fuel pump wire
Re: fuel pump wire
Racetronix hotwire kit is a simple upgrade and will supply plenty of current to carry your pump.
COTM Editor
Received 1,855 Likes
Car: '89 Firebird
Engine: 7.0L
Re: fuel pump wire
The 4th gen Racetronix kit is designed to be inserted right in the middle of the 4th gen vehicle harness. It will plug into the fuel tank side but you'll still have to do a little work to change connectors to plug into the 3rd gen vehicle harness. The following link shows you how the Racetronix wiring is laid out. You can use that info to decide how you want to proceed.
https://www.thirdgen.org/forums/ltx-...ml#post5825643
Re: fuel pump wire
I have the 2000 Camaro plastic fuel tank installed. So, I just run the Racetronix wire harness from the pump to the engine bay? Also, do I buy the Racetronix kit for a 99-02 Camaro LS1? I've been reading a few threads, and I think I have to do something different with the fuel level sending unit wiring.
QwkTrip
01-21-2024 09:29 PM
QwkTrip
LSX and LTX Parts
50
09-15-2023 01:27 PM
Leon82
07-29-2022 11:21 AM
