For Sale: PROMinator Pro with selector switch
Old 04-08-2012, 08:16 AM
Quickstop's Avatar
For sale is a used PROMinator Pro with the associated cables and the blue LED bin selector switch.
I believe the device is for 16k bins. The Pro version allows you to upload bins to the PROMinator and then when you are driving you can change what tune the car is running from with no interruption to the car.
These were made by www.speedtronics.net and a gentleman called MrBill on here.
Search for PROMinator to get an idea but I am sure you know what these are.
I'd be looking to get $200 shipped or a near offer.
Please send me a PM as I am not on this forum very often.
Mark
Old 08-08-2013, 02:43 PM
Captain C's Avatar
Car: 1985 IROC-Z
Engine: 1989 350 4 bolt roller block
Transmission: ProBuilt 700R4 Road Race with Edge 9.5" 2800 stall lockup converter
Re: For Sale: PROMinator Pro with selector switch
Mark
Had one in my Camaro, they are the best bang for the buck you can get!!!!!
Old 10-10-2013, 11:52 PM
WoodenRegent's Avatar
Car: 1991 Camaro RS
Engine: 5.8l Aluminum LSX
Axle/Gears: 10 Bolt 3.42 "Spooled"
so, I'm kinda new to tuning. this looks like an awesome setup.
But how do I know if it will work with my car/ecu?
-Josh
Old 06-29-2015, 07:10 PM
champam's Avatar
Can anyone tell me where to buy a prominator??? Speedtronics no longer exists and ther is nothing on EBAY. Can someone tell me if I buy this thing do I no longer need a programmer ? Can it program a chip that is not plugged into and ECM?
MikePChampagne@gmail.com
89GTA
zz4 350
Running rich cant get past e-test need to learn to program ASAP.
Thanks.
Old 11-24-2015, 05:28 PM
Captain C's Avatar
Car: 1985 IROC-Z
89GTA
zz4 350
Thanks.
Wish I knew where to get one, he made them for Fords as well and I was thinking I would like to do a little work on my 2001 F-150 4x4.
You would still need the software for your particular ECM. The guy I sold my car to 8 years ago just sold the body after taking the motor and trans out to put in his son's 69 Chevelle. He messed up and forgot to take the computer out before he let it go.....
On the running rich thing, if you have an adjustable fuel pressure regulator, try lowering the fuel pressure. If you have an aftermarket fuel pump around 168 ltr per hr, you won't be able to lower it below 50 psi even with an adjustable regulator. On my 85 (with the 89 ECM via a homemade adapter) it turned my 30#/hr injectors into 33#/hr injectors..... If you are running stock 22#/hr injectors, they are more like 24's if you are running the bigger pump. Something I highly recommend!!!
tglennon11
09-23-2015 05:30 PM
tglennon11
Interior Parts Wanted
09-11-2015 10:25 PM
Randomtask2
09-10-2015 08:37 AM
luvofjah
09-03-2015 07:08 PM
85Special
09-03-2015 04:21 PM
Quick Reply: For Sale: PROMinator Pro with selector switch
