Ohio?
Old 09-26-2014, 04:08 PM
  #2151
budfreak1's Avatar
Car: 1991 Trans Am GTA
Engine: 355
Transmission: 4L60
Axle/Gears: 4th gen 10 bolt 3.42 posi
Re: Ohio?
Originally Posted by CashMunson
Anybody want to meet up for a gathering before the weather turns shitty?
I'm game for as long as my health hangs on.
Old 09-26-2014, 05:52 PM
  #2152
Azrael91966669's Avatar
Car: 1991 camaro RS
Engine: CharlesOdoryOB
Transmission: 82513892892
Axle/Gears: pbr disc 3.27 nine bolt
Re: Ohio?
never made it out this year
Old 09-26-2014, 10:27 PM
  #2153
CashMunson's Avatar
Car: 87 Trans Am GTA
Engine: 408 LS
Transmission: LS 4L60E
Axle/Gears: 9 Bolt/3.70 Gears/TAP Girdle
Re: Ohio?
Anybody else want to meet up with myself and Jason?
Old 09-27-2014, 12:42 AM
  #2154
Car: 1991 camaro RS
Re: Ohio?
me and I h8 wwd hung out tonight did his intake manifold
Old 09-27-2014, 01:36 AM
  #2155
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
Re: Ohio?
Proof.
We got more than just the intake done. Checked timing and bumped to 4*. Checked Fuel pressure and is showing around 10psi through the range. Figured out 2 live wires on my harness are no big deal (Fogs and under-hood light). Car seems much more stable. Smoother idle, snappier take-off. She's becoming a Beast, sort of.
P.S. Azrael
https://www.thirdgen.org/forums/faq-...ine-axles.html
Originally Posted by iroc_zz
Here are the hollinder part numbers for third gen axles
447-1301 82-87 F-body w/disc brakes 10 bold cover GM22515440 26 spline 30 5/16" long
447-1302 82-89 F-body w/drum brakes 10 bolt cover GM22515441 26 spline 30 5/16" long
447-1407R 87-90 Camaro, 85-91 Firebird w/disc brakes 9 bolt cover 28 spline
447-1605L 87-90 Camaro, 85-91 Firebird w/disc brakes 9 bolt cover 28 spline
447-1776 90-92 F-body w/disc brakes 10 bolt cover GM26034018 28 spline 30 5/16" long
447-1777 90-92 F-body w/drum brakes 10 bolt cover GM26031251 28 spline 30 5/16" long
The spicer numbers for the Dana 44 - bill of material number 605218-1, -2, & -3 (listed in the Spicer book as a 1984-85 F-Car)
72384-1X 29.54" long 1.31" x 30 spline
72384-2X 30.50" long 1.31" x 30 spline
I have 26 spline.
Attached Thumbnails Ohio?-img_20140926_210405-copy.jpg   Ohio?-img_20140926_210437-copy.jpg   Ohio?-img_20140926_222004-copy.jpg
Old 09-27-2014, 08:23 AM
  #2156
Car: 1991 camaro RS
Re: Ohio?
ok so the axles I have are 28 I do know that lol
Old 09-27-2014, 08:28 AM
  #2157
Car: 1991 camaro RS
Re: Ohio?
when is the plan to meet up? I will say I have too much **** to get done this weekend and I since I work Saturdays it wouldn't be till after 7 for me to get anywhere
Old 09-27-2014, 08:37 AM
  #2158
CashMunson's Avatar
Engine: 408 LS
Re: Ohio?
I was thinking next sunday as long as the weather is nice. Anybody have a place in mind? Summit racing?
Old 09-27-2014, 12:10 PM
  #2159
budfreak1's Avatar
Engine: 355
Transmission: 4L60
Re: Ohio?
I won't be around next Sunday. I'll be in Baltimore, working.
Old 09-28-2014, 08:25 AM
  #2160
BirdofFireBOB's Avatar
Car: 88formulatp1
Engine: 5.0
Transmission: 5
Re: Ohio?
Sunday the 28th Minerva is hosting a all city carshow. Weather looks good..Another good one coming up is The Old Stagecoach in over in North Georgetown on Monday the 6th of Oct. Last month there were a lot of nice rides and their fish sandwichs are the best. Period. They start to fill up after 5:30 since its a workday.
Old 09-28-2014, 09:10 PM
  #2161
patriot_tech's Avatar
Re: Ohio?
I'd be interested in meeting up with a few folks sometime. Anyone go to Quaker steak in canton on Sunday nights?
