The "Red Dragon" 1987 Formula 350
I picked up another 3rd gen, 1987 Pontiac Firebird FORMULA 350
First look:
Got it running pretty quick with a new Fuel pump:
then the 700R4 came out for a rebuild and stall convertor:
Got it too pass emissions, on the road and some new/used ROH Snypers
The heater core decided to puke all over the interior, so that was a fun replacement
I've just been cleaning the interior and replacing a bunch of broken Radio / HVAC / Shifter plate / Console parts, as it was broken into for the stereo, and they must have used a sledge hammer !
I've been driving it around town and to work quite a bit, much more fun than my P/U
~DaVe
First look:
~DaVe
Engine: 4++,350 & 305 CIs
Re: The "Red Dragon" 1987 Formula 350
Nice!
Thanks guys !
Plan for now is just keep repairing the small things ... still needs a HVAC / radio bezel and maybe a new pod, seats are in pretty rough shape, some small under-hood items like leaky vacuum lines, etc.
And of course original red paint and most of the original decals
Also picked up a set of Eibach prokit rear springs, and need to find matching fronts.
Even stayed in the garage for a minute
~DaVe
~DaVe
Car: Base Firebird
Engine: TPI 350
Axle/Gears: D44
Red dragon. F'n right!
Oh no thanks, honey. I've got a fresh beer!
Car: Base Firebird
Engine: TPI 350
Axle/Gears: D44
sweet find, btw. Original paint cars don't hide anything!
Well I took the red dragon to a local AutoX as my '82 was still a couple hours from being ready (oil change, etc.) ... I didn't like it after 5 of 8 runs it decided to not run, had to pull the driveshaft and rope tow it 4-5 miles home
Symptoms:
Starts very briefly and dies almost instantly
Can hear the fuel pump running / priming
Oil pressure gauge reads pressure so I don't think that's shutting it off
Time to get a fuel pressure gauge on it, and have the ignition module tested (suspect)
~DaVe
Symptoms:
~DaVe
I would agree with ignition or ECU issues too if it has good fuel pressure at the rails. It could also be low pressure from the pump.
New Wells SU-145 should be here Friday ... Really hoping it's the final "repair" / part needed as it has become frustrating !
Car: 92 Camaro RS
Engine: 5.0L
Transmission: AUTO, 56k orig
i have vogtland front springs, new in the box from founders performance, ill sell them to you. i kind of did the opposite, i had the pro kits on the front of my Z and the vogtlands on the rear. if your interested ill cross the part numbers and make sure its all good.
~DaVe
Car: 1988 Iroc-Z
Hell yes I did !
The Red Dragon doesn't get a lot of love, between other projects but heres a few random things:
TPI nameplate and airfoil, worth 4–6 hp and if you believe that I also have a bridge for sale!
Snypers back on after winter:
due to a radio thief ... New radio / HVAC "pod" & trim plate, stereo mount kit, rewired the old deck, new hidden antenna so I can eliminate the broken external power antenna on the fender:
And test fit of some new seats !!!
~DaVe
COTM Editor
Received 1,855 Likes
Car: '89 Firebird
Engine: 7.0L
This guy is the only person I know that does a burnout in his driveway while pointing at the house. You are either very skillful or very drunk.
Well I haven't hit any of my other things yet, .. BUT I do burnouts pretty often
~DaVe
~DaVe
wrong post
