15x10 with 6.5bs anyone running?
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Is anyone running a 15x10 with 6.5bs? I know the accepted size is 5.5bs but trying to see if I can tuck them a little more before buying a set of rims. Got the bumpstop area cut out and a flat piece of steel welded in along with offset LCAs and the front area has been beat a ton. I don't mind cutting out the front area and welding in more plate steel if needed. Looking at a drag radial class where I could run a 325/50 M/T drag radial.
Car: 1986 Iroc
Engine: 454 Demon 850DP
Transmission: TH350, 3500 stall
Re: 15x10 with 6.5bs anyone running?
I have 15X10's with the 5.5" back spacing with 28X13.5 ET Streets. I had to do some pounding on the inner wheel well as well a trim the bolts on the lca's. I think it would need a lot of clearancing to go with 6.5 backspacing.
Car: 1984 Z28
Well there's someone on another forum looking to do a 325/50 with 6.5" bs and a 1/4" spacer and he sounds like it should go on easily. Right now he's running the 325/50 with 5.5bs. I really wish I could find pics of a vehicle with the 5.5bs and see their clearance with a bigger tire like this from underneath especially showing shots of the front area, LCA spacing, etc etc. A 325/50 is 13.4" of section width and over 11" of true tread touching the pavement across. It is similar in size to a 10.5W tire.
1 Post
Car: 92 Z28
Engine: Boosted LSX
Just mini tubb it.
15x10 with a 6.5 BS.
but as I said The wheel wheels were cut out and mini tubbed.
Sold these rims and plan to put a 17x11 under it with a 315 next.
http://www.cecoatings.com/images/Car...r/DSC03644.JPG
Im sure it could be done with a BFG (Big FKeN Hammer) also.
Car: 1984 Z28
Just mini tubb it.
1 Post
Car: 92 Z28
Engine: Boosted LSX
Yes its a 6.5 BS. and quite a bit was removed actually. Like I said i want to fit a 315 or even a 335 if I get wider rims.
Dono what tubbs they were as i got em from a buddy who is totally redoing his car to a 25.5 chassis.
Here are some pic's before everything was removed form his and I did mine.
http://www.cecoatings.com/images/oth...ED3rdgen/2.jpg
http://www.cecoatings.com/images/oth...rdgen/back.jpg
http://www.cecoatings.com/images/oth...n/dscf0003.jpg
http://www.cecoatings.com/images/oth...20(Medium).jpg
All Im using are the tubbs. none of the other sheetmetal.
I have 15x10s with 6.5bs and a 275/60 Hoosier drag radial. Just had to cut the hump out kind of like a c notch or like a mustang to get the clearance i desired. Also beat and cut some of the front on the inner fenderwell. Doesn't stick out past the outer fender looks awesome.
Car: 1984 Z28
Car: 1984 Z28
how much clearance do you have all around proxemics? on the inner portion I mean. Not to mention the tire I'm planning on mounting will be probably 3" wider than yours.
Car: 87 Z28
Engine: 383
Transmission: th350
Axle/Gears: ford 8.8
Unfortunately it's so tight I want to go wider on tire but it seems I can't
I will get some pics of mine this weekend and get them posted. My car is not finished yet. Stopped mid stream on the project and switched motor setups and then run low on cash. Hope to finish very soon.
Car: 85 Camaro
Engine: 437" small block
Transmission: glide
Axle/Gears: 3.70
Not sure if your still looking but I just got done installing mine. 15x10 6.5 bs with a 295/65 drag radial. Slightly rolled lip, some work to the front of the wheel wells and removal of the bump stop hump.
Car: 1984 Z28
yup I've had my 28x12.50 slicks on the car for a few months now, posted pictures in a different thread. Your car looks nice as well
Car: 82 Z-28
Engine: 408
Transmission: TH-400
Axle/Gears: 4.11
hey radialtireking, what are the other bars that are visable in the rear end shot? they stick down on either side of the center section.
oh, by the way GREAT lookin car!
Car: 92rs
Transmission: 350
Axle/Gears: 3.73/Moser 12bolt
radialtire , that is awesome , you answered both of My ?'s before I even asked
wheel spacers are nhra prohibited (least from what i remember)
if your car doesn't run 7's you're just as g*y as anybody else not running a tt5 or smaller
Car: 85 Camaro
Transmission: glide
Axle/Gears: 3.70
They are wheelie bar brackets. I run the bars once in awhile while testing just incase my changes don't work. Once the cars is dialed in I remove them since they are illegal in the drag radial classes I run. Once in awhile I miss the setup and it ends up on the bumper which is always fun.
Car: 87 Trans Am
Engine: 434 being built
Axle/Gears: 3:73
Car: 85 Camaro
Transmission: glide
Axle/Gears: 3.70
Those are 15x3.5 with 26x4.50x15 M/T front runners. It looks better when the motor is in the cars so the gap isn't so big up front. I also have a pair of 15x4 with 205/70/15 for use on the street.
Car: 87 Firebird Formula
Engine: AFR headed SBC
Transmission: TKO 600
Axle/Gears: 9" Moser with 4.11's
Nice looking car radialtireking! I was just wondering if you had a closer shot from the back but more on one side of the car to see where the tire sits in comparison to the fender lip. Does it tuck up in there? Also this might be a dumb question but i have never removed bumpstops will that be a problem if I do that to make room for a larger tire if i still want to drive it on the street? Thanks for the help.
Car: 85 Camaro
Transmission: glide
Axle/Gears: 3.70
Did you have any interference with the LCA's? are they offset or did you not have any problems with them? Thanks again
Car: 1984 Z28
i'm sure they'd have to be offset LCAs with rod ends.
Car: 85 Camaro
Transmission: glide
Axle/Gears: 3.70
They are spohn LCA's with rod ends. They are not offset and I have about 1/2" of clearance. I wouldn't run it that close with a bias ply but the radials don't flex around much so it's no problem.
Thanks for the quick reply! I was wondering if you know if there is a difference in size between the rod end LCA and Poly bushing style in size or would i roughly have the same clearance? I am looking at running a little smaller tire than you ( the 275/60 )so that would also give me like a 1/2 to 3/4 inch on each side more play. Thanks again for the help
Car: 85 Camaro
Transmission: glide
Axle/Gears: 3.70
Thanks for the pics they look great. The tires tuck nice and the car is sick looking, awesome job.
Car: 1984 Z28
yup looks just like mine.
sorry about the wheel gap in that last pic, I'm parked on a hill in the grass.
Is your cage custom? If not where did you get it at? What other mods are done to your car? I noticed a different axle for sure. I have a white 84/85 berlinetta that I wanted to do a street/strip car with.
Car: 85 Camaro
Transmission: glide
Axle/Gears: 3.70
Wow this is an old post. Yes the cage is custom. It has Been updated to 25.5 specs since these pictures were taken so it's legal to quicker than 8.50. The rear is a 9" ford and pretty much every part of the car has been modified in one way or another.
Fast355
12-02-2016 06:33 PM
eightsixseven
08-14-2015 03:09 PM