Old 09-29-2014, 09:59 PM
  #2162
GXP
GXP's Avatar
Car: 1991 Trans Am
Engine: 350 Crate
Transmission: 700R4 with shift kit
Axle/Gears: 10 bolt 2.73
Re: Ohio?
Near the Strip? I'm about 30 minutes away. I'm just trying to get a feel for the site and try to learn a few things so I can help some people out. I'm pretty new to cars in general haha but I'd be willing to talk shop sometime.
Old 10-01-2014, 07:00 AM
  #2163
kymmee's Avatar
Re: Ohio?
I was there a few times this summer. I'll be there next season for sure.
Old 10-01-2014, 05:49 PM
  #2164
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Re: Ohio?
Getting a new backfire after bumping up 4*. Will talk with Azrael about going down to 2 and testing from there. Going to dump the Seafoam in my tank and in the oil for a quick tank run through before an oil change. I'll tell you what though, it's nice not having the car bog every morning or making a turn and barely hitting the gas and the car stall. I'm still getting low fuel pressure. I'll mess with the FPR this weekend, see if I can't figure out the cause. New pump, new filter. 10psi before the TBI. I have ran the car close to empty, stalling a few times due to lack of fuel. Maybe this picked up some garbage and is now clogged, in-tank. Let me know guys. Adios.
Old 10-07-2014, 10:48 AM
  #2165
Car: 1991 camaro RS
Re: Ohio?
it mite be to much timing for lack of fuel when I had swaped in the tpi pump but still had tbi I had zero issues running more timing
GM's fuel pressure specification for the 5.0/5.7 Tbi's is 9-13psi. yours was a soild 10 but you havd done airflow mods to an engine that is already running lean stock they all do so bump the psi to 13-14 and you have more power right there and it will just plane drive better
also what gas grade are you running? I ran 89 in mine once I did all the tbi mods
is it backfire from the exhaust or intake
stop over tonight ill drop it down for you just takes 15 min or so
mine stock was 9 once I got it to 13 it ran so much better didn't have the "knock on giving it wide open throttle" honestly it was a completely different car just fixing all that crap and doing a tune up the car went from running 17.9 @79 to 16.8 @ 84 ya it didn't sound like much but it was a major difference at the time for me .
the next mod was the rear axle once I got rid of the open 2.73 and dropped in the 3.23 posi I also added the tpi fuel pump at the same time ran a 16.0 with the stock exhaust down to the manifolds and factory muffler then I added 1.6 rollerrockers 15.7 but it was much warmer out did the tpi swap that weekend and ran 15.0 with only the tpi swap then I did edlecrap headers and exhaust 14.7
then I spun a rod bearing and replaced the tbi long block with a lb9 with l98 cam and my 1.6 rockers
ran 14.3 and that was the best my 305 could do i found the zz3 on craigslist for 500 and never went back
Old 10-09-2014, 06:09 PM
  #2166
CashMunson's Avatar
Engine: 408 LS
Re: Ohio?
Morgan did you get those drag radials mounted up yet? I want to know how they work for you!
Old 10-10-2014, 07:20 AM
  #2167
IMissMy86TA's Avatar
Car: 1988 GTA 5-spd TPI
Engine: 5.0 TPI
Transmission: T-5 baby
Axle/Gears: 3.45
Re: Ohio?
I wish this thread was on topic. I thought it was for finding Ohio people and knowing who is in ohio from this group and Ohio events?
Maybe I am wrong...
Old 10-11-2014, 01:23 AM
  #2168
Car: 1991 camaro RS
Re: Ohio?
no I haven't mounted them up yet I been busy dealing with a funeral and scrapping that pos roadmaster I picked up but ill get them mounted soon
Old 10-12-2014, 09:50 AM
  #2169
CashMunson's Avatar
Engine: 408 LS
Re: Ohio?
Maybe I am wrong...
It is for ohio people and ohio events. It's also for ohio people to talk. If all of us that talk to each other, just talk on facebook... then we don't even need this thread.
Old 10-13-2014, 08:01 AM
  #2170
Engine: 5.0 TPI
Axle/Gears: 3.45
Re: Ohio?
was just curious...
Old 10-19-2014, 09:05 PM
  #2171
RKinney's Avatar
Car: 84 Bird-28k original miles
Transmission: M29 T56
Axle/Gears: Moser 9" 3.89 Detroit Locker
Re: Ohio?
