LS1 fuel tank question.
Old 12-18-2016, 01:17 PM
Dodgeman79's Avatar
Car: 86 Z28 Camaro
Engine: 5.7 Vortec
So I will be doing a LS1 swap here very soon. And I'm getting everything that I can think of bought and ready so once I start it's all there. So my question is. Is a 99 V6 fuel tank the same as the LS1 tanks? I know the pumps are different but how about the actual tanks? I have read pages and pages and no one ever answers that questions they just guess.
Old 12-18-2016, 06:54 PM
Chopski's Avatar
Car: 1989 IROC
Axle/Gears: 3:42
Re: LS1 fuel tank question.
They are the same part number through GM.
Old 02-26-2017, 12:10 AM
Dodgeman79's Avatar
Car: 86 Z28 Camaro
Engine: 5.7 Vortec
Ok so a few questions I hope you guys know. I'm having a harness made by pocket. And I've done a 4th gen dash so I'm running a 4th gen gauge cluster is there a way I can wire up the perge valve and tank preasure? That way my gas tank is working the way it's suppose to
Old 03-07-2017, 07:09 AM
Dodgeman79's Avatar
Car: 86 Z28 Camaro
Engine: 5.7 Vortec
Anyone?
Old 03-09-2017, 02:42 PM
five7kid's Avatar
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Yes.
Old 03-09-2017, 02:43 PM
Dodgeman79's Avatar
Car: 86 Z28 Camaro
Engine: 5.7 Vortec
Originally Posted by five7kid
Yes.
could you expand on that?
Old 03-09-2017, 02:56 PM
five7kid's Avatar
Engine: LS1/LQ4
You hook up the purge and tank pressure wires to the proper ECM wires/pins.
Old 03-09-2017, 03:02 PM
Dodgeman79's Avatar
Car: 86 Z28 Camaro
Engine: 5.7 Vortec
That's it? I thought there was EGR stuff involved. That's easy enough.
Old 03-09-2017, 04:12 PM
five7kid's Avatar
Engine: LS1/LQ4
EGR is in the engine harness. The engine-mounted purge solenoid is also in the engine harness.
It's been a few years, and I didn't hook it all up when I used a 4th gen LS1 tank, so I don't recall what all goes to the tank other than the pump power, fuel level signal, and tank pressure signal. Seems like there is something else, but I'm not sure about that.
Old 03-09-2017, 06:26 PM
Dodgeman79's Avatar
Car: 86 Z28 Camaro
Engine: 5.7 Vortec
I know a 2001-2 didn't have EGR so would it just be the purge solenoid up at the engine ? The rest would be at the tank already
Old 03-14-2017, 10:26 AM
five7kid's Avatar
Engine: LS1/LQ4
You didn't say what year LS1 you were talking about. And you brought up EGR, thinking it related to the purge system. But, you are correct, '01-'02 did not have EGR (and also had the better LS6 intake manifold).
The purge solenoid on the engine has the wiring built into the engine harness, and goes to the PCM. No rewiring required there. You will need whatever connections that go to the fuel tank, as those are not part of the engine harness (as I recall - should be in a connector that goes to the chassis harness).
Old 03-14-2017, 09:16 PM
Dodgeman79's Avatar
Car: 86 Z28 Camaro
Engine: 5.7 Vortec
That's what I was thinking but I had a guy on a other site arguing that you also needed to use the 4th gen BCM and I didn't think that was right.
Old 03-15-2017, 12:13 PM
five7kid's Avatar
Engine: LS1/LQ4
http://mrk-motorsports.com/pdf/99-02...%20Pinouts.pdf
http://teamzr1.com/pcmecm/99pinpcm.html
Blue connector:
Pin 46 - 5 Volt Reference (Fuel Tank Pressure Sensor) (Factory)
Red connector:
Pin 34 - EVAP Canister Purge Solenoid Control
Pin 45 - EVAP Canister Vent Solenoid Control
Pin 54 - Fuel Level Sensor Signal (Factory)
Pin 64 - Fuel Tank Pressure Sensor Signal (Factory)
<10 minutes of searching there.
Old 03-15-2017, 12:59 PM
Dodgeman79's Avatar
Car: 86 Z28 Camaro
Engine: 5.7 Vortec
I appreciate you spending you're time to help
