Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
Best converter for the money
Old 02-23-2011, 10:14 PM
383 rs's Avatar
Ok guys I am getting my Th350 gone through right now. I have had two trans burn up in my converter i have now. I figure it is time to get a new one. I was running a 9" 3400 before, unsure of the make but definatley an older conv. Who do you think makes the best converter out there for the money. I dont wanna spend $1000 on one. looking around the $4-500 range.
Also do you think is worth getting my old one rebuilt, and if so who do recommend?
Johnny
Old 02-23-2011, 11:04 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
Re: Best converter for the money
Transmission Specialties...talk to Fast383 on this board. he gives TGO members a good deal. i have one of his converters in my car, and he's been on board helping me with the technical questions i have whenever i tweak something on the car. his name is Justin.
i just noticed, you live in Warner Robins...i do too! who is/was building your transmissions? whats your combo?
Old 02-23-2011, 11:23 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Any torque converter can fail. They don't last forever. With a torque converter, you really do get what you pay for and expensive ones can fail just as easily as inexpensive ones. The expensive ones should however take more abuse put to them as they should be built with better components.
A proper converter purchase should be done with an engine dyno sheet in front of you. Since most people don't have that, detailed information about the engine, the vehicle and it's intended use should be known so that the converter can best match the combination of parts used.
Old 02-23-2011, 11:48 PM
383 rs's Avatar
They guys name is Neal. He works on base and builds them on the side. He is supposed to be the stuff. My car is just a 500hp 383. Solid lifter old school motor. The car is almost done I just need to get tranny situated and put some paint on it
Old 02-25-2011, 10:18 AM
Fast 383's Avatar
Car: 1986 Camaro SC
Engine: None
Transmission: None
Axle/Gears: Moser 9" W/ spool 3.50 gears
Hey, thanks for the word Matt. I may have to pay you commision, lol
You should probably post up some details on your motor/car. I had a 383 500HP motor that liked 3200-6500 rpm's. You may have one that likes 4500-7500. That will make a difference as to which converter and stall speed will work best for you. Your cam profile and duration at .050 will determine the desired RPM range.
Another thing that will help you decide is the use of the vehicle. If it's a full street vehicle you may feel comfortable with a 3200 stall and strip only car may like a 4000 stall.
Your budget of $400-500 is going to take alot of the guess work out of which actual converter your gonna get. Usually, that kind of money will get you a 10" (9.5) street/strip unit. We sell our maxed out version for $435. Balloon Plates and all. Stall between 2500-4500 depending on where you want it.
PM me if you want the TGO deal that MW66NOVA speaks of or if you have any specific questions about your options. Or just post em.
Old 02-25-2011, 10:51 AM
mw66nova's Avatar
Engine: 7.0L
just send me two new stickers cause i need to move mine from the front fender to the window hell, i'd put a banner across the windsheild if you had on for me
Old 02-25-2011, 02:16 PM
Fast 383's Avatar
Car: 1986 Camaro SC
Engine: None
Transmission: None
Send address in PM. I have something youll like.
Old 02-25-2011, 02:52 PM
383 rs's Avatar
Ok here are a few specs on the car. I am on my phone so I'm gonna try to make it shorter. The car was planned to be weekend play toy but I enjoy cruising it around. So I think I need to keep it under 3400.
Cam specs
At 50. 244 intake. 252 exhaust.
Valve lift. .52 int. .54 ex
Car is I'm guessing around 3200. Alum rpm heads, hooker super comps, with a 342 gear
Old 02-25-2011, 04:57 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
My opinion would be 3600-3800 at least, you put in a big cam, not a small "cruising" cam
Old 02-25-2011, 06:13 PM
383 rs's Avatar
I understand it is a big cam. I should have worded it better, the motor was planned to be used on mainly on the strip. But when i got the car together i had alot of fun driving around.
I think i would rather lose a little bit of 60' time and keep it more streetable.
Old 02-25-2011, 06:34 PM
DIGGLER's Avatar
my experience has been that you will goof up the innards of a $400 converter long before you'll need balloon plates. im not a converter guy, but i was told the cheaper ones arent welded all that well on the fins. (which is why most of mine got bent backwards)
i guess your torque applied to the track while leaving the line would be a good number to monitor. if its a big number, you need to spend more on your converter. (power adder cars on a big tire, for instance)
Old 02-26-2011, 03:01 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
I spent 200$ on a Jegs 2700-3000 converter because i have used them in the past, but not for long, so i will actually see how it does after beating on it for a while, usually i used them then solde the car or trans it was in. Otherwise, for 200$ they have been great. With the turbo build, i am scared to find out what converter i will REALLY need to hold 650 RWHP.
Old 02-26-2011, 06:05 AM
mw66nova's Avatar
Engine: 7.0L
those Jegs converters are built by Transmission Specialties.
Old 02-26-2011, 01:46 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
I assume that is good? I had no idea who actually built them, just know i have bough 4 or 5 of them.
Hotrodboba400
12-10-2019 07:07 PM
89fast5oh
09-08-2015 09:55 AM
Vassago
Convertibles
09-04-2015 09:37 PM
Hotrodboba400
09-02-2015 07:28 PM
Quick Reply: Best converter for the money
