t56 clutch master cylinder swap
hi, i used the adjustable clutch master cylinder from hawks third gen and it dosent fit with 4th gen pedal set, its to close to the wheel fender, so i called them and they said i have to hammer the fender!!!
anyone can help in this issue ?
Car: 91Firebird Formula
Engine: 5.0 TBI / Now LS1
Transmission: Auto / Now T56 with stage 2 monster
Axle/Gears: 4/10
Re: t56 clutch master cylinder swap
I bought the one for 98-02 LS1 and it did require a little fender manipulation to get it to fit but nothing major. it seems to be a nice piece.
COTM Editor
Received 1,855 Likes
Car: '89 Firebird
Engine: 7.0L
COTM Editor
it will fit without issue if the holes are in the right spot or at most very little massaging... see post #12 in the thread below for an example
https://www.thirdgen.org/forums/engi...50-vortec.html
