Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
Winter 2013/2014 drag race suspension overhaul!
Old 05-14-2014, 09:09 PM
  #101
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
Re: Winter 2013/2014 drag race suspension overhaul!
well i noticed my 1/8 mile mph swung nearly 2 mph between 6 passes and so i started looking. it picked up the mph on the passes it spun, lol. i have 1 pass where it went near 102 mph in the 1/8
i don't know much, but i'll help with what i can!
Old 05-14-2014, 09:16 PM
  #102
khulsebus's Avatar
Car: '89 Camaro
Transmission: 4L65/70E
Axle/Gears: 9 Inch, 3.70 gears
Well, mine needs more work before I take it to the track. I'm going to try and get it together enough to go to the track before I leave Missouri, but I'm not going to put slicks on it until I get a new rearend.
Old 06-02-2014, 08:48 PM
  #103
mw66nova's Avatar
Engine: 7.0L
gonna try to get the oiling under control before it bites me:
big thanks to PA Racing for stepping up again and giving me a killer deal on this pan. wanted to get this on before the race this weekend, but i'll be living dangerously on the fbody oil pan one more weekend.
Old 06-07-2014, 10:30 PM
  #104
mw66nova's Avatar
Engine: 7.0L
put the small 750 back on, changed nothing else, and today i ran:
10.59
10.50
10.49
10.52 (lifted)
10.55 (lifted)
10.48
no idea why, but it seems to like this smaller carb better. DA was worse today, hovered around 1500'. Ran with the Pro Stick (east coast stick shift bracket org) and had a blast. i'll never go back to an auto. i made it to the 3rd round today where i went way red as the car tried to roll the beams on me. Also, the headlight covers are worth NOTHING. i ran the same mph (actually a little better today at 131.8 was my best) without the covers. i messed them up this week so i opted to take them off...was basically wasted effort, lol.
https://www.youtube.com/watch?v=kvN7...ature=youtu.be
in car
https://www.youtube.com/watch?v=kgZ9...ature=youtu.be
Old 06-08-2014, 07:15 PM
  #105
86iroc2try's Avatar
Car: 84 camaro
Engine: HRE 355
Transmission: th350
Axle/Gears: 4.56
Way to go buddy!!! Looking good.
I figured out my struts are done on the front of my car. Finally taking off the old 90/10 lake woods. They don't like wheelies after 200 passes.
Old 06-08-2014, 07:27 PM
  #106
mw66nova's Avatar
Engine: 7.0L
yo brandon, how ya like that "right on with a 1"?
also, 200 passes on a set of struts seems like not a lot. i know guys that can do that in 1 season....
Old 06-08-2014, 07:34 PM
  #107
86iroc2try's Avatar
Car: 84 camaro
Engine: HRE 355
Transmission: th350
Axle/Gears: 4.56
Oh yeah...the dead on is $$$$. Lol.
I thought the struts should last many years ...but I had them on my old street car before for a couple of years...and now on this one.
Time for some fresh ones I guess.
Old 06-08-2014, 09:42 PM
  #108
zz17iroc's Avatar
Car: 91' Z28, 92' Z28
Engine: 383, L98 stock
Transmission: Built 700R4, Stock 700R4
Axle/Gears: 12 Bolt 3.73, 10 Bolt 3.23
Matt,
That thing is moving, makes me wish I'd kept my T56. I may consider getting another since I went turbo, but who knows! Looking good Bro.
Old 06-09-2014, 07:23 AM
  #109
mw66nova's Avatar
Engine: 7.0L
Craig, you ain't lying man, this thing is a blast! Have you made any passes yet with the new turbo combo? i'm definitely pumped to see how it does man
Old 06-09-2014, 09:31 AM
  #110
skinny z's Avatar
10.59
10.50
10.49
10.52 (lifted)
10.55 (lifted)
10.48
What are the 2 carbs you've been using?
Any mods (in a flow improvement sense) to either?
At what RPM do you feel you're making peak HP, (not neccesarily your max RPM)?
