CT-1986 Trans Am WS6
#52
Re: CT-1986 Trans Am WS6
Well it sounds like it really wants to turn over. If you have a multi meter you can pop the connectors off the fuel injectors and see if they are getting a reading. Also you can pull each plug and connect a spark plug to see if you are getting spark. Realistically I would just do what I did. Buy a new coil, set of oem plugs, plug wires, cap and rotor. It's like really cheap, and if all that stuff from 1986 like mine were I would just replace it anyways.
#53
Car: 1986 Trans Am WS6 w/ Recaros
Engine: LB9
#54
Engine: LB9
Can somebody send me a pic of there fuse box under the dash ? I'm having trouble seeing what some of mine are saying.
Thanks!
Does anyone have a fuse box diagram for an 86 trans am 305 tpi?
#57
Engine: LB9
Yeah I know, I'm going to keep this the original 305. I'm not looking to do anything that permanently alters this car ( maybe 5 spd swap? haha ). Easy bolt ons maybe, nothing extensive. But I am looking to clean up this engine bay and I think red spark plug wires would add a nice touch.
#58
Axle/Gears: 10 Bolt 2.73 Open
Uneven cranking speed, and something squeaking...are you sure you don't have an accessory that is frozen up? I had a Neon once that wouldn't start. Turned out to be a frozen alternator. Could not achieve enough cranking rpm to get it to start.
#59
Engine: LB9
My smog pump possibly. I'll have to check tomorrow. Can I just cut that belt?
#60
Engine: LB9
here is what I did today, I had very limited time so I was only able to pop off the distributor cap after labeling all the wires and such. What do you think of this distributor cap? Worth replacing? First, I checked a firing diagram and I followed each wire from the cylinder to the distributor cap...everything checked out. I'm not very mechanically inclined when it comes to this kind of thing, but you guys are definitely teaching me a lot!!
Pictures below indicate the position of the distributor cap and the rotor once I pulled it off.
#61
#63
Engine: LB9
Ok done! I'll have to get a new D cap and rotor for sure. Wires and plugs to check next.
while I was lookin around more thoroughly I noticed a mess behind the alternator here and under the Throttle body. And idea what can cause this? It's like a yellow powder almost.
#66
Engine: LB9
So according to what mantaguy posted... I am missing a fuel pump; oil pressure switch... and I looked what that could do and I found this on yahoo answers...
https://answers.yahoo.com/question/i...4184656AATPpms
Can this be why my car wont start? No oil pressure?
#68
Engine: LB9
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
It's the owners manual.My car doesn't have a fuse in that slot.
#70
Engine: LB9
Engine: LB9
Picked a new msd distributor cap and rotor today
Looks like the original ignition coil! 1-25-86
On another note, should I use MSD's gm bushing or low resistance bushing they included in the packaging?? Illl be using their cap and rotor but my stock gm ignition coil for now ( to see if it starts )
#72
Engine: LB9
I finally got it to start for a split second and it immediately dies. Tried several times and once it actually ran for 2 seconds and died
#74
Engine: LB9
Engine: 5.0 EFI
You don't need one of those to get the codes.Stick a wire in the A&B socket of the ECM terminal.
#76
Post 4 here shows how it was done on a '93 Lumina. Also shows a little key / tool that you used to be able to buy for a buck at your local parts store, back in the day. But a piece of wire, or bent up paper clip will do the same job.
https://www.2carpros.com/questions/c...arting-problem
#77
Engine: 5.0 EFI
Make a loop out of a pc.of wire,turn key to the on position,stick wire into A&B terminal,the 1st reading will be 1-2 (1 flash then 2 flashes )that will happen 3 times,then the diagnoses will start by a series of flashes,(example flash flash flash pause flash flash flash (3 times) that would be code 33,every flash would mean a number,again flash pause flash flash (3 times) would mean 12.every code will flash 3 times.so try and remember or write them down.
#78
Engine: 5.0 EFI
#79
Yep. And 12 means the computer as entered the diagnostic loop. So if you don't get the 12, you have to fix that issue first, then the rest.
You get a second code 12 after the trouble codes too, right Franny? To confirm you have reached the end?
It's been a while since I've done this with flash codes.
#82
Engine: LB9
Ok I'll start researching flash codes! Never done that before! thanks for the info.
#83
#84
Engine: LB9
This is a great video for flash codes! I'll have to try this next time I'm with the car!
#85
Engine: LB9
Did the flash code diagnostic, I got code 33. And maybe code 12? Or is that the end of the disgnostic sequence?
#86
12 is the beginning, and the end of the codes. Just tells you the computer is working, and has entered it's diagnostic mode.
Looks like 33 is "DTC - 33 MAP sensor circuit error (signal high indicating low vacuum)"
http://gmtuners.com/OBD1_DTC.htm
FYI...OBD 1 was the first On Board Diagnostics (OBD) system. Cutting edge in it's day, pretty crude by today's standards. It's fairly limited list of codes can get you pointed in the right direction, but does not point very specifically at a failed component. This gives you an idea that something is wrong somewhere in a system (MAP), but not specifically what. Is the MAP sensor bad? Is there a leak in a vacuum line? Is there an error in the computer reading the signal? Is there an open, or high resistance, in the harness to/from the sensor, creating a false reading? Corrosion at a connector body or terminal at the sensor, in line, or at the ECM? Just some possibilities you MIGHT run into (not saying that's the way the circuit works...just want you to understand how broad the code can be).
Today's OBD 2 vehicles have many, many more codes, and can be much more specific. It still doesn't tell you "change part X and you'll be all set", but it gets you a lot closer in a much more complex system.
#87
Engine: LB9
Ok so I'll go over all my vacuum lines, I probably don't even know what I'm in for haha. Maybe I should do one at a time to eliminate possible confusion
#88
Someone here will have a manual for your car. There will be a proper, step-by-step trouble tree for this code. Hopefully they will post it for you. Follow those steps, and you should find your problem.
#89
Engine: LB9
I did get a manual from a member here for an 88 firebird. Not sure if it's the same procedure? Aren't some years alternators, ac pumps and other things swapped ?
#90
Engine: 5.0 EFI
You are coding MAF(mass air flow)your application doesn't use MAP you have the 5.0 Tpi.
#92
Engine: LB9
My mechanic friend came over yesterday and we were tinkering with a few things, and He unplugged the MAF and I tried starting it to let it idle and it still didnt run with or without the MAF plugged in. Can this sensor be the reason why my car wont start? ( I'm currently uploading a video on youtube so you guys can see what it does now )
#98
Engine: LB9
#100
Engine: LB9
