87 IROC-Z Interior
Car: 1987 Iroc-Z Camaro
Transmission: 5-Speed
Axle/Gears: 9 Bolt Borg Warner 3.45 Gears
87 IROC-Z Interior
The Following things are what i have accomplished since buying this car a couple months ago.
New ACC Dove Grey Carpet install (ss396.com)
New Grey Sill Plates (Hawks Performance)
New Lt. Charcoal Deluxe Vinyl Seat Upholstry (Hawks Performance)
New Grey Headliner (Hawks Performance)
New T-Top Weather Strips (Hawks Performance)
New Belt Molding's Both Doors (Hawks Performance)
New GM NOS Seat Track Covers (EBAY)
New GM Right Side License Plate Lens (EBAY)
New Grey Seat belt Sleeves for front seats (Hawks Performance)
Parts i have that need to be installed:
New Door panels w/weatherstrips (Hawks Performance)
4 New Rotors and pads
New tires (Cooper Zeon RS3-A) 245-50/R16
New Oil Sending Switch
New Headlight Mounting Panel (Old one has a crack on one side)
New Pins and Bushings both Doors
New Pinion Seal
New Rear Differential Cover Gasket
New Under Hood Insulation
New Pinion Seal
Re: 87 IROC-Z Interior
This is the progression of the interior...
Thanks for the welcome, It is a nice car all around, the interior i have just recently finished. I will be painting the front clip later this winter when i have time, the urethane has a little bit of spider webbing. Other than that the car is immaculate as far as paint goes.
97K for mileage, it only has had 17k miles in the past 18 years, the owner i got it from didnt use it much and garaged it up until the last year he owned it, during that one year a grommet was worn out in the fire wall and thats where the rust came from on the floor board drivers side. so thats when i re did the entire interior. it does have radio delete also UL5.
COTM Editor
Very cool project! 87 was such a strange year for interior/seat trims. I gotta say I would see if whoever did the seats would be willing to take them back apart and add stuffing or swell the foams. The covers are very loose fitting, but it can be fixed.
Welcome!!!
Welcome!!!
