1989 Iroc-Z Build
1989 Iroc-Z Build
New to thirdgen! And to Chevys as well! All advice is welcomed. I just bought a '89 Camaro Iroc-Z28 for a price I won't reveal
Anyhow, it was a deal I couldn't turn down. Sat on blocks for 4 years, from VA and transported up North. 130K Miles. Frame has little rust, floor pans are rusted pretty good though. I plan on making this car awesome by spring time! So I have plenty of time to get to it.
V8 350 5.0L (I believe.)
Gunna order parts Friday to have her running, hopefully. Will post pictures soon!
When we first got her
Now she's home!
Now she's home!
Car: 89 5.7 IROC/95 LT1 Corvette
Engine: All 5.7's
Transmission: 700R4 (Roessler)/ZF6
Axle/Gears: 10 bolt Zexel 3.23's. CTW 17" wheel
Re: 1989 Iroc-Z Build
It looks like someone tried to turn it into a 91 Z28...
I want to replace the quarter panel because I'm not going to bondo the any rust holes, I want it to be in top shape top to bottom. Needs floor pans as well. Any advice on welding either one or let a body shop do it? I'm getting it repainted when Spring is here. Putting all new interior. Dash is surprisingly in good shape! No cracks! Needs a tune up. Needs new tires. Doing that Friday, pictures will follow.
Finally got the parts in for the big day tomorrow! Will keep everybody posted. Got a new problem. Truck lock is siezed but we managed to get it opened and found a puddle of water at the truck bed. Got the water out, now she's airing out. Got the T-Tops off of it for ventilation.
Put all new plug wires in, new oil plus filter. Air filter, and battery. New connectors. Electronics come on, won't turn over. Fan is running when trying to turn over but it won't actually turn over. Going to test the starter tomorrow. Any suggestions?
Car: 92 camaro/99 gmc Z71
Engine: 357/5.3
Transmission: built 700r4 4500 stall/4l60
Axle/Gears: 4.56/?
Make sure the security light isn't on it will flash for a second then should go off but if it don't you have bigger problem.
Got the car started. I fiddled with the with the wires for awhile then she cranked over and ran for about 5 seconds. Gas is leaking from the back so the lines are gone. Needs a pump too. Will post pictures soon
Glowsock
09-11-2015 11:09 PM