What am angling is that the formula most use to determine CFM based on engine size and max RPM is somewhat flawed. Even taking into account what your assumed volumetric effeciency might be, the formula leans towards a carb that a little on the large size. That results in mixture quality not being as good as it might be with a carb of a smaller size. Often the smaller carb will produce better results. This might be what you're seeing. It may also be the the style of booster that's in one carb compared to the other. A booster that gives a stronger signal will produce better mixture quality and the result is a charge that enters the cylinder that easier to ignite. That may not sound like much of way to build more horsepower but a lot of people put a lot of time into that part of the science for a reason.
Bigger is not always better.
Old 06-09-2014, 01:02 PM
  #111
mw66nova's Avatar
Engine: 7.0L
carb 1 ("old reliable") 750 cfm:
box stock holley metering blocks
box stock holley fuel bowls
box stock holley throttle blade plate
proform center section (the original 750 one released 12-14 years ago)
2 corner idle circuits
downleg boosters
front pv
i haven't had the bowls off in so long i don't recall jetting
carb 2 900ish cfm custom K&B carb that was not built for my engine:
billet blocks with custom metering
billet throttle blade plate
downleg booster
pv in front and rear
4 corner idle circuits.
because this was a custom jobber, i have opted to not post jetting/metering that i've found because it wasn't my carb.
i realize my testing was not very scientific, and without the information from the other carb, it's just not a great comparison. also the comparing runs were done on two seperate weekends, but the DA was within 400'. the better results was from the smaller carb and worse air, lol. i have asked my father to let me just keep this thing though, lol!
Old 06-09-2014, 01:14 PM
  #112
skinny z's Avatar
Might be a perfect example of how the increased venturi size ( and I'll bet the 900 has a larger cross sectional area when compared to the 750) is affecting mixture quality. Not as fine an atomization and a mixture that enters the cylinder a little compromised. This isn't to say the 900 couldn't be brought around to match the 750s performance. Something along the lines of a stepped downleg may make the difference or even an annular dischage booster although I've found that tuning the annular booster takes a little more time because they repsond so well to any changes made. That said, from a drag racing perspective, that's not so much an issue. WOT and go.
Like you said though, tests on different days may not be telling the whole picture.
Old 06-19-2014, 10:57 AM
  #113
mw66nova's Avatar
Engine: 7.0L
car is in it's new home i couldn't be happier right now
Old 06-19-2014, 08:23 PM
  #114
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
matt
your not going to know what to do... with out snow on your tools or rain dripping on your head!.. WOW.. out of the stone age....sorta speaking
cool!
Old 06-20-2014, 09:28 AM
  #115
STREETDEMON's Avatar
Car: 91 Z28
Engine: 6.0L LQ9
Axle/Gears: Dana 44 3.92
whoever was painting in that garage has 2 right feet.......
glad you've got some shop space to wrench!
Old 06-20-2014, 10:27 AM
  #116
skinny z's Avatar
You left your lights on.
Old 06-20-2014, 10:29 AM
  #117
mw66nova's Avatar
Engine: 7.0L
the car was running when i took the picture
Old 06-20-2014, 10:32 AM
  #118
quik88's Avatar
Engine: 406 sbc, dart iron ea
I didn even notice the two right feet!!! now that's funny. matt that thing is running great man keep it up.
Old 06-27-2014, 07:11 AM
  #119
mw66nova's Avatar
Engine: 7.0L
first night out on the street playing in the new area, brought it home on the trailer
seems the tick stage 2 didn't like a hard 2-3 on street tires, lol! i'm sure it was already hurt, cause it seems unlikely that it would have broken the way it did otherwise. i think i got the output shaft but i'll know more this weekend.
time for vipershaft and faceplate upgrade!
Old 06-27-2014, 08:18 AM
  #120
Car: 91 Z28
Engine: 6.0L LQ9
yeah, it wouldn't have anything to do with side stepping the clutch on the north side of 6k rpm at the track......
Old 06-27-2014, 09:41 AM
  #121
mw66nova's Avatar
Engine: 7.0L
you mean, 7800?
Old 06-27-2014, 10:06 AM
  #122
Car: 91 Z28
Engine: 6.0L LQ9
you mean, 7800?
well yeah...just didn't want to pin it down to 1 number, haha. i remember waiting to hear what happened around 5k!
Old 06-27-2014, 10:59 AM
  #123
mw66nova's Avatar
Engine: 7.0L
can't wait to get it out and see what is actually broken.
