help me please!!!! tuned port injection
Old 10-22-2014, 05:47 PM
86z28gal's Avatar
please am stumped. brand new fuel pump, fuel relay, fuel regulator, iac, tps, spark plug wires fuel filter, pcm, maf sensor, new gaskets on throttle body. starts and will run in idle but as soon as u try to rive it acts like its getting no gas. cant even make it out of driveway. what am i not doing right. tps adjusted to specs timing on the money fuel pressure at 22psi. drained gas twice so new gas
86z28gal's Avatar
Re: help me please!!!! tuned port injection
this is on a 86 camero tuned port injectors
Old 10-22-2014, 06:01 PM
83Z28/L69's Avatar
Car: 83 Z28/L69
Engine: L69 305H.O.
Transmission: 6spd T56
Axle/Gears: 4.10 LS 4th Gen
Sounds like your fuel pressure is too low. Should be around 45 PSI at the rail.
Old 10-22-2014, 06:31 PM
COTM Editor (Retired)
Linson's Avatar
Car: 89 Formula 350, TTA
true. also, there is no "e" in Camaro. sorry. just sayin.'
I am having a similar issue with my Formula 350, but the fuel pressure is good. my next two moves are to replace the ECM ($85.00 with core) then the MAF (practically new A1 Cardone unit).
Old 10-22-2014, 06:55 PM
86z28gal's Avatar
so what can i do to get right pressure. i read 85 and 86 fuel pressure was only 17 psi. and checked pressure at pump and its getting 14 volts to it.did i maybe not connect pump right. it runs good but only at idle
69GTOby
04-18-2016 02:34 PM
customblackbird
10-01-2015 04:30 PM
mrestrictrplate
09-21-2015 11:24 AM
eustodp
09-20-2015 05:09 PM
m00n420
09-11-2015 02:39 PM
Quick Reply: help me please!!!! tuned port injection
