Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
Winter 2013/2014 drag race suspension overhaul!
Old 10-12-2014, 09:16 PM
  #201
khulsebus's Avatar
Car: '89 Camaro
Transmission: 4L65/70E
Axle/Gears: 9 Inch, 3.70 gears
Re: Winter 2013/2014 drag race suspension overhaul!
Could have been 3200 if you had shaved. Because race car and weight reduction.
Old 10-12-2014, 09:18 PM
  #202
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
if i had shaved, i'd have lost the ability to use the man pedal. bearded manliness is what makes the man pedal possible
Old 10-12-2014, 09:21 PM
  #203
khulsebus's Avatar
Car: '89 Camaro
I justify the not shaving because I need ballast in the middle of the car. That and I have to shave everyday for work, so not shaving on the weekends is ok.
Old 10-13-2014, 07:05 PM
  #204
mw66nova's Avatar
Engine: 7.0L
well....looks like i'll be in the market for a new case and gear set, lol.
does anyone have an opinion on these cases? Says they're good for 1200+ HP....
http://www.ebay.com/itm/9-Inch-Ford-Yukon-Aluminum-Thru-Bolt-Third-Member-Case-/221534882546?pt=Motors_Car_Truck_Parts_Accessories&hash=item3394820af2&vxp=mtr
Old 10-13-2014, 07:59 PM
  #205
DIGGLER's Avatar
i have the moser version. i have no complaints thus far.
the car sounds sweeeet!!
Old 10-14-2014, 08:24 AM
  #206
zz17iroc's Avatar
Car: 91' Z28, 92' Z28
Engine: 383, L98 stock
Transmission: Built 700R4, Stock 700R4
Axle/Gears: 12 Bolt 3.73, 10 Bolt 3.23
Matt, that car is moving son!! I enjoy watching you roll thru those gears man, just makes me think back when I put a T56 in my car. Should have stuck with it because it made the car more enjoyable.
On another note; the converter worked out just fine, but now I have a ton of blow by on cylinder # 7. After pulling the plug, it was so wet with oil it was pouring out of the plug. I knew something was wrong when the car only went 7.38 @ 96.17mph and with a 1.75 60ft. on 9lbs. of boost. I know when it happened too; It was when I installed the 3-bar map sensor in August and not knowing in EBL the MAP PW constant wasn't correct for the 3-bar MAP and this was after I made my first WOT pull. I looked at the data and said that's not right, and it was crazy lean. So now I'm down for the count.
At first, I was really upset wishing I had known about the tuning flaw prior to turning on the 3-bar map flag in EBL, then again their will always be risks when playing with our toys but at what cost is the question. I already knew I was playing with fire with high compression, so I also knew my tune had to be spot on. This is a major set back for me and I don't have that kind of money just laying around to build a new motor at the time. So the beast will be down until I can dig up the money for the repair. Still kinda upset about it!!!!!!!!!!!!!!!!!!!!
Old 10-16-2014, 07:00 PM
  #207
mw66nova's Avatar
Engine: 7.0L
dude, i totally understand that man. this season has been tough!
i forgot about this video. stumbled upon it. round 1 win, 10.422 on a 10.42 dial
Old 10-17-2014, 02:17 PM
  #208
zz17iroc's Avatar
You know Frederick, Md. is like 18 miles down the road from Mason Dixon. That's where I grew up.
Anyway, I should have the motor out this weekend to take a better look at the damage that 3-bar map sensor fiasco caused!!!!!! I sure wished I knew about that before trying the 3-bar. Well I guess it was time for a rebuild anyway, after 10 years of beating on it.
Old 10-17-2014, 06:38 PM
  #209
mw66nova's Avatar
Engine: 7.0L
yessir we live in woodbine area btw
keep me posted.
Old 10-18-2014, 07:39 PM
  #210
mw66nova's Avatar
Engine: 7.0L
was getting stuff out of my boxes here at the house to prepare for the new rear case to be here and decided to pull the pinion support out of the broken case....the pinion support crumbled as i pulled it apart....
i was counting on this piece still being good. i may be stuck at the moment.....running into a crossroads of "getting another to get me back together" and "getting the one i need for the 35 spline setup now"....
