New Member 1986 Z28
Old 02-20-2013, 10:16 AM
  #51
KuroNeko's Avatar
Car: 1986 Firebird, 1992 camaro
Engine: 79' 350, 89 305
Transmission: TH400, 700r4
Re: New Member 1986 Z28
who needs A/C when you have windows that go down? seriously... my camaro's A/C needs charged and my firebird doesnt have it
Old 02-23-2013, 08:12 PM
  #52
Tyler1986's Avatar
man this is making me jelly. this is what i wanna do with my 86 since it recently caught fire and the wiring is crap anyway along with the motor needing cleaned and stuff id like to repaint my engine bay if i had all the tools / help to do this itd be getting done right now good luck on ur project bud i read the entire thread
Old 02-23-2013, 10:29 PM
  #53
Psychoz28's Avatar
Car: 1984 Z28 / 2002 Z06
Engine: 350 New Crate / LS6
Transmission: T5 / M12
Axle/Gears: 3.73 / 3.42
Look very ncie! Love this color combo!
Old 02-24-2013, 03:33 AM
  #54
khulsebus's Avatar
Car: '89 Camaro
Transmission: 4L65/70E
Axle/Gears: 9 Inch, 3.70 gears
I like the car, and you remind me of myself quite a few years ago. In high school I had a '85 T/A, and then in college I had a '91 RS. One thing that I regret doing to the RS though was taking the whole HVAC system out. I used to say the same thing, it has two windows, but it got old carrying a rag in the car to wipe the window when it fogged up. I wish that I would have just installed the non-ac box instead. Just food for thought, it's your car, build it the way that makes you happy.
Old 02-25-2013, 03:42 PM
  #55
street/stripZ28's Avatar
Car: 1986 Camaro Z28
Engine: 305 stock, 355 on the way
Transmission: 700R-4
Axle/Gears: 2.73 stock, 12-bolt with 3.90s soon
Thanks guys, I did go ahead and get a steel non-ac box(score from a friend) and a non AC blower motor from an S10(junkyard score) they will come up later in the build! So I will have heat/defrost..
Ready to go get washed...
It was freezing!
Old 02-25-2013, 03:50 PM
  #56
Got it pretty clean
Headed home...I HATE seeing it on a trailer!
Back it the garage, time to start smoothing!
The first thing I wanted to do was clean up where the battery box/canister mount met the frame rails....Got it scuffed up and Dad started welding
http://i1273.photobucket.com/albums/...pse5c99d40.jpg[/IMG]
Old 03-01-2013, 07:50 AM
  #57
khulsebus's Avatar
Car: '89 Camaro
looks good, take your time patching all of the holes and smoothing them out and it will look amazing when you are done. under the hood is the easiest place to learn bodywork, most of your mistakes will be hidden by the motor once it's in. glad to hear you picked up the non-ac box.
Old 03-01-2013, 10:11 AM
  #58
Next up was the inner fenders...stated removing paint
Then cleaned up the fire wall
about ready to start filling holes
Old 03-04-2013, 09:55 PM
  #59
Got the edges blended on the fenders
I really wanted to round the corners on core support/fenders so out came the grinder!
Old 03-04-2013, 10:11 PM
  #60
Cut, ready for final welding/sanding
Old 03-04-2013, 10:37 PM
  #61
onthedownlow's Avatar
Car: 1984 Camaro Berlinetta
Engine: 355
Axle/Gears: Australian 9 bolt 3.27 posi
Cars coming along very nicely! Great story too, I can tell how much you and you dad enjoy doing this stuff. You both look so happy in the photos, awesome to see (: Keep those updates coming. Subscribed
Old 03-07-2013, 10:56 PM
  #62
Gettin' There
A couple more holes filled
Old 03-07-2013, 10:59 PM
  #63
Almost ready for Bondo, you can also see part of the panel I cut out to cover the large open hole in front of the fender.
Old 03-07-2013, 11:02 PM
  #64
Slingin' mud!
In pretty deep!
Old 03-08-2013, 01:15 AM
  #65
1986Z28OWNER's Avatar
Car: 1979 Malibu
Engine: Blown LSx
Transmission: T56 Magnum
Axle/Gears: 9"/wavetrac/35's/3.70
Looking really good!
Old 03-12-2013, 08:14 PM
  #66
85SilverIrocZ's Avatar
Nice Z28... Gonna be nice when your
finished. ! ! !
Old 03-13-2013, 01:58 PM
  #67
Started sanding...then seam-filling
Old 03-14-2013, 01:22 PM
  #68
Sanding and paint dust was EVERYWHERE!