I will be moving to Columbus at the beginning of December. Looking for any third gen people, possible meets. I have an 84 firebird, 26k original miles. It's under the knife at the moment. Suspension and brakes done, need to finish the Lt1/t56 swap. It's on hold till I get up there. Hopefully have it done by the spring. I will be living a few miles from national trails raceway. Do they have test and tunes throughout the year?
Old 10-20-2014, 07:15 AM
  #2172
Engine: 5.0 TPI
Axle/Gears: 3.45
Re: Ohio?
I am also in columbus. welcome!
sounds like a nice bird
Old 10-20-2014, 08:10 AM
  #2173
Zuk1972's Avatar
Re: Ohio?
I'm from centerville / dayton area and am just getting into learning to tune my sons tbi . Working on getting apu1 and reading up on here how to DIY . If anyone in this area is interested in helping a beginner with tips as I go along it would bd appreciated
Old 10-20-2014, 09:15 PM
  #2174
RKinney's Avatar
Re: Ohio?
Moates autoprom is a nice piece. I used it on my 93z lt1 and will be used on the same lt1 being used in my 84. Datalog and tune on the fly simultaneously with tunerpro rt. Really looking forward to get this move done and start working on the car. I am a GM tech, if anyone needs help with car issues let me know.
Old 11-03-2014, 02:55 PM
  #2175
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Re: Ohio?
Radiator sprung a leak at the fins. Trans line/hose blew off, trans fluid all over the driveway. Any local radiator repairmen? I can drive on it with low coolant, but'd rather get this fixed sooner than later. Thanks.
Old 11-04-2014, 02:35 AM
  #2176
Car: 1991 camaro RS
Re: Ohio?
might be time to buy a radiator 89 bucks at autozone
Old 11-10-2014, 11:20 AM
  #2177
firejuggalo's Avatar
Car: 1987 camaro
Re: Ohio?
springfield,ohio near the Dayton area
Old 11-10-2014, 06:17 PM
  #2178
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Re: Ohio?
Fart
Driving again, less coolant than before and trans actually feels better now after the quick flush and fill. Probably some gunk in there or something? Anyway, this weekend I'll probably get the radiator fixed and my fans re-wired and mounted. They keep cutting out and I think my butt-connectors are crappy, since they're hard plastic and not nylon. Going to replace the bc's with nylon ones so they'll not only be weatherproof, but won't slide out for any reason. Also going to remove the extra 3ft of wiring I have under my carpet since I routed everything around the door, then found a hole in the firewall to snake them through, just a simple cut and connect. No biggie.
I need my GUYrage fixed!
Old 12-02-2014, 03:01 PM
  #2179
CashMunson's Avatar
Engine: 408 LS
Re: Ohio?
Anybody working on their car? Mine has been under a car cover for the past month. I've started it a couple of times but that's it. As soon as we get 86Base's car done, mine will be back in the garage for some improvements.
Old 12-02-2014, 10:02 PM
  #2180
zaxanllc's Avatar
Car: 86 Firebird TA
Transmission: Automatic
Axle/Gears: Stock POSI
Re: Ohio?
I am in the Salem area south of Youngstown.
Old 12-04-2014, 08:59 AM
  #2181
Hayes84's Avatar
Car: 84 camaro z28
Engine: LG4 305
Transmission: Tremec 5 speed OD
Axle/Gears: 3.73 10 bolt 26 spline axles
Re: Ohio?
I go to UNOH in Lima, Auto/Hypo Tech.
-84 z28 still burnin tread!
Old 01-13-2015, 10:07 AM
  #2182
DC87GTA's Avatar
Car: 1987 Pontiac GTA
Engine: ZZ383 HSR
Transmission: T-56 6-Speed Manual
Axle/Gears: Ford 9", 3.89 TrueTrac Posi
Re: Ohio?
For all you local Ohio people. I have some items for sale in the classifieds. Take a look at let me know through the classifieds link below. I will not respond to sales on this thread. I just wanted to let the local Ohio guys know Would prefer not to ship these items.
https://www.thirdgen.org/forums/exte...-1987-gta.html
Old 01-13-2015, 06:06 PM
  #2183
CashMunson's Avatar
Engine: 408 LS
Re: Ohio?
Can't believe you sold your car. What are you working on now?
Old 01-13-2015, 07:17 PM
  #2184
5liter_eater's Avatar
Re: Ohio?
Berea Ohio. Right by the IX center and hopkins airport.
Hope to be the owner of an 85 this weekend!
Old 01-14-2015, 06:10 AM
  #2185
DC87GTA's Avatar
Engine: ZZ383 HSR
Re: Ohio?