Old 10-20-2014, 07:14 PM
  #211
mw66nova's Avatar
Engine: 7.0L
well, pieces started showing up this weekend.
i'd never seen the conversion bearings for a baby spool (28/31/33) in a big case, so i figured i'd share them too, lol.
workin hard, gotta get the pinion support and yoke ordered yet.
Old 10-29-2014, 08:06 PM
  #212
Sojer's Avatar
Car: 1987 IROC-Z red t-top
Engine: Nothing much
Transmission: I wish t56
Axle/Gears: 9bolt 3.27 4sale
U need a 4 inch crank or better RHS 502 ci ls lol. I follow your car a bit, it helps me build mine. Like my car will be faster but I was going to use a ls1 oil pan but never thought of its limits. The bell housing, the trouble to have it in right. I know to knock my dowl pins out now lol. I would love to see u take this thing in the 8s
Old 10-30-2014, 08:52 AM
  #213
billybob6110's Avatar
Car: 1984 chevy camaro
Engine: 355
Transmission: turbo 350 2800 stall
Axle/Gears: 3:73 detroit locker posi
Originally Posted by mw66nova
today was not a work day, but i went down to where the car was for a baby shower so i figured i'd take a couple of pictures of what i accomplished yesterday since the sun went down on me before i could take pictures.
don't mind the lack of rear carpet or the scratches on the interior plastics as this thing is an ever going project. i'm going to try to either repaint my interior plastics, or come upon some decent black plastcis. also going to redo the rear carpet in ozite like we did my cousins car. next week i am going to make a dzus rail for the front of the hood, so hopefully that will tighten up the hood gap. i also have a handful of other small projects that need to get tied up to be ready for the MM meet on 4/13.
where did you get the roll cage carbon fiber decals at? that's a good idea for wear areas
Old 10-30-2014, 09:50 AM
  #214
mw66nova's Avatar
Engine: 7.0L
those are not decals. they're the real deal
http://www.jerrybickel.com/carbon-fi...rotectors.html
Old 03-04-2015, 05:04 PM
  #215
Podium's Avatar
Do you happen to have pics off the exhaust bolted up after you completed the frame rail mod?
Old 03-04-2015, 07:55 PM
  #216
mw66nova's Avatar
Engine: 7.0L
Podium,
I saw you contacted me the other day, and i'm sorry i hadn't gotten back to you yet. It's been a busy week. here's a couple pictures of the old exhaust system under the new subframe mods.
Old 03-04-2015, 09:24 PM
  #217
skinny z's Avatar
Have you ever done an analysis (like through a Pipe Max program or similar) to see if those collector/mufflers are the best length?
Old 03-04-2015, 10:33 PM
  #218
Podium's Avatar
Thanks Matt!
Old 03-05-2015, 08:22 AM
  #219
mw66nova's Avatar
Engine: 7.0L
the system pictured was slapped together based on best packaging. the new headers i'm building (outlined in this winter's update thread) are going to have primary and collector lengths that are tuned based on PipeMax.
Old 03-05-2015, 07:31 PM
  #220
skinny z's Avatar
... have primary and collector lengths that are tuned based on PipeMax.
Nice. I've had the Pipe Max program for a few years now. Interesting results except that I haven't had the chance to build anything for me specifically. Perhaps this year will be the breakthrough year.
I'll be interested to see how your headers and exhaust work out. (You may have to start a new thread though...)
Old 03-05-2015, 08:49 PM
  #221
mw66nova's Avatar
Engine: 7.0L
it's outlined here:
https://www.thirdgen.org/forums/orga...t-updates.html
Bubbajones_ya
09-14-2015 08:38 PM
abray1
09-14-2015 08:18 AM
dennisbernal91z
Wheels and Tires
09-12-2015 12:28 AM
buckshot63
09-10-2015 09:15 AM
84 TA NV
09-06-2015 08:02 PM
Quick Reply: Winter 2013/2014 drag race suspension overhaul!