Almost time for primer and paint
Old 03-14-2013, 02:03 PM
  #69
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Looking good!
Old 03-19-2013, 11:06 PM
  #70
Primed!!!
Checking out the paint Dad got matched for me,this color is awesome!
Sneak Peek.....
its's already dusty!
Old 03-19-2013, 11:13 PM
  #71
Back to the motor:
Assembling the connecting rod and piston
Rings are on, ready to go in the block!
Santa came! except his sled was a brown truck and I ordered everything, but none the less it was exciting!
Old 03-19-2013, 11:17 PM
  #72
more parts!
Old 03-26-2013, 10:28 AM
  #73
Engine bay is painted!
Front cross member need some attention and since I could't afford a tubular one, I attacked it with a wire wheel and scuff pads, then Herculiner truck bed coating. I plan on doing the underside of the car too.
Motor work!
Camshaft going in
Dad helping get it lined up
ready for the timing chain
checking the clearance of the timing chain and the aluminum timing cover I bought
Looking good!
Old 03-26-2013, 10:37 AM
  #74
Time to paint the motor
got it ready to spray:
I am using Duiplicolor Engine enamels, Primer:
I went back and forth on color and I decided on Chevy engine orange, I like the old-school look:
I cleared it too:
Old 03-26-2013, 10:43 AM
  #75
Timing cover going on:
Took a break from the motor and installed my new polyurethane motor mounts
old:
new $10 mounts just for the cases:
All you have to do is drill out the mount rivets and install the new bushings, they secure with a large zip-tie and are sandwiched when bolted to the frame:
These were tons of fun to bolt back in!
Old 03-26-2013, 12:19 PM
  #76
Car: 1971 Camaro
Engine: 427
Looking good, I have a suggestion for you though, instead of sealing the gasket to the the block, like you did on the timing cover, seal the gasket to the cover. That way, in the future, if you have to pull it off, it will be easyier to scrape gasket material off the cover than the block.
Keep up the good work!
Old 04-02-2013, 11:23 AM
  #77
Johnny, thanks for the advice but the oil pan was already installed after I read it, Live an Learn!
More Progress:
Dad and I pulled the oil pump apart to have our friend weld the pickup on
Welded, cleaned, and back together, sorry about the blurry picture
Goin' on the motor!
Ready for the oil pan!
I went with orange on the block because I like the old school feel. Black would have trapped heat and made the engine bay too dark, and I didn't want blue for the same reason.
Almost time for the heads!
Old 04-02-2013, 11:30 AM
  #78
Edelbrock Performer RPM 64cc Aluminum Cylinder heads! I ended up buying their complete top end power package.
one down one to go
Starting to look like something. Heads are installed, so are the balancer and timing pointer
Lifters too!
Intake is next!
Old 04-02-2013, 12:29 PM
  #79
Fueled's Avatar
Car: 08 G8 GT, 98 Z28, 86 IROC, 85 Z28
looking good!
Old 04-02-2013, 05:10 PM
  #80
Engine: 355
Everything looks great.
Old 04-05-2013, 01:40 PM
  #81
Thanks!
With some more help from Dad, we got the intake on
Then came the water pump
Motor mounts went on, then it was time to finish the heart transplant!
Old 04-05-2013, 01:44 PM
  #82
Fitting the Hedman long-tubes
It's in!
Got the radiator and fan back in too:
Also got the overflow canister mounted:
Old 04-05-2013, 01:52 PM
  #83
Car: 1971 Camaro
Engine: 427
What cam did you go with?
Old 04-09-2013, 10:49 AM
  #84
Johnny,
The cam cam with the top end kit, I don't have the came specs with me but I believe it has .488"/.510" Lift, The RPM range was from 1500-6500. The kit is rated for 410 horsepower but that was on a 9.5:1 compression small block. My motor won't quite have that compression and I probably won't spin it to 6500 but we will see!
Some more Progress
Since this car is going to see the Drag strip a lot, and we had to pull the tank to modify the fuel pump, we figured it was time to upgrade the rear as well.
Tear down:
This rear is For Sale now. 3.23 gears, Posi, Disc Brake
Old 04-09-2013, 10:55 AM
  #85
I am fortunate enough to work at a transmission shop and my awesome boss was willing to let me tear down and help assemble my 700R-4 .Time to rebuild the trans:
Pulled Apart:
Cleaned and ready to assemble:
New "Beast" drum:
Shift and Ring kit:
New pan:
Old 04-09-2013, 10:59 AM
  #86
Setting up the shift kit:
Going back together:
Almost done!
