My 1988 sport coupe build
Want a title? Post!
Car: 88' Camaro Sport Coupe
Engine: Built 327
Transmission: Th200c
Axle/Gears: 7.5" 10 bolt 2.73 gears
Hi all just figured I'd share the transformation of my 88 sport coupe from when I got it February of 2012 till now.
Here's when I first brought it home paid $800 for it. It had the original tbi 305 removed and replaced with a carbed 350 that had a flat lobe on the cam and a blown headgasket because of it.
So I picked up a cam n lifters for cheap and pulled the heads to replace the gaskets. I will never do this with the motor in the car again haha.
Then two weeks later it spun a rod bearing so I swapped in a built 327 I had laying around 11:1 compression pretty wicked cam aftermarket valve springs and retainers and some ported camelbacks.
Old motor on the stand.
New 327 on the cradle.
Want a title? Post!
Engine: Built 327
Re: My 1988 sport coupe build
Tore all the hvac crap out and removed alot of the unused tbi wiring.
Then I had a headgasket fail due to my hei distributor failing and giving me way too much timing so that mixed with the high compression caused it to fail.
I threw headgaskets in it and drove it nice till this last year when it came apart again.
Want a title? Post!
Engine: Built 327
Want a title? Post!
Engine: Built 327
Got the motor back in and ran it for a bit it ran really strong and had no leaks so I went on with the mods. It had a nasty true dual 2 ¼ crush bent exhaust on it which had to go and I figured id ditch the manifolds at the same time so I ordered a set of hooker supercomp longtubes, a mufflex y pipe and a 4" bullet muffler for now.
Want a title? Post!
Engine: Built 327
That pretty much brings us up to current. Things I didn't list, 3 transmissions it ate and a pump in the current trans ,and it blew another headgasket right before last winter weights stuck in the hei. I also put in a custom stereo as well. Ill have to write up a complete mod list soon.
Here's a pic of how the car currently looks.
Want a title? Post!
Engine: Built 327
Mods:
11:1 327
Ported camelbacks
Aftermarket springs and retainers
Comp ultra gold roller rockers
Comp magnum pushrods
Edelbrock torker intake
"Chevrolet" tall cast valve covers
Comp cam lost the card I believe 525/540 lift unsure on duration
Holley 600cfm mechanical secondary carb.
Summit racing billet distributor
Summit racing digital ignition box w/rev limiter
Msd wires
K&N 4" filter and lid
Custom accessory brackets
Hooker super comp 1¾ primary long tube headers
Mufflex y-pipe
4" bullet muffler
Fully built th200c shift kit, line pressure mod.
B&M 2600 stall converter
Blazer 2wd driveshaft
Poly torque arm mount.
B&M console mount megashifter
Electric fan.
Interior:
Custom stereo
4x 8" crossfire db series subs
Crossfire vr601d amp
All Pioneer speakers
Jvc deck
One of thise cheap 3 gauge pods under the center vents on the dash.
Exterior:
4" steel cowl hood
Cheap chrome "track wheels"
Custom Dents dings scratches haha.
That about sums it up I think. Well till next year it's patiently waiting in storage.
11:1 327
Ported camelbacks
Msd wires
Mufflex y-pipe
4" bullet muffler
Electric fan.
Interior:
Custom stereo
Jvc deck
Exterior:
4" steel cowl hood
Want a title? Post!
Engine: Built 327
Thanks, been a long time lurker. I'm comin over from the dsm scene been doin sbc's for a long time though. This is my first third gen tho.
83 Crossfire TA
09-08-2015 12:06 PM