CashMunson - I sold the car, and now selling the parts to move onto a 1st gen. (69 camaro). I do not have another project right now, but I have wanted one for as long as I could remember. I figured if I did not make the move to try and get one soon then it may not happen in my lifetime. I hope to start looking for a project to work on either this year or next year. Need to move my stash of parts for the thirdgen's first.
Old 01-14-2015, 06:34 PM
  #2186
89L98IROCZ's Avatar
Car: 1989 Camaro IROCZ
Engine: 5.7 TPI
Axle/Gears: 10 Bolt w/ 2.77
Re: Ohio?
Who all is around Fairfield County, Lancaster/Columbus area? We need to get a good racing scene set up. Everyone from my town drives a ***** and never want to do any racing, just fight and talk crap.
Old 01-15-2015, 10:50 AM
  #2187
Necron's Avatar
Car: 2002 Camaro SS
Engine: Built LS
Re: Ohio?
Any Folks down in Cincinnati area?
Old 01-15-2015, 11:29 AM
  #2188
89L98IROCZ's Avatar
Engine: 5.7 TPI
Re: Ohio?
why does it sensor r. i. c. e. r. ?
Old 01-25-2015, 09:39 PM
  #2189
GCrites80s's Avatar
Car: '87 IROC-Z
Engine: TPI 5.7
Re: Ohio?
I live in Columbus and work in Lancaster but am more of an autocross/road course guy not a street racer (assuming that's what you're talking about).
Old 01-26-2015, 10:45 AM
  #2190
89L98IROCZ's Avatar
Engine: 5.7 TPI
Re: Ohio?
Yeah I'm more of a street racer, where do u race?
Old 01-26-2015, 12:08 PM
  #2191
budfreak1's Avatar
Engine: 355
Transmission: 4L60
Re: Ohio?
You might want to join columbusracing.com. Good friends of mine own it, and they do lots of racing and meets.
And Hi guys!! I'm still alive and kicking, and so is the GTA. I now have a new truck, and am hauling cars. It's a loaded 2011 GMC Sierra 2500 HD SLT Z71 4X4 with 33K miles. If anybody needs my services, just let me know.
Attached Thumbnails Ohio?-20141227_162353-2-.jpg   Ohio?-20141227_160913-2-.jpg
Old 01-26-2015, 09:21 PM
  #2192
GCrites80s's Avatar
Car: '87 IROC-Z
Engine: TPI 5.7
Re: Ohio?
Most of the local AX venues such as Columbus Motor Speedway, National Trails, the auto auction lot on Groveport Rd. (if they'll have us back, lot's filling up again), Kil-Kare, Wilmington Airport. Also try to make it to Nelson Ledges from time to time.
Old 01-28-2015, 11:02 PM
  #2193
CashMunson's Avatar
Engine: 408 LS
Re: Ohio?
Glad to see things are going better for you. Get ahold of me sometime.
Old 03-14-2015, 04:35 PM
  #2194
CashMunson's Avatar
Engine: 408 LS
Re: Ohio?
Anybody still out there or is everybody just hanging on facebook?
Old 03-14-2015, 10:12 PM
  #2195
dukebomb1234's Avatar
Engine: MPFI V6
Transmission: 5 speed manual
Re: Ohio?
I'm from west unity, ohio about 55 mins from toledo
Old 03-14-2015, 11:53 PM
  #2196
Engine: MPFI V6
Re: Ohio?
mettalicirocz i live like 15 miles from you
Old 03-15-2015, 09:00 AM
  #2197
devildriver's Avatar
Car: 1984 Camaro Z28
Transmission: 700R
Re: Ohio?
I live around Findlay as of now. I grew up in Bellevue and Bloomville areas.
Old 03-15-2015, 06:04 PM
  #2198
zaxanllc's Avatar
Car: 86 Firebird TA
Re: Ohio?
Near Canton Ohio here
Old 03-15-2015, 07:16 PM
  #2199
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: BBC 509 Merlin ii 9.6:1 pump gas
Transmission: ATI pro th350 sfi case. TSI 5500 st
Axle/Gears: Strange S60 4:10s
Re: Ohio?
I grew up in Bellevue as well. Moved up to toledo as I'm part of a pipefitter welder ua local 50 union. And this is where the works at.
Old 03-15-2015, 10:48 PM
  #2200
kymmee's Avatar
Re: Ohio?
Still here-pretty much hibernating during the winter. Ready for spring. Plan on doing Riverfront in Cuyahoga Falls and some cruise in's at Roosters and Quaker State in North Canton.
Quick Reply: Ohio?