Time to sign and date it:
New 2200 stall converter too:
Old 04-09-2013, 02:58 PM
  #87
LivinLarge's Avatar
Project looks great dude!! You keeping the stock rear end?
Old 04-09-2013, 03:00 PM
  #88
Nope, stock rear has to go, it's posted in the For Sale section now. I bought a Strange 12 Bolt....Pictures coming soon.
Thanks!
Old 04-09-2013, 03:11 PM
  #89
FryeDaddy's Avatar
Car: 85z28(sold),91 rs, 15'Mazda3GT
Engine: 5.7L V8 350 (ZZ4)
Transmission: 700r4 rebuilt with kits+ vette serv
Where you get that overflow canister from? Looks sick, agree the yellow thingy is a bit ugly lol
Old 04-29-2013, 08:29 PM
  #90
DiabolicalRS's Avatar
Car: '90 Camaro
Engine: 305 tbi
Axle/Gears: 9 bolt posi 373
any updates?
Old 04-30-2013, 03:19 AM
  #91
HaVoK_C89's Avatar
Car: 1985 Chevrolet Camaro Z28
Engine: 305 Small Block V8 (tpi)
Wow! You've come quite a ways...wish I had gotten my car at an earlier age lol.
Old 05-01-2013, 01:02 PM
  #92
Thanks guys!
Dad and I have been hard at work getting the car together, goal is Ocean City Cruisin in TWO WEEKS!
As I mentioned earlier in the thread, I am further along then the pictures show, but as of today, we have yet to fire the motor. That will happen this weekend!
Between school and busy weekends on the car I have not had time to post pics but I will get some more up soon.
Fyre Daddy: The overflow is a generic stainless steel canister from jegs
Here are a few pics.....
We got the old exhaust out:
And started test-fitting the headers, they are going to need to be dimpled on the drivers side
Old 05-01-2013, 03:16 PM
  #93
Richboll's Avatar
Car: 89 Black IROC-Z convertible
Engine: 305 TBI
Looking good. I hope it runs as well as it looks. Good job on the build!
Old 05-06-2013, 03:29 PM
  #94
We fired the car up.....took it for a test drive...I'm PUMPED! It's going to the trans shop this week to get the cooler, TCC switch and kick down cable adjusted. I will update the pics ASAP.
Old 05-06-2013, 04:16 PM
  #95
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Awesome build! I love your attention to detail... I am going to be doing the same thing pretty much when I get back from deployment.
Why didn't you go with a bigger stall though? 2200 seems a bit tiny if you have plans to race it a lot.
Also, I spotted a red fox next to your Camaro... Is that one of your parent's car or something? Any details on it?
Old 05-06-2013, 05:31 PM
  #96
one92rs's Avatar
Car: SOLD!!!!!
wow a young man doing it the right way!!!!!!! looks great!
Old 05-06-2013, 10:10 PM
  #97
Thanks Guys!
As far as the stall, I went off recommendations from my Dad and my Boss. While I do plan on racing the car, it will also see a lot of street time and cruising as well as being driven to the track.
The red foxbody is also mine. When I stated having problems with the camaro's original motor(plus it was slow and I wanted something with a manual trans) and pulled it off the road, I bought the Mustang. My family is die hard Chevy so I kinda broke the mold but I have always liked foxbodys. It is a 93 Notchback, originally a V8, T-5, Torch Red, Black interior car. It currently has a Gt-40 crate motor with a Paxton Novi-2000 Supercharger and a Tremec 5-Speed (all came in the car when I bought it) Since then I have been up grading it when I can(suspension, street slicks, making it my own).I have run a best of 12.07 @ 120 in the 1/4 mile and I drive it daily.
Old 05-09-2013, 08:58 AM
  #98
86T/A_Ram_Air's Avatar
Car: 91 Trans Am
Engine: 355 TPI
Transmission: Built T-5
Nice job on the build man, can't wait to see it done
Old 06-04-2013, 08:50 PM
  #99
Update Time!!!!!
Trans is done and ready to go in.....new cooler lines from inline tube....lokar flexible dipstick....freshly bed-coated cross member
Craigslist SCORE: 12-bolt rear, 3:90 gears, posi, LPW diff cover,33-spline street/strip(user name plug) axles, beefy studs, C-clip eliminators, and a ton of suspension components
Sent it out to have new seals put in and pinion depth and backlash checked etc., time to scuff and paint
cleaned up nice
Old 06-04-2013, 08:58 PM
  #100
Stainless brake lines from inline tube showed up
Along with the Hurst Line-Loc
First up, we put fluid in the rear
Then brake lines and the 4th gen calipers and rotors
Quick Reply: New Member 1986 Z28
