moving the car to the new place..
ok having the car moved by rollback.
just tossing the front end on it so it will roll (k member is off )and all the front end parts.
so i have to put just the basics (i hope) car is 40 miles away from the new house. all this will be pulled off when in the new shop.. so i can do the paint under the car.
tube K member
coil overs
spindles
rotors
wheels and tires (have to mt up the new ones) all out of the others.
im thinking i can just install the coil overs on the struts with the stock hats. as its just to move the car 20 or 30 feet.
and what of the tie rods ya think ill have to put this stuff of finger tight to have it pulled up on the rollback.. as i have the steering box out also.
just want to get it moved.. and all the new parts are just sitting what all do ya think ill need to get the front end to roll..(wheels and tires ...yes)
ill pack up all the parts even the streeing box as i dont want to make a 40 mile drive to get somthing i forgot..
anybody moved one like this before? some insight would be fantastic.
tube K member
coil overs
spindles
rotors
Car: 85 Trans Am
Engine: 383 ci
Transmission: Liberty Geared Tko 600
Axle/Gears: Moser 9" 4.11 gear wavetrac locker
Re: moving the car to the new place..
it would be no fun. finger tight on every thing should be fine. hope fully u have some help if u don't plan on hooking up the steering box
help..just the tow truck driver...
ill take the box and shaft with me. had the front tires mounted today. $40..felt robbed
but ill get it to roll..it's up to them to get it on the truck....
have a old set of weld drag lites with the 28x12.5x15 ET slicks ill air up and toss on the back
the new fronts are MT 26X6X15R
close match to the new rears
Car: 72 nova/ 90 camaro rs,04 suburban
Engine: blown 327/ 355/306/355/5.3
Transmission: muncie 4 speed/T5/powerglide,4l80e
Axle/Gears: 342/411/456/ moser axles
did you get it moved or is that day coming close
got the tires mounted..and the parts layed out..this is weld med pad hight wheel..i wounder what the Hi pad wheel looks like
more then enof room to clear pads..the low pad was just clearing the caliper.
this med pad wheel clears by more then an inch. must be 1" at a time low/med/High
iv always liked the way my front tires hugged/tucked under the front of the car..
I hope they dont push out with this new set of front wheels. all i need was 1/4" more room to feel good..but the nexed part number was a full 2"inches out..
with the drag lights
back the day the eng was pulled.....
Car: 85 Trans Am
Engine: 383 ci
I know..right....
Thinking of going with there low pad.a 2nd time ..And using a 1/4" spacer..have to see what they look like on the car...
As it was the first rims I had from weld in the rts. Was a low pad...and it just touched the calipers....just..so I sent them back and orderd. Fronts in a med high pad..and its a full inch off/above the calipers....lol
well today's the day vans loaded up...hi hope I have all the parts
the before shots...2:30 pm
and it starts.. bolting on parts to move the car
it's not easy holding a k member up with one hand and bolting it in
it was close...but fit like a glove..only thing/tools i forgot..spanner wrench for front coil overs..if i could have had the front up a bit more..but still just fit on the truck..with about 1mm to clear...lol..sitting like its got an eng in it...
it's on and rolling
8:30 pm
it's on and rolling
8:30 pm
got it home..unloaded.. put the covers back on. it was late. ill put it in the shop and remove all the parts i just put on it to move it..lol
total to move it 36 miles $248... but its at it's new home!
whew, glad to see you got it over there. might be time for a truck/trailer though? lol. i know mine has paid for itself 30x's over (i also will haul/recover with it for a cut-rate price for buddies and such...was a good investment for me).
yes definitely going to get a trailer. I'm looking at them all aluminum custom. Probably enclosed. But the that's what my buddies do for me if/when my car breaks at. the track.. I usually get it towed from them. and flip them 30 40 bucks...
looks good man!
Thanks..spent some time. tonight layn out the bolts and getting a game plan layed out.
have a load of parts to still get plated...
have to pull the front end back off to shoot some paint under in the spot the GM K member was bolted up. and start to clean up the eng bay..
Car: 85 Trans Am
Engine: 383 ci
back space looks good on front wheels.. Garage looks killer now you just need a killer tool box in the space instead of that hobo freight box you have. lol. I am a Matco dealer so I am a little biased on how sweet my boxes are.
Will be going over to get my tool boxes this weekend.. the boxes in the pics are xmas gifts from the wife to be...she knows I wanted a new lower box for a welder set up. And a service cart I can take to the car or work site (dont have to make trips to the roll away).picked up a shelf to add to the cart..and added a rubber pad to the top...in case I need to lay somthing heavy on it. And to keep the top nice looking..but I will say.
l...iv had $5600 snap on rollaways..and mac boxes..and that/this service cart. Is built just as well if not better. Lol...had a snap on box stolen..one time...thank god I had insurance it covered everything. Tools were at a depreciated value..but I got almost all paid for. And did the replacement cost reimbursement with my insurance company and i came out on top at the end..and replaced everything with craftsman at half the cost. Oh I still have a few Mac & snap on Tools...but my boxes are all craftsman now...with a air tools in Ingersoll Rand.. Blue Point. And a few others...my first snap on service cart set way too low we always had to put extensions on but the last 25 years the service carts have gotten better.....I will say I like the looks of the stainless steel rollaways...sweet!.
Hobo cart...thats is funny....some of the stuff is not up to snuff
those us general boxes have amazing reviews, and for the money are far superior to other consumer level boxes available on the market. i want to get one of these to put under my work bench...two would be better!
http://www.harborfreight.com/44-in-1...net-68784.html
[QUOTyour ri66nova;5779483]those us general boxes have amazing reviews, and for the money are far superior to other consumer level boxes available on the market. i want to get one of these to put under my work bench...two would be better!
http://www.harborfreight.com/44-in-1...net-68784.html[/QUOTE]
Matt your right. a lot of good reviews. And I can tell you for one the gauge of steel the style of construction is right up with all the time name brands I've had snap on boxes I've had Mac boxes and I had craftsman boxes.in for the price you can't beat em. She paid $169for that service cart and $150 for that craftsman box it's sitting next to in the pic..the reason I didn't buy one a few years ago is they had that flat finish paint on them yuck. But as soon as they did the gloss finish i was in!
i get my 1/4 think black rubber tool box mat from anyplace that sells floor mats.. $8 held in place with duble sticky tape
home depo has some good looking mats..ya got to cut them down to fit the boxes. have used them on top of the work benches before also.
alot to do... got to pick a place and just start.
all new front end (everything) right down to the wheels now i want to go from the new Welds rts to the Welds.
http://www.summitracing.com/parts/wld-788-15274
have not even ran them..and time to upgrade..this is how it works..
so this set will be up for sale soon.
only used to move the car on a rollback
price will be better then summits.
with shipping..
in the facty boxs with all goodys..
with shipping..
AkDrifted
08-17-2015 07:45 PM
db057
08-11-2015 10:11 PM
novaderrik
08-10-2015 12:44 PM
