Just making sure my information is correct.
Car: 86 Z28 Camaro
Engine: 5.7 Vortec
OK so I will be doing a LS swap as soon as I can find what I want. I have read for hours on this and there is a lot of information that isn't perfectly clear or confusing. So here's my questions I want a 6.0 LQ4 block. From what I have read the early model 6.0s used a different crank and won't work.so I need a 2001-2004. Would 2005 work?
Also once I get my motor the LS1 stuff bolts up to it expect the alternator and you have to drill out and tap 1 hole is this correct?
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: Just making sure my information is correct.
The first year of the LQ4 had the longer crank hub. 2005 would be fine. Also, you are correct on the accessories as well.
Car: 86 Z28 Camaro
Engine: 5.7 Vortec
What's a good harness company? I was going to use pocket but I can't get him to return a message. Don't think he's on much anymore.
I'm having the engine rebuilt. Since it will be apart anyway I was going to put rods and pistons from a LQ9 in it. Those are the same motor besides that correct? And anyone have any experience with what cams do good with these motors. I have been reading a lot on them but would like to talk to someone who has done one
Car: 1984 Z28
Engine: LG4 305/4bbl for now
Transmission: 5-Speed
Axle/Gears: 3.23 Posi
I have a 6.0L with trickflow heads, big cam, wiring harness and computer for sale in Mobile Alabama. lacking exhaust, intake and oil pan.
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
The LQ9 did indeed have different rods and pistons however, if your LQ4 is from 2005 it should have the same rods (Gen IV). If it is a good running core, there isn't really any need to change pistons, no less with another OEM one. Milling the heads to bump the compression is cheaper than installing new pistons to give you some of that compression back.
Asking about camshafts is sorta asking what is the meaning of life. There are a bazillion variables. Your best bet is to read up on LS1tech.com, paying attention to the dyno and results section, to see what type of combo's yield which type of results.
Things that need to be answered before selecting a cam:
Power goals
Static Compression Ratio
What heads, flow, quench, etc
What RPM band do you drive in
Vehicle weight
Auto or Manual Trans
Other mods on engine (headers, intake, etc)
Car: 86 Z28 Camaro
Engine: 5.7 Vortec
You are right I should have been more clear with that.
I have been around old 350s but know nothing about these LS motors so I'm having to learn everything.
I'm wanting 400hP. Not going to be a drag car just a fun daily driver that me my wife and kids can just go cruiz in but I want to be able to have some fun with it.
Things that will for sure happen will be the flat top pistons instead of the dish pistons that came in the LQ4s except 2005 from what you say and that would be great! Hawks long tube headers and for heads I'm not sure yet. I keep reading of some factory heads that do pretty good. The stock heads. 317 if I remember right seem like a good head but I don't think I will get the HP I'm wanting with those.
I'm on page 17 on the engine build section of this site so I'm learning slowly lol.
What I know now is I want a 6.0 iron block and have to get a 99-2002 LS1 wiring harness and PCM. Use a LS1 oil pan splash pan and sump. I have a 4th Gen fuel tank so I will use the factory pump for fuel.
I'm really wanting to find a 6.0 with high Mikes and rebuild it. The last motor I had I was told was rebuilt and saw the rebuild sheet but right after installing it broke a rod and destroyed the block. The builder I took it to said a bunch of the rods were bent so apparently the guy that rebuilt it didn't know what he was doing or was trying to save money and use bad rods. So that's why I want to rebuild it so I know 100% it's good and I can see the work.
Last edited by Dodgeman79; 01-10-2017 at 09:46 AM. Reason: I was stupid and hit the wrong button
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Car: 86 Z28 Camaro
Engine: 5.7 Vortec
The reason I'm not to worried about changing pistons is I was talking to the engine builder I want to use and he quoted 3k for a full rebuild of a 6.0 and he has to buy new pistons anyway so he said that wouldn't really change the cost any. The new rods would but he would just add that to the build. I know 400 isn't that much I would even be completely fine with 450. The reason I don't want high horsepower is I want it to be good and dependable.
On the budget. Yes and no. I wont spend 10k on a motor but I want this done completely right so if it takes a few extra weeks to afford what I need then that is what I will do. I'm not going to rush this project.
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
I would contact Phil at Advanced Inductions and send him your 317's. He can pair a cam with it and then you can give your cam to your shop to install and degree. Since you will be doing a total rebuild, make sure you don't skimp on the small things. New timing set, oil pump, etc etc.
