.to/2AedcN1
Locar crap vs locking dip
while the header was out, I chose to heat wrap the header, these things put off some serious heat https://amzn.to/2LBdX7B
Transmission: 4l80e
thanks, I am working on tuning at the moment. I am using GTP injectors around 40lbers at 58psi.
But I think my 255lph fuel pump is not going to cut it.
Transmission: 4l80e
Thank You,
it is a drill bit guide, and a 1.4 inch dowel. I use an arp crank bolt though
Transmission: 4l80e
Question for anyone? What is the limit of a Walbro 255 fuel pump?
that is what I have in the tank. I am thinking I will need a 340-400lph.
What do you guys think?
Transmission: 4l80e
Well tuning is getting in the ball part.
with LTFT in about the +/- 3 range in most of the under 100kpa area. I did a few WOT tests. @ PE in boost of 1.25 up to 175kpa. I was seeing 12.3-5 afr's.
Increased the PE in boost up to 175kpa to 1.50 resulted in 10.6-10.8 AFR. (injectors and pump are OK so far)
I am getting just under 6psi with my 3.6" pulley 141kpa max @5800 (5.8psi).
I have a 3.4" A&A pulley that I will tryout this week.
P.S. I think I am going to need a brake upgrade...
Transmission: 4l80e
A good view of the intercooler was requested
glimps of the BOV under nose.
Transmission: 4l80e
I installed the 3.4" pulley and that resulted in 154kpa at 6100rpm. (7.8psi)
11.0 afr @ 14deg of timing advanced on 93 pump gas, zero knock
The intake temps are great at 75 degrees, with 70degree temps outside.....
I would like those boost number sooner, so maybe a 3.2" pulley is needed. Maybe after a trip to the track.
I have to re-plumb the nitrous system now.
Car: 92 Firebird
Engine: Supercharged 6.0
Axle/Gears: 8.8 3.73
Looks nice
Id pull that pinched off EGR tube and replace it with an expanding rubber plug for a better seal. The EGR tube didnt seal that great NA, cant imagine all of youyr boost is contained by it now
Also, look to an idler reinforcement bracket. C5/6 accessory brackets are notorious for snapping the lower idler off with a SC
Transmission: 4l80e
If you look at a few of the later pics and the video clip, you can see I did. With a billet aluminum pc. I thought the same thing.
better yet here is a few better shots... https://amzn.to/2LsSEWf
Car: 1986 IROC-Z
Engine: LS1-ish
Transmission: T56 stage II
Axle/Gears: S60 4:10's
Nice setup. Ive been looking at doing this exact bracket for a procharger. Would love to see more of this and get more details.
Transmission: 4l80e
What else would you like to know? Happy to help!
Car: 1985 Camaro
Engine: 5.3
Transmission: 4L80e
Axle/Gears: 3.42 10 bolt
Hey I got a few questions.
How was the fitment for the Allstar dipstick?
Did you get the corvette ps pump for clearance or is there some sort of advantage?
Did you ever up the boost and is this a stock internals engine?
Thanks for all the great info.
Transmission: 4l80e
- Fitment of the Allstar was pretty good, slight bending but much much better to fill and check
- A&A sc bracket is designed for a C5 so accessories should be corvette
- boost is at 9-10ish at 6000rpm, with a 3.4 pulley
- Stock LQ4 with Pac springs and sloppy cam.
breathment
08-09-2002 11:51 PM
breathment
03-26-2002 12:20 AM
