Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
What size slicks?
Old 08-13-2005, 07:36 PM
BT283's Avatar
Car: 1991 Camaro RS, 1993 Camaro Z-28
Engine: what engine, LT1
Transmission: did it come with one, 4l60
Axle/Gears: They spin (most of the time)
What size slicks?
Hey guys, i am just trying to figure out what size MT ET Drags i should put on my car, its a 91 Camaro and the wheel size will be 15"s and probably mounted on Telstars. I dont what the tire sticking way out of the wheel well and i was think how does a 28x10.5 look on a camaro? Thanks in advance
Old 08-13-2005, 09:06 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
A 10.5" slick might be a little wide to install without some modifications. A 10.5 DOT tire will fit though but only has a tread width of about 9".
It's going to depend on exactly what rims you use. I don't know how well a 28x10.5 slick will fit on a stock rim. Minimum rim width should be 8" and 10" would be better. How far it sticks out depends on the rim backspace. Most common for third gens is a 10" wide rin with 5.5" backspace.
Depending how well it's goin to fit on you car, clearance issues are normally on the inside. Buy and install the tires and rims. Then if anything needs to be modified for clearance, you can see exactly what needs to be done. The 28" tall tire shouldn't cause any problems. It's just the width. The biggest problem will be the bump stops. They can easily be cut off and sectioned over if the tire comes to close to them.
A 28x9 slick should fit with no problems at all and will fit on factory rims.
Old 08-13-2005, 09:12 PM
BT283's Avatar
i was going to mount them on Telstars but it is just a drag race wheel(pull up to the dragstrip and change wheels kind of thing). Any pics of a 10.5 tire and 10" wheel on a camaro i can see thanks so much
Old 08-13-2005, 09:46 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Unless you have 4.10 gears I dont think you want 28" tires. You would be better with 26" tires.
Old 08-13-2005, 11:24 PM
BT283's Avatar
yea i have a 3:73 gear
Old 08-14-2005, 11:23 AM
jbenge's Avatar
Car: 1991 Camaro Z28
Axle/Gears: Strange 12 Bolt, 3.42
I'm running 15x8 with 4.5in backspacing on the rear. Tires are 27x10.5 ET Streets. They tuck in very nice, this pic should give you an idea of how it looks.
Old 08-14-2005, 11:32 AM
jbenge's Avatar
another shot from the front
Old 08-14-2005, 03:29 PM
BT283's Avatar
Thanks those look great and did you have to do any kind of clearancing for the rear tires to fit?
Old 08-14-2005, 05:34 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Remember what I mentioned in my above post. A slick and DOT tire are not the same. ET Streets are a DOT tire.
DOT tire width is measured across the section of the tire. A 10.5" tire usually only has about 9" of tread.
A slick width is measured across the tread. A 10.5" slick is usually between 11-12" wide across the section.
The 27x10.5 ET Streets should fit with no fender modifications.
http://www.mickeythompsontires.com/strip.html
Go look at the dimensions of each tire.
Old 08-14-2005, 05:37 PM
Blackroc86's Avatar
Car: 1986 Iroc
Engine: 454 Demon 850DP
Transmission: TH350, 3500 stall
I was runnning a 28" tire and ran 11.86 with 3.73 gears.
Old 08-14-2005, 07:34 PM
itsjustabird's Avatar
Car: 91 firebird
Engine: sb2.2 headed sbnos
Transmission: tsi glide
Axle/Gears: 4.30
i agree with stephen 28" and 3.73s are a rough combo unless you have a real strong motor, but despite this i have went 11.58 with this combo and using a th350. i do believe it will go faster with a lil tune. to make the most of your car you would theoretically(sp) need a steeper gear. aaron
Old 08-14-2005, 07:37 PM
jbenge's Avatar
Yes they fit very well, no modifications to the inner fender well. Depending on what classes you want to race in you might want to consider a dot tire...I like using the dot tires to keep my options more open as to what classes I can run in.
Old 08-15-2005, 08:19 AM
BT283's Avatar
i didnt relize a ET street and ET drag where different sizes thanks, and is there really a difference in traction in a ET street and an ET drag
Old 08-15-2005, 08:58 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Not really. They're made from roughly the same compound. The ET drag is a bit softer. The new ET drag and ET street radial tires are softer than the old ET street tires but still not as soft as the ET drag. The ET Street just receives a DOT rating because of the thin grooves in the tread.
That doesn't mean the tires should be driven on the street. The rubber is so soft that on a daily driver, the tires could be worn out in less than 4000 miles. The DOT slicks, no matter what brand, were designed for racing classes that demand a DOT tire. They were never intended for street use.
It's better to just buy slicks and mount them on a second set of rims for track use only.
Old 08-15-2005, 11:37 AM
BT283's Avatar
That is what i am doing because im going to switch them between two cars i just what to get the right size slick
Old 08-15-2005, 11:24 PM
83 Crossfire TA's Avatar
Are you suggesting that the new et street DR’s should be close to as sticky as the old ET streets (I’ve run nitto and BFG DR’s that aren’t nearly as sticky as a dot slick)?
Old 08-16-2005, 05:06 AM
dragracer2068's Avatar
I have 28x10.5 mickey thompson slicks on my car they are mounted on a 15x9" rim with 5.5" backspacing
Old 08-16-2005, 07:33 AM
IHI
IHI's Avatar
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
Compound's might be close, but sidewall is all together different and that is where the lack of traction in the radial tire design lacks for less that perfectly tuned chasis's and better than stock hp.
Old 08-20-2005, 01:58 AM
1bad406's Avatar
Car: 1987 Camaro
Engine: 406
Axle/Gears: Moser 31 spline / 4.86
Here's mine with 28x10.5's on 15x9" rims with 5" backspacing. Had to tap on the inside of the finders a little bit.
Old 08-20-2005, 02:32 AM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
28x10.50" ET Drags on 15x8" rims with 5.5" Backspacing. Had to beat the crap outta my wheel wells and grind down the lower control arm mount. My current 27x10.50 Hoosier QTP's fit with tons of room everywhere.
Old 08-25-2005, 08:31 AM
406maro's Avatar
Car: 1986 Camaro Berlinetta
Engine: 406 roller
Transmission: th 350
Axle/Gears: 4.10
i squeezed in some 29x11.5 hoosier slicks on 15x8 wheels with 4.5 backspacing. i had to beat in the inside fender wells a touch, but they look nice. they are on centerline indy style wheels, looks nice.
Pac J
05-17-2020 10:44 AM
LiquidBlue
Wheels and Tires
32
12-10-2019 04:06 PM
PAFORM350
Wheels and Tires
10-02-2015 07:21 PM
dbrochard
Interior Parts Wanted
09-28-2015 07:40 PM
Twinn Engines
South East Region
09-25-2015 06:25 AM
Quick Reply: What size slicks?