Old 06-27-2014, 08:14 PM
  #124
DIGGLER's Avatar
i need a third gear and third gear synchro assembly if the rest of its trash... lol
Old 06-29-2014, 09:11 PM
  #125
mw66nova's Avatar
Engine: 7.0L
well...not what i was hoping to find...not sure exactly what the long term solution will be, but i think i'm going to send this to Tick to have it fixed and re-set up to their tolerances.
Old 06-29-2014, 10:05 PM
  #126
1991sleeper's Avatar
Car: 1991 firebird
Engine: TBI 305 (built)
Axle/Gears: 4.10
Tick tock tick tock .... Boom ... Sorry I couldn't resist ...
91' bird 305 TBI T-5, trick flow 175 cc heads, 4.10 gears, lots of suspension upgrades......... 24mpg @ 2300rpm hwy 65mph ........ 8.63@ 85mph 1/8th on street tires... 8.000's soon
Old 06-29-2014, 10:49 PM
  #127
IROCgiraffe's Avatar
Car: '87 IROC-Z | '99 SS
Engine: LB9 | LS1
Transmission: 700R4 | T56
that trans don't look good :-P ... Don't know how I missed this thread. Subscribed!
Old 06-30-2014, 08:20 AM
  #128
Car: 91 Z28
Engine: 6.0L LQ9
well, i can honestly say i've seen worse. we had a 4 speed saginaw behind an aluminum headed 383 in a 56 chevy. went through 4 of them in about 2 weeks, then put the th-400 back in!
did it get into the case or chew up any bearings?
Old 06-30-2014, 04:52 PM
  #129
AssaulT/A's Avatar
Car: 1986 Trans Am
Axle/Gears: 3.08? unlimited slip
you mean, 7800?
Holy Bajesus that's insane! What's your 60' time with a launch like that?
Old 06-30-2014, 09:16 PM
  #130
mw66nova's Avatar
Engine: 7.0L
it spun hard on that pass. went 1.59 or something. i normally launch at 6000 rpm and do a quick slip, not a dump. i've been 1.41 a few times.
i can't see exactly what all it got. i think the case and bearings are OK, but not for sure.
Old 07-04-2014, 04:03 AM
  #131
zz17iroc's Avatar
It's always something! But that's the price we pay in this hobbie; boys and our toys. I'm pretty sure I'm going to break something in Valdosta, Ga. next weekend during the LSX vs. Everybody else event when the boost gets turned up to 15-18lbs.
Old 07-04-2014, 07:08 AM
  #132
mw66nova's Avatar
Engine: 7.0L
keep me posted on how it does craig!
Old 07-04-2014, 02:00 PM
  #133
mw66nova's Avatar
Engine: 7.0L
talked with Jonathan at Tick Performance a bit yesterday. T56 is shipping monday. it will recieve:
-new input shaft
-new cluster shaft
-faceplated 1-4 gear set
-REM polishing
-cyrogenic treatment of all pieces
-plumbed for squirters onto the input/cluster gear set
-viper mainshaft
we worked out a payment/layaway plan. here's to hoping i get it all back together over the next 6 weeks or so. trying to get it back together by yellow bullet, but definitely hope to be at the ProStick/UMTR stick shift nationals in mid september at MIR.
Old 07-04-2014, 02:18 PM
  #134
AssaulT/A's Avatar
Car: 1986 Trans Am
Glad to hear you're gonna get it fixed up! Could you explain what REM polishing is/does?
Old 07-04-2014, 02:41 PM
  #135
mw66nova's Avatar
Engine: 7.0L
it's a polishing process to the tooth face of the gears. it removes any stress risers from the tooth to hopefully prevent premature wear or damage. it's a popular process with differential gears too (my next ring and pinion will be lightened and REM polished).
Old 07-14-2014, 05:38 PM
  #136
86iroc2try's Avatar
Car: 84 camaro
Engine: HRE 355
Transmission: th350
Axle/Gears: 4.56
Damn bro. You got your hands full there!!!! Good luck getting her back together. Will I see you at Yellowbullet?
Old 07-14-2014, 09:20 PM
  #137
mw66nova's Avatar
Engine: 7.0L
i will definitely be there. it's still up in the air whether i will have the car or not though :/ we will have chucky's car regardless!
