Pour out a 40oz for my IROC-Z
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
Had this car since I was 16... At this point it looks like it wouldn't even be worth trying to fix. All windows and t-tops are shattered and the roof is smashed in big time. It'd be cheaper to just find a new car to put it's drivetrain into.
In a strange way it's probably a good thing this happened because the car wasn't exactly the safest thing on 4-wheels. It was one clean pass away from running 9's and it's only safety equipment was the factory seat belts.
Car: '89 IROC-Z
Re: Pour out a 40oz for my IROC-Z
yeah there's like some tropical storm passing up the east coast. It's been pretty windy and rainy all day but nothing too crazy. Just bad luck.
Car: 1989 IROC-Z
Engine: 355, 6.0 (LQ4) soon
Axle/Gears: Borg Warner 2.77 for now
That almost happened to me when Ike rolled through here, I'm glad the crappy carport my car was under held up. Woulda went straight down the middle of my car lol. The bad thing is yours is/was nice looking, definately a loss.
Car: '89 IROC-Z
The sucky thing is that I usually don't park the car there and I also usually drive it to work every day even if it is raining but today I hopped into my other car
Car: '89 IROC-Z
In all honesty my car is only nice looking at certain angles from a distance. Up close it's pretty rough looking. It had the original paint and interior which has all seen much better days. White paint hides a lot in pictures.
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
That sucks man. My condolences. A buddy lost his T/A two winters ago when his carport collapsed on it. He has since walked away from the hobby.
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Luckily the chassis was nothing special so you can pick up another clean roller and maybe add the proper safety equipment this time around. Hopefully the insurance company sends you a fat check and luckily the drivetrain wasn't hurt, that's where the money in these cars is at.
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Man, glad it is a third gen, so easy to find another, so if you heart lies with the rest of us and you wanna go a bit faster, there is a 82-90 firebird that is lighter and more aerodynamic calling your name to get even faster by cutting weight from the factory! LOL
1 Post
Car: projects.......
Damb, sucks to see this kinda stuff. - Homeowners insurance won't touch it, so it's up to whatever coverage you had on it and/or what you can part it for.
Car: 95 Z85 S10, 99 Formula
Engine: 4.3 CPI , LS1
Transmission: NV3500, T56
Axle/Gears: 3.08, 3.42
crapp it got that bad yesterday?? i just saw a few accidents but damn.
i rarely park my camaro on the street under a tree but after seeing this no no >.<
good luck with whatever happens
1 Post
Car: 1986 Camaro SC
Engine: None
Transmission: None
Axle/Gears: Moser 9" W/ spool 3.50 gears
Thats terrible. The storms were terrible hear last night and we have trees down everywhere. Thank god I have a garage.
On a lighter note. I got something you need. 86 camaro, 3100 or so lbs, beutiful brand new 10 point tig welded cage through dash and frame tied through floor boards. Brand new simpson harness with two full years of cert and more. It's got you drivetrain written all over it. Come get it. lol
Car: 84 Transm
Engine: 350 sbc
Transmission: t400
Axle/Gears: ford 9", 3.90
Man, that sucks. Home owners should cover that, depending on who and what you have for ins. I had something similar happen and they paid.
1 Post
Car: 1984 Z28
Engine: Alky 360
Transmission: TH400, Freakshow 9.5"
Axle/Gears: 9" 4.71
Sorry to hear....will make sure to give up a little for another car taken by the gods...
Car: '89 IROC-Z
...I bought this car using money I saved up for over a year working a part time minimum wage job in high school. I hadn't so much as changed oil before buying it so I've learned a lot along the way. I got the speed bug back then after a friend of mine introduced me to the philly street racing scene... I remember Fast 383's old "Tweekd" Monte, my buddy Will's (local guys know "malibu2slow") brown Malibu, The GN motor convertible IROC, 1QWIKZ's old primered Camaro... Lots of other cars that all inspired me to go fast.
In the end it's just a car and it can be replaced... I change my mind more than I change my underwear about what I wanna do though. At the moment I'm thinking I'll part out the body, sell the dana 44, and wheels which should all net me at minimum $2000. I've always had a fondness for 1st gen S10's and I see them all over the place in the sub-$1000 range so that's my most likely choice. I'd like to build something a little more mild and daily drivable so I'd probably take the motor apart (it's due for a freshening anyway) and rebuild it with a smaller cam and less compression. I think even with a milder motor I can run in the lower 11's on motor in an S10 considering they're at least 500lbs lighter than my IROC.
...Then again, if I happen to stumble across a clean and very cheap f-body I'll scoop it up and just swap everything but it seems everyone wants a fortune around here for 3rd gens even in worse condition than mine..
1 Post
Car: 1986 Camaro SC
Engine: None
Transmission: None
Thanks for the props on the Tweekd Monte and I drove the GN powered Iroc alslo. That was my buddy Mikes.
I was serious about selling my car because I have an opportunity to by a TTA roller. It would be ready for you to transfer everything over into. Your wheels, rearend, fuel system, headers, motor, trans, T/A and all. The car will Cert to 8.50 no problem. I have a reciept for Chassis work for $2500 from 1/10. The cage is done very right. Car is very presentable. I will sell the car for $3500.
PM me if interested.
Car: 91 Z28,64ImpalaSS4094spd,67 Galaxy
Engine: Dart 415Profiler hd,cmprlrs,Hlly750
Transmission: Built 700R4, 3200 stall
Axle/Gears: 3:89 Moser 9"
Sorry to see that happen, bummer........
Car: 1989 IROC-Z
Have a pic with the tree removed? From the pics it looks like you got "lucky" and have only have roof damage, but we all know thats not the case. If you were close I'd let you have my '89 RS roller, or at least let you cut the roof off. I almost lost my car twice and seeing this reminds me of how much my car means to me, no matter how big a pain in the butt it wants to be! At least its still there and thats all that counts.
Car: '89 IROC-Z
Car: '89 IROC-Z
In about 3 weeks I'm going to start parting the car out - Everything will be parted out including the drivetrain so if anyone is interested in anything let me know...
Car: 92 RS
Engine: 305 weakTBI (wanting TPI)
Transmission: 700R-4
Axle/Gears: Stock (2.73?)
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
Jesus just wanted a fast car to play with.
...sorry about your loss! i wish my car had been in its place, it needs put out to pasture.
Car: '89 IROC-Z
Update... Came across this. It's an 89 that is almost identical to mine. Been sitting for years but the body is very straight with very little rust, and it's pretty much all there except for the motor. Even though I didn't really want to build another turdgen, I saw this and couldn't resist. Should be pretty easy to splice the good parts off my car onto this one and be back running by next season.
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Thats sweet! Lets see a side by side of them! Are you going to add some safety equipment to this one or just run it sleeper style?
Car: '89 IROC-Z
It'll probably be slower than the old one because I'd like to keep all the stuff it currently has... the stock hood, wheels, air conditioning, and maybe even see how long the 700R4 lasts if I can find a converter for the right price. I might even see what kind of times I can run with the 2.77 rear since i've always gotten a kick out of seeing how fast I can run in these cars with all the "crap" parts so this should be fun.
Car: 1989 IROC-Z
Well theres your sign! Cheap and it wasn't a tree pillow! Looks good, now tear it up!
