first rain in two weeks
Engine: 406 sbc, dart iron ea
thrash and get your stuff back together and excited to see what it does and this is what you get. it SUCKS. try again in another two weeks
Re: first rain in two weeks
well got a break from the rain and got to go run my car. ran good except one running hot issue. but after my last pass i broke a spring or something on the passenger front cause it was sittin all the way down and i couldn compress the shock or make it rebound. i dont know what thats about but maybe i can get it apart in the morning. but for the good part the car went a best of 11.44. car still has some left. timing is only set around 31-32. i had a miss at 5600 so i shifted at 5500 and whenever i get the miss fix will shift at 6k. the carb has not be tuned in for that car and i am still running 3.42 rear gear. oh yea and south ms air in july is terrible. so all in all it was a good night. if you dont create problems you can fix em!
yea when i got back to the trailer and got out it just looked like the passenger front tire was flat!!!! i could push down on the car none or pick it up. it was stiff as a rock. and another thing i forgot i need to ad to the car is a rear sway bar. i did create a cage issue tho being it was built to be low 12s high 11s i didn expect to need a cage. and i feel like with some gear and tuning i could possibly see 11.00s out of it. what you think?
do you guys think my 60' is slow because of gear? and my problem is a busted strut. it had stock struts on it. i guess i am goin to order a set of lakewood 90\10s. any suggestions on struts and how to get my 60 down? i was only leaving the line around 2800.
Well finally made it back out. I kept the car in the 11.60 range to keep from goin under11.49 and gettin a cage warning. New struts felt great. Car did good except a bad radiator cap causing some issues. The biggest problem is tryin to learn the tree. I was leaving as soon as the third yellow came on and kept goin red. All but one was .450 range then two real late passes. I just need more seat time and figure out how to sit longer I guess.
3.8TransAM
10-01-2015 07:47 PM
