Project Secret Squirrel
Old 05-30-2015, 12:47 AM
LC2 TECH's Avatar
Project Secret Squirrel has begun.
Knew the turbo was blowing some oil but did not expect to find this.
So a new turbo goes on this weekend with larger injectors and a chip for now.
Hope to have the prototype 3" DP next week for mockup.
Future plans:
New stock location intercooler
Billet fuel sending unit (will be converting to E85)
3" single shot stainless exhaust
Mecham wing ( not completely sold on this one so maybe just a stock replacement)
Strut tower brace that bolts in with out drilling new holes
I am sure there will be more as we go along.
Old 05-31-2015, 02:59 PM
TEDSgrad's Avatar
Car: '89 Formula
Engine: LS2
Transmission: 4L65E
Axle/Gears: MW 3.42 12 Bolt
Re: Project Secret Squirrel
Since you could pick it up yourself, I'd go with the Mecham (save on ship). I wouldn't put old rubber on - that leaves Hawk's fiberglass which will need to be messed with to fit, but gives the stock look. Just keep the old rubber one around somewhere for posterity sake.
Good luck on Rocky (Bullwinkle is the moose)!
Old 05-31-2015, 03:47 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
I look forward to seeing some progress! I love the older Turbo GM rides... I was actually trying to buy a TTA when I stumbled into my Typhoon.
Old 06-05-2015, 12:17 AM
LC2 TECH's Avatar
Unfortunately with all the other projects this is going slower than I wanted.
Old 06-21-2015, 10:12 PM
LC2 TECH's Avatar
Everything buttoned back up and new tires came in. Hope to be able to test the new wastegate system and turbo this week. Then need to concentrate on other projects for awhile. Should have the full down pipe for mockup soon and will work on a new intercooler soon.
Old 10-24-2015, 12:28 PM
LC2 TECH's Avatar
Have not had a ton of time to work on her but did get a new turbo shield thanks to a friend and a set of newer seat covers for the front.
Attached Thumbnails Project Secret Squirrel-img_0727-copy.jpg   Project Secret Squirrel-img_0726-copy.jpg
Old 10-24-2015, 05:31 PM
MoJoe's Avatar
Car: 87 IROC
Engine: L31 350
Axle/Gears: 4.10 D44
I would expect oil leaking from the turbo to show up in the cold outlet side and intercooler. The cold inlet I think is crankcase blowby being sucked in from the PCV (hole on the right side). The leading edge of the impeller looks pretty rough! No doubt the turbo need to be overhauled/replaced.
These are oriented toward LS1, but you might consider a catch can between the valve cover and turbo...
https://www.thirdgen.org/forums/ltx-...-your-ls1.html
https://www.thirdgen.org/forums/ltx-...ort-silly.html
http://www.saikoumichi.com/Stage1_LS1_page.html
Old 10-24-2015, 07:58 PM
LC2 TECH's Avatar
The excessive oil in the stock turbo was from when it blew. Normally on the GN motors it is not a pronounced issue.
Old 10-30-2015, 10:31 AM
Beater79TA's Avatar
If you haven't already ordered the Mecham wing, don't. Unless you're a really good and patient with body work. We ordered one two years ago and it had a long list of issues including, 1) the mounting bolts didn't line up with any of the deck lid holes (and we acquired the correct decklid for this swap) and 2) the mounting points were an inch to short to mount the wing and close the trunk. It took our body guy about 20 hours of labor to correct the issue with the wing so it could be mounted to the car.
Since you're car has the wraparound spoiler, the Mecham wing won't mount to the deck lid without drilling new holes and patching the ones from the wraparound spoiler. Or you can find a different deck lid from the base flat spoiler and use it.
Old 11-16-2015, 09:11 PM
LC2 TECH's Avatar
New large neck intercooler mod
Old 11-22-2015, 09:52 AM
LC2 TECH's Avatar
One of the best buys I've had lately.
Makes oil change much easier. Not much work on her lately. Up soon 80lb injectors and F.A.S.T for E85
Old 02-10-2016, 09:23 PM
LC2 TECH's Avatar
Finally got the first downpipes mocked up and installed and went ahead and installed the Hooker exhaust from my B4C after a little modification.
Old 04-21-2017, 11:04 PM
LC2 TECH's Avatar
Have not updated in awhile. Installed new 80lb injectors and chip. Did some polishing and a little tuning. Hope to start on the custom intercooler after the summer.
Attached Thumbnails Project Secret Squirrel-img_2525.jpg   Project Secret Squirrel-img_2524.jpg
mattcanty
10-12-2015 11:08 AM
LT1Formula
10-08-2015 08:34 PM
oil pan 4
Fabrication
10-06-2015 11:56 AM
92projectcamaro
09-29-2015 07:07 PM
Vincent135
09-28-2015 10:50 PM
Quick Reply: Project Secret Squirrel