Old 08-06-2014, 06:59 AM
  #138
mw66nova's Avatar
Engine: 7.0L
just an update:
i've been speaking with steve at monster clutches. we've decided that a tilton flow control valve (basically a restrictor for the clutch hydraulics) will help with longevity and consistency, so i'm putting that on my list.
i spoke with the guys at tick performance about the damage. it got:
-input shaft
-cluster gear shaft
-5th gear
-6th gear
-reverse gear
Buddy also mentioned that the fluid was burnt. this was new Amsoil ATF and had less than 20 passes on it so i was surprised when he said that. Basically the fluid is going to the back of the case on hard launches and the front gears and bearings run dry for a couple seconds. compound that with the high rpm range that this engine wants to live in and it was only a matter of time, so i'm also going to be getting an external fluid pump to keep the pieces parts happy.
Additionally, the payments are going to tick, albeit slowly, and i'm hoping to have the trans back maybe sometime next month. i'm about halfway there right now, lol.
Old 08-06-2014, 08:26 AM
  #139
Engine: LB9 | LS1
Good update!
Old 08-06-2014, 08:05 PM
  #140
khulsebus's Avatar
Car: '89 Camaro
I'll be waiting to see another pass either on here or MM.
Old 08-07-2014, 06:50 AM
  #141
mw66nova's Avatar
Engine: 7.0L
stickers make it faster, right?
Old 08-07-2014, 10:38 AM
  #142
mw66nova's Avatar
Engine: 7.0L
i just looked at the schedule again to get a refresher. there are two pro-stick races in October. One is at Mason-Dixon Dragway in Hagerstown, MD. The other is at VMP in Richmond, VA. i don't know how realistic it is to make the one in VA, but the one in MD is about 45 mins from my house. Mason-Dixon does a drive-in drag event too, where you have to drive in and race. it's setup as a bracket race and i believe they have a quick 8 also. i'm going to try to get the car back together for these events.
just trying to be realistic at this point. i'm also trying to come to grips with the idea that i may NOT make it out before the end of the season. it will be hard to say.
a local guy is allowing me to borrow a factory stock t56 though. i will not race on it, but i have some ideas on some mods for the car that will make servicing the trans better/easier. i'm going to put the trans in the car, get the mods setup, get the hydraulics bled with the new restrictor, and do a little driving. this will be mutually beneficial as he has no way of testing to see if this t56 is any good.
Old 08-12-2014, 07:51 PM
  #143
mw66nova's Avatar
Engine: 7.0L
things gettin' serious up in hurrrrr
Old 08-19-2014, 08:57 AM
  #144
mw66nova's Avatar
Engine: 7.0L
started my next project while the trans is out:
Old 08-19-2014, 11:12 AM
  #145
Engine: LB9 | LS1
I see what you did there More deets
Old 08-19-2014, 12:11 PM
  #146
mw66nova's Avatar
Engine: 7.0L
i hope to have more updates about this tonight or tomorrow. i'm going to cut the other side out tonight, a crosstube will go between the sfc's for a transmission crossmember, then i'll run tubes from the subframe stubs back to the crosstube, and lastly, i will french into the floor tubes diagonally from the crosstube rearward back to the sfc's nearish the front lca mount. i'll keep ya posted.
Old 08-19-2014, 10:11 PM
  #147
mw66nova's Avatar
Engine: 7.0L
more cutting tonight. hope to start the new bars before the end of the week. tomorrow will be a wash though.
and what i cut out
Old 08-20-2014, 08:43 AM
  #148
khulsebus's Avatar
Car: '89 Camaro
So much more room for activities.
Old 08-20-2014, 09:21 AM
  #149
Engine: LB9 | LS1
(popcorn is popping in the microwave)
Old 08-20-2014, 09:47 AM
  #150
mw66nova's Avatar
Engine: 7.0L
i wish i could have another update tonight, but it's gym night, and having lost 50lbs so far, i'm not wanting to skip on my routine. i have another 25lbs to get to my goal weight, lol. so...i'll get back under the car tomorrow night and get back to work
Quick Reply: Winter 2013/2014 drag race suspension overhaul!
