87 camaro z28 convertible build
#52
Car: 87 camaro Z28 convertible
Engine: 350 carb
Transmission: th-700r4
Axle/Gears: Posi traction 3.42 gears
Re: 87 camaro z28 convertible build
Just finished for tonight. I was able to swap out the driver door tonight.
Surprisingly the body looks very good
New door installed
New door installed
#54
Engine: 350 carb
More rust
Rust
Rust☹️
And more rust 😑
I was able to get some more work done today. Looks like I'm going to be cutting and welding more then I thought
#55
Engine: 350 carb
Started the painful task of cutting and replacing the floors
#56
Car: 1989 IROC-Z Vert
Engine: 305 TPI (LB9)
Transmission: 700R4 Auto
Great work so far, really looking better. I really think that it would be awesome to get her to look like she did new, yellow paint is uncommon and being a convertible is less common especially if she could possibly be a 1 of 1. I would try my best to keep her original color scheme. otherwise glad to see her coming back to life.. can't wait to see more updates!
#57
Engine: 350 carb
Thanks man. Still debating if I'm going to keep it blue or go back to yellow. The yellow with the black top and interior would look nice though.
#59
Engine: 350 carb
#60
Engine: 350 carb
Finally finished school and was able to get some work on her done today.
#62
Engine: 350 carb
If I do go back to yellow thinking of doing this color
Don't like this one that much.
#64
Engine: 350 carb
Before
One quarter panel done.
#65
Engine: 350 carb
Test fitting the floors. Still have some more trimming to due then por-15.
#67
Engine: 350 carb
#68
Engine: 350 carb
Got some work done on the car today. Dash and front windshield. Removal.
Found rust under passenger side dash. More cutting and welding to do.
#69
Engine: 350 carb
Front end ready to be sanded and primed
#71
Received 1,160 Likes
Car: 1986 Camaro Drag Car
Engine: 383 on Ethanol
Transmission: Automatic
Axle/Gears: 3.90 Currie 9 inch
Core support paint code is 19. Is that yellow? I could look it up but I'm not at work....
I want that car...
I want that car...
#72
Engine: 350 carb
Putting in some work today
#74
Engine: 350 carb
#75
Engine: 350 carb
Picked up a new door for the passenger side. Very clean.
#77
The paint code on the radiator support tag is 19. That is BLACK. I just looked it up on our paint mixing system. If that radiator support is original to the car....it is not a factory yellow car.
#78
Engine: 350 carb
#80
Engine: 350 carb
Yea that’s what I was thinking Because the whole car is yellow.
